F322525MUBCE2O
F322525MUBCE2O
    YJX(雅晶鑫)
    SMD3225_4P
    有源晶振 25MHz 1.8V~3.3V-40℃~+85℃ CMOS
F322525MUBCE2O 数据手册
雅晶鑫電子 Shenzhen Yajingxin Electron Co.,Ltd Customer Production Name SMD OSC CMOS Customer P/N SEAM 3.2*2.5 N/A P/N F322525MUBCE2O Revision A Print Date 2023-04-20 Drawn Checked Approved RoHS Compliant 1.Model No 3225 OSC 2.Nominal Frequency 25.000000MHz 3.Mode of Oscillation Fundamental 4.Operating Temperature Range -40℃ to 85 ℃ 5.Storage Temperature Range -55℃ to +125℃ 6.Frequency Stability ±10ppm 7.Power Supply Voltage 1.8V~3.3V 8.Input Current 5mA Max. :25.000000MHZ 9.Output Voltage Logic High(Voh) Logic Low(Vol) 90%Vdd Min 10%Vdd Max 10.Output Load 15pF max CMOS Load 11.Semmetry (at 50%VDD) 40-60%Normal 12.Rise & Fall Time 8ns Max. 13.E/D or N/C. Tri-state 14.Output Disable Time 100nsec 15.Output Enable Time(start-up time) 10msec max 16.Aging ±3ppm/year 17.Unit Weight ■ Dimensions 2 ********************************************************************* 3 ********************************************************************* ■ Marking Line 1: 客户指定印字 Line 2: ■ Measurement Circuit 25.000 MHz Output Wave Form ■ Input Output Condition 4 ********************************************************************* ■ Reflow Profile ■ Reliability Specifications 5 ********************************************************************* No Test Item Test Methods Device are dropped from a height of 75 cm onto 3 mm 1 DROP TEST thickness stainless plate executing 3 times of random drops. Device are shocked to half sine wave (1000 G) three 2 MECHANICAL SHOCK 3 High Temp and Humidity Test 85℃/RH 85%, 500Hrs 4 High temp storage test 125℃+/-2℃ 500Hrs 5 Low temp storage test -40℃ 500Hrs 6 Thermal shock test 7 Aging test 85℃ 500Hrs 8 Resistance to solder heat 260℃ 10S 9 VIBRATION mutually perpendicular axes each 3 times. -40℃~+85℃ DWEL 60' 100cycles Frequency range Amplitude Sweep Sweep Time Test Time 10-2000 Hz 1.5 mm 20 minute 2 hours MIL - STD - 20E Method 208C Temperature Material 10 SOLDERABILITY 245°C±5°C H63A (Silver 2-3 %) Immersion depth 0.5 mm minimum Immersion time 3 ± 0.5 seconds Flux Rosin resin methyl ■ Packing 6 ********************************************************************* 7 ********************************************************************* 8 *********************************************************************
F322525MUBCE2O 价格&库存
很抱歉,暂时无法提供与“F322525MUBCE2O”相匹配的价格&库存,您可以联系我们找货
F322525MUBCE2O
库存:7235
