F3225100MWFCK2F466
F3225100MWFCK2F466
    YJX(雅晶鑫)
    SMD3225_6P
    有源晶振 100MHz 3.3V -40℃~+85℃ LVDS
F3225100MWFCK2F466 数据手册
雅晶鑫電子 Shenzhen Yajingxin Electron Co.,Ltd Customer Production Name SMD LVDS OSC SEAM 3.2*2.5 Customer P/N N/A P/N F3225100MWFCK2F466 Revision A Print Date 2023-06-27 Drawn Checked Approved RoHS Compliant ■ Electrical Specifications 1.Model No 3225 LVDS OSC 2.Nominal Frequency:F0 100.000MHz 3.Mode of Oscillation 3RDOvertone 4.Operating Temperature Range:Top -40℃ to85℃ 5.Storage Temperature Range: Tst -55℃ to +125℃ 6.Frequency Stability ±50ppm TYP. ±30PPM CONTACT SALES Fdev 7.Power Supply Voltage Vcc 3.3V±10% 8.Current Consumption: I 50mA Max. 9mA typ. @100mhz 3.3v 9.Output Voltage 1.6V MAX, 1.45V typ. 10.Output Load: Logic High(VoH) Logic Low(VoL) Vod(OUTP_H-OUTN_L) Vop(OUTP-OUTN) Cload 0.9V min 1.1V typ. 250mV-450mV 500mv-900mV 100 Ohms 11.Semmetry (at 50%VDD) :Duty 12.Rise & Fall Time :Tr &Tf 45-55% @CROSS POINT 0.5 ns Max. 13.Tri-State Function Tri-state 14.Output Disable Time 15.Output Enable Time(start-up time) 100nsec 10msec max 16.OE pin input: 0.3Vcc Max 70% Vcc Min. VinL: VinH 17.RMS Phase Jitter (Integrated 12 kHz ~ 20 MHz) 1 ps max 18.aging per year: ±3ppm/year ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p2/8 ■ Part Number Configuration ■Dimensions ■ Marking ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p3/8 CANDOR 100.000MHz Line 1: CANDOR Line 2: 100.000MHz 中间对齐。 ■Output Wave Form AND Test diagram,: Measuring Measuring for for Vod. Vopp, Tr,Tf,Duty ■Enable/Disable timing: ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p4/8 ■Termination Diagrams for Enduser. LVDS AC Termination LVDS DC Termination at the Load . ■ Reflow Profile ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p5/8 Note: 1) Maximum of 3 reflow cycles is recommended In order to minimize device damage: 2) *Do not wash or clean the board after reflow process because of the unit with a vent hole on the back side . ■ Reliability Specifications ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p6/8 No Test Item Test Methods Device are dropped from a height of 75 cm onto 3 mm 1 DROP TEST thickness stainless plate executing 3 times of random drops. Device are shocked to half sine wave (1000 G) three 2 MECHANICAL SHOCK 3 High Temp and Humidity Test 85℃/RH 85%, 500Hrs 4 High temp storage test 125℃+/-2℃ 500Hrs 5 Low temp storage test -40℃ 500Hrs 6 Thermal shock test 7 Aging test 8 Resistance 9 to solder VIBRATION mutually perpendicular axes each 3 times. -40℃~+85℃ DWEL 60' 100cycles 85℃ 1000Hrs heat 260℃ 10S Frequency range 10-2000 Hz Amplitude Sweep 1.5 mm Sweep Time 20 minute Test Time2 hours MIL - STD - 20E Method 208C Temperature 10 SOLDERABILITY Material 245°C±5°C H63A (Silver 2-3 %) Immersion depth 0.5 mm minimum Immersion time 3 ± 0.5 seconds Flux Rosin resin methyl ■ Packaging ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p7/8 ■ Reel Dimension 单位:mm 规格 C1±3 H±0.5 A±0.3 B±0.5 B1±0.3 T±0.2 T1±0.2 D±0.5 8mm 178 8.8 2.6 22.5 13.5 2.0 1.6 60.0 NOTE: QTY 3K/REEL. ********************************************************************** Shenzhen Yajingxin Electron Co.,Ltd p8/8 备注
F3225100MWFCK2F466 价格&库存
很抱歉,暂时无法提供与“F3225100MWFCK2F466”相匹配的价格&库存,您可以联系我们找货
F3225100MWFCK2F466
库存:61
