SWOCEV33S8-50.000000
    STARWAVE(思大)
    SMD3225_4P
    有源晶振 50MHz ±10ppm 3.3V -40℃~+85℃ CMOS
SWOCEV33S8-50.000000 数据手册
OC Type Crystal Oscillator Typical 3.2 x 2.5 mm Frequency 1MHz to 80MHz FEATURE - Typical 3.2 x 2.5 x 0.95 mm ceramic SMD package - Operation supply voltage: 1.8V, 2.5V and 3.3V - Output frequency up to 80MHZ - Tri-State Enable/Disable - Frequency Stability ±50ppm over -40 oC to 105 oC - Pb-free/RoHS compliant TYPICAL APPLICATION - WLAN/WiMax - Mobile Phone - DSC, Set-topBox , HDTV DIMENSION (mm) SOLDER PAD LAYOUT (mm) 0.1 μF [ BO TTO M VIEW ] [ TOP VIEW ] 2.10 ± 0.15 #3 #2 #2 #1 0.90 ± 0.15 Pin# 0.35 0.95 ± 0.15 [ SIDE VIEW ] 1 2 3 4 1.60 1.10 2.50 ± 0.15 #1 #4 1.65 ± 0.15 #3 #4 0.65 ± 0.15 3.20 ± 0.15 2.10 Function 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3V Parameter Supply Voltage Variation (VDD) Frequency Range 2.5V Min. Max. Min. Max. VDD-5% VDD+5% VDD-5% VDD+5% VDD-5% VDD+5% V 4.00 54.00 4.00 54.00 4.00 54.00 MHz - 15 - 10 - 7 mA - 1.5 - 1.5 - 1.2 mA mA 4.000MHz~54.000MHz At 15pF Load Current No Load Condition, 1.25MHz Fo < 10MHz Unit Max. Standard Frequency Supply 1.8V Min. MHz No Load Condition, 10MHz Fo < 20MHz - 2 - 2 - 1.5 No Load Condition, 20MHz Fo < 80MHz - 3 - 2.5 - 1.5 mA No Load Condition, 80MHz Fo < 125MHz - 8 - 7 - 5 mA Duty Cycle Output Level 45 55 45 55 45 55 % Output High 2.97 - 2.25 - 1.62 - V Output Low - 0.33 - 0.25 - 0.18 V - 3 - 4 - 5 nSec Fo < 10MHz 1.25MHz Transition Time: 10MHz Fo < 20MHz - 3 - 3 - 4 nSec Rise / Fall Time+ 20MHz Fo < 80MHz - 3 - 3 - 4 nSec 80MHz Fo < 125MHz - 3 - 3 - 4 nSec - 2 - 2 - 2 mSec 2.31 - 1.75 - 1.26 - V - 0.99 - 0.75 - 0.54 Startup Time Tri-State Enable (High Voltage or Floating) (Input to Pin 1) Disable (Low Voltage or GND) Output Loading 15 15 15 V pF Stand by Current (@-40oC to 85oC) - 10 - 10 - 10 Stand by Current (@-40oC to 125oC) - 20 - 20 - 20 Period Jitter (Pk-Pk) - 40 - 40 - 40 pSec RMS Phase Jitter (12kHz to 20MHz) - 1 - 1 - 1 pSec Aging (@ 25oC, 1st Year) - 3 - 3 - 3 ppm -55 +125 -55 +125 -55 +125 Storage Temp. Range A A o C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position +Transition times are measured between 10% and 90% of VDD, withan output load of 15pF FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±15 -20~+70 -40~+85 -40~+105 ± 20 ±25 ± 50 *O: Available △: Conditional X: Not available *Inclusive of calibration @ 25 oC ,operating temperature rrange,input Voltage variation,load variation,aging (1st year),shock,and vibration Note: not all combination of options are available. Other specifications may be available upon request. www.starwavecorp.com info@starwavecorp.com OC Type Crystal Oscillator Typical 3.2 x 2.5 mm Frequency 1MHz to 80MHz Ordering Information Output Drive Strength SW O C B V 33 E F 25.000000D Brand SW:Starwave Part Series O: Oscillator Output Drive Strength 4 :4 mA 8 :8 mA F :16 mA Packing “D”: 8 mm Tape & Reel, 3ku reel “E”: 8 mm Tape & Reel, 1ku reel “T”: 12/16 mm Tape & Reel, 3ku reel “Y”: 12/16 mm Tape & Reel, 1ku reel Blank for Bulk Frequency XX.XXX MHz Feature Pin “E” for Output Enable “S” for Tri-State Package Size “E” “D” “C” “B” “A” 2.0 x 1.6 mm 2.5 x 2.0 mm 3.2 x 2.5 mm 5.0 x 3.2 mm 7.0 x 5.0 mm Supply Voltage “18” for 1.8V ±10% “25” for 2.5V ±10% “33” for 3.3V ±10% Frequency Stability Temperature Range “A” for ±15 ppm “B” for ±20 ppm “C” for ±25 ppm “D” for ±50 ppm “E” for ±30 ppm “U” Commercial, -20ºC to 70ºC “V” Industrial, - 40ºC to 85ºC W:High Temp -40 ºC to + 105 ºC Table 13. Ordering Codes for Supported Tape & Reel Packing Method Device Size (mm x mm) 16 mm T&R (3ku) 16 mm T&R (1ku) 8 mm T&R (3ku) 8 mm T&R (1ku) 2.0 x 1.6 – – – – D E 2.5 x 2.0 – – – – D E 3.2 x 2.5 – – – – D E 5.0 x 3.2 – – T Y – – 7.0 x 5.0 T Y – – – – www.starwavecorp.com 12 mm T&R (3ku) 12 mm T&R (1ku) info@starwavecorp.com
SWOCEV33S8-50.000000 价格&库存
很抱歉,暂时无法提供与“SWOCEV33S8-50.000000”相匹配的价格&库存,您可以联系我们找货
  • 5+1.67768
  • 50+1.47356
  • 150+1.38608
  • 500+1.27700
库存:2523
