雅晶鑫電子
Shenzhen Yajingxin Electron Co.,Ltd
Customer
Production Name
SMD LVDS OSC SEAM 3.2*2.5
Customer P/N
N/A
P/N
F3225125MWFCK2F466
Revision
A
Print Date
2023-06-27
Drawn
Checked
Approved
RoHS Compliant
■ Electrical Specifications
1.Model No
3225 LVDS OSC
2.Nominal Frequency:F0
125.000MHz
3.Mode of Oscillation
3RDOvertone
4.Operating Temperature Range:Top
-40℃ to85℃
5.Storage Temperature Range: Tst
-55℃ to +125℃
6.Frequency Stability
±50ppm TYP. ±30PPM CONTACT SALES
Fdev
7.Power Supply Voltage Vcc
3.3V±10%
8.Current Consumption: I
50mA Max.
9mA typ. @125mhz 3.3v
9.Output Voltage
1.6V MAX, 1.45V typ.
10.Output Load:
Logic High(VoH)
Logic Low(VoL)
Vod(OUTP_H-OUTN_L)
Vop(OUTP-OUTN)
Cload
0.9V min
1.1V typ.
250mV-450mV
500mv-900mV
100 Ohms
11.Semmetry (at 50%VDD) :Duty
12.Rise & Fall Time :Tr &Tf
45-55% @CROSS POINT
0.5 ns Max.
13.Tri-State Function
Tri-state
14.Output Disable Time
15.Output Enable Time(start-up time)
100nsec
10msec max
16.OE pin input:
0.3Vcc Max
70% Vcc Min.
VinL:
VinH
17.RMS Phase Jitter
(Integrated 12 kHz ~ 20 MHz)
1 ps max
18.aging per year:
±3ppm/year
p2/8
■ Part
Number Configuration
■Dimensions
■ Marking
p3/8
CANDOR
125.000MHz
Line 1:
CANDOR
Line 2: 125.000MHz
中间对齐。
■Output Wave Form AND Test diagram,:
Measuring
Measuring for
for Vod.
Vopp, Tr,Tf,Duty
■Enable/Disable timing:
p4/8
■Termination Diagrams for Enduser.
LVDS AC Termination
LVDS DC Termination at the Load .
■ Reflow Profile
p5/8
Note:
1) Maximum of 3 reflow cycles is recommended In order to minimize device damage:
2) *Do not wash or clean the board after reflow process because of the unit with a vent
hole on the back side .
■ Reliability Specifications
p6/8
No
Test Item
Test Methods
Device are dropped from a height of 75 cm onto 3 mm
1
DROP TEST
thickness stainless plate executing 3 times of random
drops.
Device are shocked to half sine wave (1000 G) three
2
MECHANICAL SHOCK
3
High Temp and Humidity Test
85℃/RH 85%, 500Hrs
4
High temp storage test
125℃+/-2℃ 500Hrs
5
Low temp storage test
-40℃ 500Hrs
6
Thermal shock test
7
Aging test
8
Resistance
9
to
solder
VIBRATION
mutually perpendicular axes each 3 times.
-40℃~+85℃ DWEL 60' 100cycles
85℃ 1000Hrs
heat
260℃ 10S
Frequency range 10-2000 Hz
Amplitude Sweep 1.5 mm
Sweep Time
20 minute
Test Time2 hours
MIL - STD - 20E Method 208C
Temperature
10
SOLDERABILITY
Material
245°C±5°C
H63A (Silver 2-3 %)
Immersion depth
0.5 mm minimum
Immersion time
3 ± 0.5 seconds
Flux
Rosin resin methyl
■ Packaging
p7/8
■ Reel Dimension
单位:mm
规格
C1±3
H±0.5
A±0.3
B±0.5
B1±0.3
T±0.2
T1±0.2
D±0.5
8mm
178
8.8
2.6
22.5
13.5
2.0
1.6
60.0
NOTE: QTY
3K/REEL.
p8/8
备注
很抱歉,暂时无法提供与“F3225125MWFCK2F466”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+14.16960
- 10+12.03120
- 30+10.68120
- 100+9.30960
- 500+8.68320
- 1000+8.41320
