深圳市晶友嘉电子有限公司
SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD
CRYSTAL RESONATOR SPECIFICATIONS
石英晶体谐振器承认书
客户 Customer:
立创
型号 Product:
3TJ4
客户料号 Code No:
C17702131
我司料号 Code No:
3TJ498437NYLBC
频率 Frequency:
9.84375MHz
数量 Sample Quantity:
日期 Date:
2023-8-20
深圳市晶友嘉电子有限公司
深圳市龙华区东环二路数字颖博智能园 B 栋 412
TEL: 86-755-32840201 32850080
FAX: 86-755-84269460
供应商确认栏:
制作 Handler
确认 Checked
核审 Approved
戴晓嘉
陈斌
李晨
客户承认栏:
承认 Checked
核审 Approved
深圳市晶友嘉电子有限公司
1.Electrical Parameters
No.
Item
Symb
Electrical Specification
Min.
Type
F0
Max.
9.84375
Remark
Units
1
Nominal Frequency
MHz
2
Mode of Vibration
3
Frequency Tolerance
ΔF/F0
-10
10
ppm
4
Operating Temperature Range
TOPR
-30
85
5
Frequency Stability
TC
-20
ppm
6
Storage Temperature
TSTG
-40
90
7
Load Capacitance
CL
8
Equivalent Series Resistance
ESR
9
Drive Level
DL
10
Insulation Resistance
IR
11
Shunt Capacitance
C0
12
Motional Capacitance
C1
13
Aging Per Year
Fa
Fundamental
2. Equivalent Circuit:
Page:2
12
At 25℃±3℃
PF
150
100
Ω
μW
MΩ
500
5
At 100VDC
PF
PF
-3
3
ppm
First Year
深圳市晶友嘉电子有限公司
3.实物 Product
4.外型尺寸 Outline Dimensions (unit:mm)
Page:3
深圳市晶友嘉电子有限公司
SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD
5.回流焊曲线 Reflow Profiles
Profiles Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts max to Tp)
3℃/second max.
Preheat
Temperature Min (Ts min)
Temperature Max(Ts max)
Time (ts min to ts max)
125℃
200℃
Time maintained above
Temperature (TL)
Time (tL)
217℃
60~180 seconds
60~150 seconds
Peak/Classification Temperature (Tp)
Time within 5℃ of actual Peak
Temperature(tp)
20~40 second
Ramp-down rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Suggest reflow times
3 times max.
Page:4
深圳市晶友嘉电子有限公司
6.机械可靠/信赖性 Mechanical Performance
Item
1.
2..
Drop
characteristics
Shake
characteristics
Condition
Standard
Free drop from 50cm height on a hard
Frequency change:
wooden board for 3 times. (Board is
≤5ppm
thickness more than 30 mm.)
Rr as specification
Shake frequency 10~55Hz, cyc1~2
Frequency change:
minutes, swing 1.5mm, direction x/y/z, all
≤5ppm
30 minutes, test after 1 hours.
Rr as specification
Put crystal into the pressure cabin with
3.
Airproof
alcohol, keep pressure 0.4~0.5mpa 10
characteristics
minutes, then take out and blow for 5
IR≥500MΩ
minutes
4.
5.
6.
7.
8.
Weld
characteristics
Humidity
characteristics
260℃ Max, 10 seconds
90% exhibit tin ok
Frequency change:
+40±2℃ & 90%~95% R.H. 250 hours
≤5ppm
Rr as specification
Low temperature
-30±2℃, 250 hours, put in room
characteristics
temperature, test after 1 hours.
High temperature
+85±2℃, 250 hours, put in room
characteristics
Temperature
-30±3℃/30±3 min~+85±2℃/30±3min, 5
cycling
cycles
Page:5
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
Frequency change:
≤5ppm
Rr as specification
深圳市晶友嘉电子有限公司
7.Dimension of Inside Package
1. 5
内包装尺寸图
.5 ±
0180 .0
3-
10
+ 0/-0
02
08
06
04
+ 1/- 0
08
06
04
06 0.0
Ho le
02
Ps
01 3.0
± 0 .2
0 .4
3-2.0 ±0.5
Ho le
01 3. 0
±0. 5
La b el
17 .0± 0.3 * 1
19. 4 ±1 * 2
G
T
E
J
* 1 -5032, - 4025: 13.0±0 .3, -3225 : 9.0±0 .3
* 2 -50 32, -4 025:15 .4±1.0 , -322 5 : 11. 4±1.0
*3 -S e ries : 3 30
B
C
D
H
# 2#3
F
Q
K
A
Direc tio n
Standard quantity of
3225 : 3.000 pcs/reel
Standard quantity of others : 1.000 pcs/reel
Carrier tape : Antistatic material (PS)
Each reel can be recycled
Page:6
深圳市晶友嘉电子有限公司
7050
6035
5032
3225
A
5.4±01
3.9±0.1
3.5±0.1
2.9±0.1
B
7.4±0.1
6.4±0.1
5.4±0.1
3.6±0.1
C
16.0±0.2
16.0±0.2
12.0±0.2
10.0±0.2
D
7.5±0.1
7.5±0.1
5.5±0.1
5.5±0.1
E
1.75±0.1
1.75±0.1
1.75±0.1
1.75±0.1
F
8.0±0.1
8.0±0.1
8.0±0.1
4.0±0.1
G
2.0±0.1
2.0±0.1
2.0±0.1
2.0±0.1
H
4.0±0.1
4.0±0.1
4.0±0.1
4.0±0.1
J
1.55±0.05
1.55±0.05
1.5+0.1/0
1.5±0.1/0
K
1.4±0.1
1.5±0.1
1.0±0.1
0.9±0.1
Q
1.6+0.1/0
1.55±0.05
1.6±0.1
1.5±0.1/0
T
0.3±0.05
0.3±0.05
0.25±0.05
0.25±0.05s
8.Inner carton
A nt istat ic bag
Seal
Reel
Labl e
L able
Reel
Page:7
深圳市晶友嘉电子有限公司
OUTET CARTON
Lable
8-1.MARKING
(1)Marking Labels are affixed to reel, inner carton and outer carton.
(2) Each label contains the following information.
(a) Manufacture’s name or aymbol
(b) Parts name or type
( c) Frequency
( d) Quantity
(e) Reel number
(f) Manufacturer’s code (EIAJ code)
8-2. QUANTITY
3000pcs/reel (max.5reels in outer carton)
8-3. STORAGE ENVIRONMENT
Storage the reel at normal temperature and humidity
Open the packing just before using
Do not expose the sun
Do not storage with some erosive chemicals
Nothing is allowed to put on the reel or carton to prevent mechanical damage
Nothing is allowed to put on the reel or carton to prevent mechanical damage.
8-4. HANDLING
Handle with care to prevent the damage of tape, reel and products.
很抱歉,暂时无法提供与“3TJ498437NYLBC”相匹配的价格&库存,您可以联系我们找货
