B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China
TEL :+86(0)755-8327-9247
Fax :+86(0)755-8327-9247
http://www.starwavecorp.com
E-mail :info@starwavecorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD SEAM SEALING X'TAL 3.2*2.5
NOMINAL FREQ.
8.192000MHz
STARWAVE P/N
SWXCEACVK0-8.192000
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by STAR after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
RoHS Compliant
FMT-DOC024
Issue Date: 03.09'06 VER.D
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
8.192000MHz
STARWAVE P/N
SWXCEACVK0-8.192000
REVISION
A1
PE/RD
QA
MFG
28-Jul-23
28-Jul-23
28-Jul-23
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required.
RoHS Compliant
FMT-DOC024
P/N:SWXCEACVK0-8.192000
Rev
Revise page
A1
N/A
FMT-DOC024
Revise contents
Initial released
Date
28-Jul-23
REVISION:
A1
Ref.No.
PAGE:
1
Reviser
N/AYachuan Miao
P/N:SWXCEACVK0-8.192000 REVISION:
PAGE:
A1
2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by HP E5100A or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.018±0.001 g/pcs
Parameters
1 Nominal Frequency
SYM.
Electrical Spec.
MIN
TYPE
MAX
8.192000
FL
Notes
UNITS
MHz
Fundamental
CL
12
pF
4 Frequency Tolerance
±10
ppm
shift to -5ppm at 25 ℃ ± 3 ℃
5 Frequency Tolerance
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
2 Oscillation Mode
3 Load Capacitance
±30
-40
±3
DL
9 Effective Resistance Rr
Rr
10 Shunt Capacitance C0
C0
5.0
11 Motional Capacitance C1
C1
12 Insulation Resistance
500
13 Storage Temperature Range
14 Pulling Sensitivity
8 Drive Level
FMT-DOC024
85
ppm
1st Year
uW
200
Ω
pF
3.0
fF
MΩ
-55
125
19
15
ppm/pF
10
at DC 100V
A1
PAGE:
3
■ DIMENSIONS
0.7±0.1
3.20±0.1
GND
4
2.50±0.1
3
4
MARKING
1
2
3
2
GND
1
Internal View Connection
1.15
3
1
2
0.7
4
1.00
0.65 0.90
1.2
Top View
Suggest Layout
Units:mm
■ MARKING
Marking
Frequency(MHz)
ex:25.000000=25.000MHZ
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
Solder melting point :220 ℃
10 sec
260
220
180
150
Time (sec)
120 sec
FMT-DOC024
60 sec
REVISION:
A1
PAGE:
4
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
QTY
MATERIALS
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
1
2 Base(Package)
Ceramic (AI 2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu
1
Color black
3 PAD
Au
4
Tungsten metalize
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
1
5 Conductive adhesive Ag
4
Silicon resin
6 Electrode
2
FMT-DOC024
Au + Cr
REVISION:
A1
PAGE:
5
INDEX MARK
F
H
■ EMBOSS CARRIER TAPE & REEL
B
E
G
C
A
A
B
Feeding
D
C
D
E
F
G
H
DIMENSIONS
1.65±0.10
3.40±0.10 2.70±0.10 4.00±0.10 8.00±0.20 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
REMARK :
User direction of feed
W
W1
2.0
L1
L
L1
W
W1
178±1.00
13±0.50
11.5±0.20
8±0.10
L
DIMENSIONS
FMT-DOC024
(UNIT:mm)
REVISION:
A1
PAGE:
6
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
1.2 Mechanical Shock
1.3 Vibration
Test Methods
REF.DOC
150 cm height, 3 times on concrete floor.
JIS C6701
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
MIL-STD-202F
MIL-STD-883E
(Total test time 12 hours)
1.4 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2
1.5 Fine Leak
Helium Bombing 4.5 Kg/ cm 2 for 2 hr
1.6 Solder ability
MIL-STD-883E
Temperature
260 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 500 ± 12 hours
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 500 ± 12 hours
REF. DOC
MIL-STD-202F
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
125 ± 3 ¢J
2.4 Thermal Shock
MIL-STD-883E
25 ¢J
-55 ± 3 ¢J
30 min.
30 min.
10 min. max.
2.5 High Temp&Humidity
85℃ ± 3℃, RH 85% , 500Hrs
JIS C5023
2.6 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
FMT-DOC024
SWXCEACVK0-8.192000 价格&库存
很抱歉,暂时无法提供与“SWXCEACVK0-8.192000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.15344
- 50+0.90850
- 150+0.80352
- 500+0.67263
- 3000+0.61431
