VOLTAGE
CRYSTAL
CONTROLLED
OSCILLATOR
V132H
VCXO UNIT
WITH
HCMOS
SMD 3.2X2.5MM
OUTPUT IN
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 3.2x2.5x1.0 with 6 solder pads.
Tight stabilities over temperature range.
Tristate enable/ disable function (pad 2).
RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant.
APPLICATIONS
WiMAX / WLAN / Ethernet
DSL / VoIP
Cable modem
Set-top box / HDTV
PRODUCT SPECIFICATIONS
PARAMETER
Frequency range
1.8V
SUPPLY VOLTAGE
2.5V
3.3V
15 ~ 50MHz
10 ~ 250MHz
10 ~ 250MHz
Frequency stability
±25ppm / ±50ppm / ±100ppm
Operating temperature range
±3.0ppm
Frequency pulling range
40mA
Depending on frequency
45mA
Output waveform and load
Options available
@+25°C
±50ppm ~ ±200ppm
Supply current
—See note below
–10 to +60°C / –20 to +70°C / –40 to +85°C
Aging first year
REMARKS
50mA
LVCMOS 15pF
@15pF
30pF optional
Output voltage level HIGH
1.62V
2.25V
2.97V
Minimum
Output voltage level LOW
0.18V
0.25V
0.33V
Maximum
Rise and Fall times
6ns
Symmetry (duty cycle)
@10~90% of VCC
40~60% or 45~55%
Phase jitter RMS
@ 50%VCC
0.8 ~ 1ps
Phase noise (27MHz)
12kHz≤Fj≤20MHz
-132dBc
@ 1kHz
-147dBc
@ 10kHz
-152dBc
@ 100kHz
Note: Stability includes frequency deviations at +25°C, over temperature range, due to supply voltage changes, output load
changes, shock and vibration.
PACKAGE OUTLINE / DIMENSIONS
PACKAGING INFORMATION
Tape & Reel compliant to EIA-481.
Embossed carrier width 8mm.
Component pitch in carrier 4mm.
Reel diameter 180mm.
QTY per reel: 3,000pcs
RECOMMENDED REFLOW PROFILE
Suzhou HangJing Elec&Tech Co., Ltd.
Http://www.hci.com.hk
Telephone:+86 (0)512 6591 6689
No.1,First Qunxing Rd,Suzhou Industrial Park,Jiangsu,China
Mobile phone:+86 (0)13819495058
e-mail: tony@hci.com.hk
V132H-40.000J33DTSL 价格&库存
很抱歉,暂时无法提供与“V132H-40.000J33DTSL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+36.29751
- 10+31.37487
- 30+28.36556
- 100+25.84851
