page 1 of 9
LUCKI CM ELECTRONICS Co.,Ltd
APPROVAL SHEET
Customer :
Part Number: 3225 GLASS Sealing Crystal
LK Part No.:
L327G260C11L
Holder :
SMD 3225
Frequency:
26.000MHZ 7.3PF ±10PPM
Manufacturer: Lucki Electronics
Date:
2023-04-12
Prepared
Checked
Approved
Zhao Qian
Zhang Dongwei
Zhang Bin
(For Customer Use)
Acceptable
Professional manufacturer of quartz crystal
Http://www.lucki.com.cn
page 2 of 9
Revision History
No.
Revised Date
Change Content
Approved
Remark
page 3 of 9
1.Electrical characteristics
Items
Symbol
Unit
Specification
Min
Model No
Typ
Notes
Max
Seam Seal 3225
Blank Cutting Mode
Nominal Frequency
AT FUND.
F0
Oscillation Mode
Frequency Tolerance
26.000000
■Fundamental
△F/F0
-10
Load Capacitance
CL
Frequency Stability
TC
-20
Topr
Tstg
-40
-55
Operating Temperature
Storage Temperature
MHz
□3rd
10
7.3
ppm
ppm
85
125
100
300
uW
Ω
Drive Level
DL
Effective Resistance RR
Rr
40
Shunt Capacitance C0
C0
2
pF
Trim Sensitivity TS
TS
ppm/PF
Insulation Resistance
Aging:
IR
Fa
500
-2
2
MΩ
ppm
Weight
25℃±3℃
pF
0.0163
at DC 100 V
Per year
g
Remark: Sample Data See Attachment
Measure equipment :
Electrical characteristics measured by S&A 250B or equivalent.
Hermetically :
Fine Leak:
Helium Bombing 4kg/cm2for 1 Hour, Leak ate Less Than -8atm. cc/sec
Gross Leak:
125℃ FC#40 , 120 Seconds, No Bubble
1×10
page 4 of 9
2.Solder Dimension And Pattern
3. Equivalent Circuit
page 5 of 9
4. Structure drawing
NO
COMPONENTS
MATERIALS
1
2
Cap
Base
CERAMIC+GLASS
Ceramic
1
1
Color black
3
PAD
Au
4
Tungsten metalize+ Ni plating+ Au plating
4
Crystal Blank
1
5
SiO2
Conductive Adhesive Ag
4
Silicone
6
Electrode
2
Ag + Cr
QTY FINISH / SPECIFICATIONS
page 6 of 9
5.Reliability Specification
Item
Condition
Free drop
1.
Drop charact eristics
board
Standard
from 100cm height
for
3
times.
on a hard wooden
(Board
is
thickness
more
than 30 mm.)
Mechanical
2
3.
4.
5.
6.
7.
8.
shock
Shake
ch aracteristics
Humidity
ch aracteristics
Low
temperature
Device
are
shocked
hal f
sine
wave
(1000g)
three mutually perpendicular axes each 3 times
Shake
freq uency
swing
1.5mm, direction
10~55Hz,
cyc1~2
x/y/z,
all
minutes,
30
+40±2℃
& 90%~95% R.H. 250 hours
-40±2℃,
25 0 hours,
test after 1 h ours.
High
+85±2℃, 250
hours,
put
in
room
Rr as specification
Frequency change:≤±5ppm
Rr as specification
minutes,
test after 2 h ours.
ch aracteristics
temperature
to
Rr as specification
Rr as specification
temperature,
Rr as specification
put i n
room temperature,
ch aracteristics
Rr as specification
Temperature
-30±3℃/30±3 min~+85±2℃/30±3min,
cycling
5 cycles
Rr as specification
Refluence
ex amination
Rr as specification
page 7 of 9
6. Marking specification
Produce Time Code
page 8 of 9
7. Type & Reel
HC-49SMD
7050
6035
5032
3225
2520
2016
W
24.00±0.30
16.00±0.05
12.00±0.05
12.00±0.05
8.00±0.05
8.00±0.05
8.00±0.05
E
1.75±0.10
1.75±0.10
1.75± 0.10
1.75± 0.10
1.75± 0.10
1.75±0.10
1.75±0.10
F
11.5±0.10
7.5±0.10
5.5± 0.10
5.5± 0.10
3.5± 0.05
3.5±0.05
3.5±0.05
T
0.40±0.05
0.35±0.05
0.35± 0.05
0.30± 0.05
0.25± 0.03
0.25±0.03
0.25±0.03
P
12.00±0.10
8.00±0.10
8.00± 0.10
8.00± 0.10
4.00± 0.05
4.00±0.05
4.00±0.05
P0
4.00±0.10
4.00±0.10
4.00± 0.10
4.00± 0.10
4.00± 0.05
4.00±0.05
4.00±0.05
P2
2.00±0.10
2.00±0.10
2.00± 0.10
2.00± 0.10
2.00± 0.05
2.00±0.05
2.00±0.05
D0
φ1.50+0.10
φ1.50+0.10
φ1.50+0.10
φ1.50+0.10
φ1.50+0.10
φ1.50+0.10
φ1.50+0.10
D1
φ1.50MIN
φ1.50MIN
φ 1.50MIN
φ 1.50MIN
φ 1.00MIN
φ 1.00MIN
φ 1.00MIN
A0
4.60±0.10
5.40±0.10
3.90± 0.10
3.50± 0.10
2.70± 0.10
2.4±0.10
2.00±0.10
K0
4.40±0.10
1.80±0.10
1.50± 0.10
1.60± 0.10
1.50± 0.10
1.10±0.10
1.10±0.10
B0
14.20±0.15
7.40±0.10
6.40± 0.10
5.20± 0.10
3.50± 0.05
2.90±0.05
2.4±0.05
3000pc/reel
page 9 of 9
HC-49SMD
7050
6035
5032
3225
2520
2016
A
φ330±1.0
φ178±2.0
φ178±2.0
φ178±2.0
φ178± 2.0
φ178± 2.0
φ178± 2.0
B
2.30± 0.20
2.00± 0.50
2.00± 0.50
2.00±0.50
2.50±0.50
2.50±0.50
2.50±0.50
C
φ13.5±0.20
φ13.2±0.20
φ13.2±0.20
φ13.2±0.20
φ13.5± 0.20
φ13.5± 0.20
φ13.5± 0.20
D
φ21.5±0.20
φ20.0±0.50
φ20.0±0.50
φ20.0±0.50
φ56.8± 0.50
φ56.8± 0.50
φ56.8± 0.50
N
φ100.0±0.5
φ60.5± 1.0
φ60.5± 1.0
φ60.5± 1.0
φ60.5±1.0
φ60.5±1.0
φ60.5±1.0
W
1
24.5± 0.20
16.5± 0.20
12.5± 0.20
12.5±0.20
9.4±0.30
8.0±0.30
8.0±0.30
T1
2.30± 0.20
1.80± 0.20
1.80± 0.20
1.80±0.20
1.40±0.20
1.40±0.20
1.40±0.20
8. Packing Specification
很抱歉,暂时无法提供与“L327G260C11L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48957
- 100+0.38589
- 300+0.33405
