L327S160Q11L
L327S160Q11L
    LUCKI(蓝晶芯微)
    SMD3225_4P
    16pF , 16MHz , ±20ppm , ±10ppm
L327S160Q11L 数据手册
LUCKI CM ELECTRONICS Co.,Ltd ■ Features - 3.2 x 2.5 x 0.7 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy Ro Hs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specififications LK P/N Nominal Frequency Oscillation Mode Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument L327S160 Q11L 16.000 MHz Fundamental 3rd ±10 ppm -40℃~+85℃/±20ppm 40 Ω 2 pF Max or specify 16 pF 10, 100, 300 μW or specify 500MΩ Min. at DC 100V ± 2 ppm / year Max -40 ~ +125 ℃ S&A 250B system with PI circuit Others ■ Dimensions ( unit: mm) Pin #1 #2 #3 #4 ■ Land pattern (unit: mm) Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND Professional manufacturer of quartz crystal Http://www.lucki.com.cn
L327S160Q11L 价格&库存
很抱歉,暂时无法提供与“L327S160Q11L”相匹配的价格&库存,您可以联系我们找货
