3TJ413560NYGBC
3TJ413560NYGBC
    JYJE(晶友嘉)
    SMD3225_4P
    无源晶振 13.56MHz ±10ppm 12pF
3TJ413560NYGBC 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD CRYSTAL RESONATOR SPECIFICATIONS 石英晶体谐振器承认书 客户 Customer: 立创商城 型号 Product: 3TJ4 客户料号 Code No: 我司料号 Code No: 3TJ413560NYGBC 频率 Frequency: 13.560MHz 数量 Sample Quantity: 日期 Date: 2023-5-10 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 深圳市龙华区东环二路数字颖博智能园 B 栋 412 TEL: 86-755-32840201 32850080 FAX: 86-755-84269460 供应商确认栏: 制作 Handler 确认 Checked 核审 Approved 戴晓嘉 陈斌 李晨 客户承认栏: 承认 Checked 核审 Approved 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 1.Electrical Parameters No. Item Symb Electrical Specification Min. Type F0 Max. 13.560 Remark Units 1 Nominal Frequency MHz 2 Mode of Vibration 3 Frequency Tolerance ΔF/F0 -10 10 ppm 4 Operating Temperature Range TOPR -30 85 ℃ 5 Frequency Stability TC -20 20 ppm 6 Storage Temperature TSTG -40 90 ℃ 7 Load Capacitance CL 8 Equivalent Series Resistance ESR 9 Drive Level DL 10 Insulation Resistance IR 11 Shunt Capacitance C0 12 Motional Capacitance C1 13 Aging Per Year Fa Fundamental 2. Equivalent Circuit: Page:2 12 At 25℃±3℃ PF 70 100 Ω μW MΩ 500 5 At 100VDC PF PF -3 3 ppm First Year 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 3.实物 Product 4.外型尺寸 Outline Dimensions (unit:mm) Page:3 深圳市晶友嘉电子有限公司 SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD 5.回流焊曲线 Reflow Profiles Profiles Feature Pb-Free Assembly Average Ramp-up Rate (Ts max to Tp) 3℃/second max. Preheat Temperature Min (Ts min) Temperature Max(Ts max) Time (ts min to ts max) 125℃ 200℃ Time maintained above Temperature (TL) Time (tL) 217℃ 60~180 seconds 60~150 seconds Peak/Classification Temperature (Tp) Time within 5℃ of actual Peak Temperature(tp) 20~40 second Ramp-down rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Suggest reflow times 3 times max. Page:4 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 6.机械可靠/信赖性 Mechanical Performance Item 1. 2.. Drop characteristics Shake characteristics Condition Standard Free drop from 50cm height on a hard Frequency change: wooden board for 3 times. (Board is ≤5ppm thickness more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 Frequency change: minutes, swing 1.5mm, direction x/y/z, all ≤5ppm 30 minutes, test after 1 hours. Rr as specification Put crystal into the pressure cabin with 3. Airproof alcohol, keep pressure 0.4~0.5mpa 10 characteristics minutes, then take out and blow for 5 IR≥500MΩ minutes 4. 5. 6. 7. 8. Weld characteristics Humidity characteristics 260℃ Max, 10 seconds 90% exhibit tin ok Frequency change: +40±2℃ & 90%~95% R.H. 250 hours ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Page:5 Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7.Dimension of Inside Package 1. 5 内包装尺寸图 .5 ± 0180 .0 3- 10 + 0/-0 02 08 06 04 + 1/- 0 08 06 04 06 0.0 Ho le 02 Ps 01 3.0 ± 0 .2 0 .4 3-2.0 ±0.5 Ho le 01 3. 0 ±0. 5 La b el 17 .0± 0.3 * 1 19. 4 ±1 * 2 G T E J * 1 -5032, - 4025: 13.0±0 .3, -3225 : 9.0±0 .3 * 2 -50 32, -4 025:15 .4±1.0 , -322 5 : 11. 4±1.0 *3 -S e ries : 3 30 B C D H # 2#3 F Q K A Direc tio n  Standard quantity of 3225 : 3.000 pcs/reel  Standard quantity of others : 1.000 pcs/reel  Carrier tape : Antistatic material (PS)  Each reel can be recycled Page:6 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7050 6035 5032 3225 A 5.4±01 3.9±0.1 3.5±0.1 2.9±0.1 B 7.4±0.1 6.4±0.1 5.4±0.1 3.6±0.1 C 16.0±0.2 16.0±0.2 12.0±0.2 10.0±0.2 D 7.5±0.1 7.5±0.1 5.5±0.1 5.5±0.1 E 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 F 8.0±0.1 8.0±0.1 8.0±0.1 4.0±0.1 G 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 H 4.0±0.1 4.0±0.1 4.0±0.1 4.0±0.1 J 1.55±0.05 1.55±0.05 1.5+0.1/0 1.5±0.1/0 K 1.4±0.1 1.5±0.1 1.0±0.1 0.9±0.1 Q 1.6+0.1/0 1.55±0.05 1.6±0.1 1.5±0.1/0 T 0.3±0.05 0.3±0.05 0.25±0.05 0.25±0.05s 8.Inner carton A nt istat ic bag Seal Reel Labl e L able Reel Page:7 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD OUTET CARTON Lable 8-1.MARKING (1)Marking Labels are affixed to reel, inner carton and outer carton. (2) Each label contains the following information. (a) Manufacture’s name or aymbol (b) Parts name or type ( c) Frequency ( d) Quantity (e) Reel number (f) Manufacturer’s code (EIAJ code) 8-2. QUANTITY 3000pcs/reel (max.5reels in outer carton) 8-3. STORAGE ENVIRONMENT  Storage the reel at normal temperature and humidity  Open the packing just before using  Do not expose the sun  Do not storage with some erosive chemicals  Nothing is allowed to put on the reel or carton to prevent mechanical damage  Nothing is allowed to put on the reel or carton to prevent mechanical damage. 8-4. HANDLING  Handle with care to prevent the damage of tape, reel and products.
3TJ413560NYGBC 价格&库存
很抱歉,暂时无法提供与“3TJ413560NYGBC”相匹配的价格&库存,您可以联系我们找货
3TJ413560NYGBC
    • 5+0.42768
    • 50+0.41764
    • 150+0.41105
    • 500+0.40436
