HY1325311MSMD3225OB1R30
    HYJG(惠源晶工)
    SMD3225_4P
    无源晶振 13.25311MHz ±10ppm 20pF 80Ω -40℃~+85℃
HY1325311MSMD3225OB1R30 数据手册
中山惠源晶工电子科技有限公司 Zhongshan Huiyuan Crystal Electronic Technology Co., Ltd GENERAL SPECIFICATIONS(电气特性) 1. Series model: (系列号) 2.Normal Frequency: (标称频率) 3.Oscillation Mode: (振动模式) 4.Load Capacitance(CL): (负载电容) 5.Frequency Tolerance 25±3℃: (频率偏差 25±3℃) 6.Stability Over Temperature Range: (工作温度频率偏差) 7.Effective Series Resistance: (等效电阻) SMD3225 8~54MHz ■Fundamental □3rd 20PF ±10PPM ±30 PPM 8~9.84375MHZ≤ 180 Ω 10~11.0592MHZ≤ 120 Ω 12~13.560MHZ≤ 80 Ω 13.598~14.318MHZ≤ 60 Ω 16~54MHZ≤ 40 Ω 8.Shunt Capacitance(C0): ≤ 5 PF (静态电容) 9. Typical drive level: 10 uW TYP. (激励功率) 10.Operation Temperature Range: -40℃ to +85℃ (工作温度范围) 11.Storage Temperature: -40℃ to +85℃ (存储温度) 12.Insulation Resistance: ≥500 MΩ at DC 100V (绝缘阻抗) 13.Aging: ±3 PPM/Year (老化率) 14.Leak 1×10-7Torr.1/sec Max (检漏) 15.Test circuit S&A 250B Pi-Network Crystal Measurement System (测试仪器) Remark(备注): 晶振最佳储存条件:温度:25±5℃,湿度:
HY1325311MSMD3225OB1R30 价格&库存
很抱歉,暂时无法提供与“HY1325311MSMD3225OB1R30”相匹配的价格&库存,您可以联系我们找货
