LUCKI CM ELECTRONICS Co.,Ltd
■ Features
- 3.2 x 2.5 x 0.7 MAX. mm of surface mounted quartz crystal units.
- Excellent reliability characteristics such as heat and mechanical shock.
- Pb-free and satisfy Ro Hs requirements.
- Reflow soldering is available.
■ Applications
Digital Electronics, Consumer Products, Mobile Communications,
Bluetooth, Wireless LAN and Automotive
■ Specififications
LK P/N
Nominal Frequency
Oscillation Mode
Frequency tolerance at 25℃
Operating temperature range and frequency stability
Equivalent series resistance
Shunt capacitance
Load capacitance
Drive level (Max.)
Insulation resistance
Aging at 25℃
Storage temperature range
Measure instrument
L327S080 U11
8.000 MHz
Fundamental 3rd
±10 ppm
-40℃~+85℃/±20ppm
200 Ω
2 pF Max or specify
20 pF
10, 100, 300 μW or specify
500MΩ Min. at DC 100V
± 2 ppm / year Max
-40 ~ +125 ℃
S&A 250B system with PI circuit
Others
■ Dimensions ( unit: mm)
Pin
#1
#2
#3
#4
■ Land pattern (unit: mm)
Function
Xtal Terminal (Input)
GND
Xtal Terminal (Output)
GND
Professional manufacturer of quartz crystal
Http://www.lucki.com.cn
很抱歉,暂时无法提供与“L327S080U11L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.74892
- 50+0.59133
- 150+0.51253
- 500+0.45343
- 3000+0.40617
- 6000+0.38250
