SWOCEV33S8-20.000000 数据手册
OC Type Crystal Oscillator
Typical 3.2 x 2.5 mm
Frequency 1MHz to 80MHz
FEATURE
- Typical 3.2 x 2.5 x 0.95 mm ceramic SMD package
- Operation supply voltage: 1.8V, 2.5V and 3.3V
- Output frequency up to 80MHZ
- Tri-State Enable/Disable
- Frequency Stability ±50ppm over -40 oC to 105 oC
- Pb-free/RoHS compliant
TYPICAL APPLICATION
- WLAN/WiMax
- Mobile Phone
- DSC, Set-topBox , HDTV
DIMENSION (mm)
SOLDER PAD LAYOUT (mm)
0.1 μF
[ BO TTO M VIEW ]
[ TOP VIEW ]
2.10 ± 0.15
#3
#2
#2
#1
0.90 ± 0.15
Pin#
0.35
0.95 ± 0.15
[ SIDE VIEW ]
1
2
3
4
1.60
1.10
2.50 ± 0.15
#1
#4
1.65 ± 0.15
#3
#4
0.65 ± 0.15
3.20 ± 0.15
2.10
Function
1.20
Tri-state
GND
Output
VDD
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Supply Voltage Variation (VDD)
Frequency Range
2.5V
Min.
Max.
Min.
Max.
VDD-5%
VDD+5%
VDD-5%
VDD+5%
VDD-5%
VDD+5%
V
4.00
54.00
4.00
54.00
4.00
54.00
MHz
15
10
7
mA
1.5
1.5
1.2
mA
mA
4.000MHz~54.000MHz
At 15pF Load
Current
No Load Condition, 1.25MHz
Fo < 10MHz
Unit
Max.
Standard Frequency
Supply
1.8V
Min.
MHz
No Load Condition, 10MHz
Fo < 20MHz
2
2
1.5
No Load Condition, 20MHz
Fo < 80MHz
3
2.5
1.5
mA
No Load Condition, 80MHz
Fo < 125MHz
8
7
5
mA
Duty Cycle
Output Level
45
55
45
55
45
55
Output High
2.97
2.25
1.62
V
Output Low
0.33
0.25
0.18
V
3
4
5
nSec
Fo < 10MHz
1.25MHz
Transition Time:
10MHz
Fo < 20MHz
3
3
4
nSec
Rise / Fall Time+
20MHz
Fo < 80MHz
3
3
4
nSec
80MHz
Fo < 125MHz
3
3
4
nSec
2
2
2
mSec
2.31
1.75
1.26
V
0.99
0.75
0.54
Startup Time
Tri-State
Enable (High Voltage or Floating)
(Input to Pin 1)
Disable (Low Voltage or GND)
Output Loading
15
15
15
V
pF
Stand by Current (@-40oC to 85oC)
10
10
10
Stand by Current (@-40oC to 125oC)
Period Jitter (Pk-Pk)
40
40
40
pSec
RMS Phase Jitter (12kHz to 20MHz)
1
1
1
pSec
Aging (@ 25oC, 1st Year)
3
3
3
ppm
-55
+125
-55
+125
-55
+125
Storage Temp. Range
A
A
o
C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position
+Transition times are measured between 10% and 90% of VDD, withan output load of 15pF
FREQ. STABILITY vs. TEMP. RANGE
Temp.
(°C)
ppm
±15
-20~+70
-40~+85
-40~+105
± 20
±25
± 50
*O: Available △: Conditional X: Not available
*Inclusive of calibration @ 25 oC ,operating temperature
rrange,input Voltage variation,load variation,aging (1st
year),shock,and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
www.starwavecorp.com
info@starwavecorp.com
Ordering Information
Output Drive Strength
SW O C B V 33 E F 25.000000D
Brand
SW:Starwave
Part Series
O: Oscillator
4 :4 mA
8 :8 mA
F :16 mA
Packing
“D”: 8 mm Tape & Reel, 3ku reel
“E”: 8 mm Tape & Reel, 1ku reel
“T”: 12/16 mm Tape & Reel, 3ku reel
“Y”: 12/16 mm Tape & Reel, 1ku reel
Blank for Bulk
Frequency
XX.XXX MHz
Feature Pin
“E” for Output Enable
“S” for Tri-State
Package Size
“E”
“D”
“C”
“B”
“A”
2.0 x 1.6 mm
2.5 x 2.0 mm
3.2 x 2.5 mm
5.0 x 3.2 mm
7.0 x 5.0 mm
Supply Voltage
“18” for 1.8V ±10%
“25” for 2.5V ±10%
“33” for 3.3V ±10%
Frequency Stability
Temperature Range
“A” for ±15 ppm
“B” for ±20 ppm
“C” for ±25 ppm
“D” for ±50 ppm
“E” for ±30 ppm
“U” Commercial, -20ºC to 70ºC
“V” Industrial, - 40ºC to 85ºC
W:High Temp -40 ºC to + 105 ºC
Table 13. Ordering Codes for Supported Tape & Reel Packing Method
Device Size
(mm x mm)
16 mm T&R (3ku)
16 mm T&R (1ku)
8 mm T&R (3ku)
8 mm T&R (1ku)
2.0 x 1.6
D
E
2.5 x 2.0
D
E
3.2 x 2.5
D
E
5.0 x 3.2
T
Y
7.0 x 5.0
T
Y
12 mm
T&R (3ku)
12 mm T&R (1ku)
SWOCEV33S8-20.000000 价格&库存
很抱歉,暂时无法提供与“SWOCEV33S8-20.000000”相匹配的价格&库存,您可以联系我们找货
