page 1 of 10
LUCKI CM ELECTRONICS Co.,Ltd
APPROVAL SHEET
Customer :
Part Number:
LK Part No.:
L32AOC050000PBL
Holder :
3225 OSC
Frequency:
50.000MHz 3.3V
Manufacturer: Lucki Electronics
Date:
2023-05-22
Prepared
Zhao Qian
Checked
Approved
Zhang Dongwei
Zhang Bin
(For Customer Use)
Acceptable
Professional manufacturer of quartz crystal
Http://www.lucki.com.cn
page 2 of 10
Revised Record
Rev.
Rev. Date
Item
Content
Remark
page 3 of 10
ELECTRICAL PARAMETERS
No.
Symb.
Item
Electrical Specification
Min.
1
Nominal Frequency
2
Frequency Stability
3
Operating Temperature
Range
F0
TOPR
-40
85
TSTG
-55
125
Power supply Voltage
VDD
6
Aging Per Year
Fa
7
Supply current
IDD
8
Output symmetry
Sym
9
Rise time
Tr
10
Fall time
Tf
13
MHz
50.000000
ppm
5
12
Units
30
Storage Temperature
Output voltage
Max.
-30
4
11
Typ.
VOH
All condition*
V
3.3±10%
-3.0
45
3.0
ppm
10
mA
55
5.0
ns
10%~90%VDD
5.0
ns
90%~10%VDD
90%
First Year
VDD
10%
VDD
Output load Hcmos Load
15
pF
Start-up time
10
mS
VOL
Remark
pin 1=“High ”or “open” ......output active at pin 3
14
Pin 1, E/D function
pin 1=“Low” ......high impedance at pin 3
pin 1=“Low”&Floating …… unstable at pin3,disallowed for this status
15
Package type
POSC3225
NOTE:Storage Temperature is only for the product itself,the temperature for the packing
material is -4~40℃.
All condition*:Include 25℃ tolerance, operating temperature range , input voltage change,
aging, load change.
STORAGE REQUIRMENT
Storage environmental conditions: -4~40℃, 70%RH max.
Maximum storage time: 24 Months from date of manufacture.
page 4 of 10
HCMOS Test Circuit
Enable/ Disable Function
Input (pin 1)
Output (pin 3)
Open
Enable
Oscillator
Normal operation
VIH :0.7*VDD ~ VDD
Enable
Normal operation
VIL :0V ~ 0.3*VDD
Disable
Stop oscillation
HCMOS OUTPUT WAVEFORM
page 5 of 10
OUTLINE DIMENSIONS (unit: mm)
Pin
Connection
1
E/D
2
GND
3
Output
4
VDD
Note:■ 0.01uF bypass capacitor should be placed between VDD (pin 4) and GND (pin 2)to minimize
power supply line noise;
■ Line shouldn't be layed under the oscillator in the PCB to minimize signal interference.
■ The Load we advise is only 15pF (that means drive only 1 CMOS/TTL gate).
■ unlabeled tolerance:± 0.1mm
MARKING
page 6 of 10
PRODUCT LAYOUT
ADHESIVE
Lid
Electrode
Blank
Gold wire
IC
PKG
NO.
PART
REMARK
LID
MATERIAL
KOVAR(Fe+Co+Ni alloy)
1
2
PKG
Al2 O3
Base
3
BLANK
Quartz
4
ADHESIVE
SiO2
Ag/Silicon
5
Electrode
Noble metal
6
IC
Si
7
Gold wire
Au
Support
Connect
page 7 of 10
REFLOW PROFILES
Pb- Free Assembly
Profiles Feature
Average Ramp-up Rate (Ts max to Tp)
3℃/second max.
Preheat
■ Temperature Min (Ts min)
■ Temperature Max (Ts max)
■ Time (ts min to ts max)
125℃
200℃
60~180 seconds
Time maintained above
■ Temperature (TL)
■ Time (tL)
Peak/ Classification Temperature (Tp)
Time within 5℃ of actual Peak
Temperature (tp)
Ramp- down rate
Time 25℃ to Peak Temperature
Suggest reflow times
217℃
60~150 seconds
260℃
20~40 seconds
6℃/second max.
8 minutes max.
3 Times max
Remark:To reference JEDEC J-STD-020
page 8 of 10
PACKAGE(reference to EIA-481)
Tape Dimensions(unit : mm)
A
1.5±0.1
B
C
D
E
F
4.0±0.1
4.0±0.1
3.5±0.1
8.0±0.1 1.4±0.10
L1
W
t
3.5±0.10
2.7±0.10
0.25±0.05
Reel Dimensions(unit: mm)
G
2.2±0.5
*3000pcs/Reel
H
I
J
K
L
M
13.5±0.5
18.2±0.5
60.0± 1.0
178.0± 1.0
9.5± 1.0
1.6±0.2
page 9 of 10
Carton Dimension (unit : mm)
180
25
130
50 25 45
70
45
50
80
50
25
180
180
25
485
1 reel = 1 Inner box
150
150
180
25
23
300
420
20 Inner boxes = 1 Carton,60kpcs = 1 Carton
page 10 of 10
Reliability characteristic:
No.
Test Item
Solderability
Solder bath temperature:260℃ , dwell time:5 seconds,
Solder: 100% tin
A new uniform coating of
solder shall cover a
minimum of 95% of the
surface being immersed.
Resistance to
soldering heat
Solder temperature 260+/-3℃,Immersion time:10 S
Solder bath composition:100% tin
∆F≤+/-5ppm
Vibration
The entire frequency range: 10Hz to
55Hz ,Amplitude:1.5mm
This motion shall be applied for a period of 2 h in each
of 3 mutually perpendicular axes(a total of 6h)
∆F≤+/-5ppm
Drop test
3 Times Free Fall from 100cm height to
concrete floor.
∆F≤+/-5ppm
Cold Storage
The quartz crystal unit shall be stored at a temperature
of –40+/-3℃ for 1000 h.then it shall be subjected to
standard atmospheric conditions for 1h after which
measurement shall be made.
∆F≤+/-5ppm
High
temperature
high humidity
storage
(steady state)
of 40+/-2℃ with relative humidity of 95% for 1000h,
then it shall be subjected to standard atmospheric
conditions for 2h after which measurement shall be
made.
∆F≤+/-5ppm
1
2
3
4
5
6
Thermal Shock
7
Sealing
8
9
Specifications
Test Conditions
High
temperature
Life test
Temperature 1: -55℃±3℃
Temperature 2: 125℃±3℃
Temperature change between T1 and T2 at
soonest
Run 1000 cycles, maintain T1 and T2
5minutes each in one cycle
Helium leakage detector shall used to measure the
leakage rate of gas through any faulty seal.
Pressure:500Kpa, duration:120 minutes .
of 105+/-3℃ for 168h ,then it shall be subjected to
standard atmospheric condition for 1h after which
∆F≤+/-5ppm
Leakage rate≤
1*10-9 Pa.m3 /S
∆F≤+/-5ppm
很抱歉,暂时无法提供与“L32AOC050000PBL”相匹配的价格&库存,您可以联系我们找货
