XC32252712MOB4SA-18
XC32252712MOB4SA-18
    YXC(扬兴科技)
    SMD3225_4P
    无源晶振 27.12MHz ±10ppm 12pF -40℃~+125℃
XC32252712MOB4SA-18 数据手册
print Crystal Unit AEC-Q200 YSX321SC Applications Features ‧Industrial ‧Standard Frequency: 8 ~ 66MHz ‧Automotive ‧Low Impedance Performance ‧Dimensions: 3.20 x 2.50 x 0.70 mm Specifications (规格参数) Item Nominal Frequency Range(额定频率范围) ‧AEC-Q200 Qualified Symbol Specifications - AT Fundamental f_nom Vibration Mode(震动模式) Load Capacitance(负载电容) CL Frequency Tolerance(频率偏差) (at 25℃ ) Frequency Versus Temperature Characteristics(频率-温度特性) Operating Temperature(工作温度) Storage Temperature(储存温度) 8pF, 12pF, or specify f_tol ±10ppm, ±30ppm, or specify T_use -40~+125℃, or specify C0 3pF Max f_tem ±50ppm, or specify T_stg Shunt Capacitance(静态电容) Level of Drive(激励电平) -55~+125℃ DL Aging (老化)(at 25℃ ) 1~200μW Max(100μW typical) f_age Equivalent Series Resistance (等效串联电阻(ESR)) 8 ~ 9.9MHz 800Ω Max 11 ~ 11.9MHz 150Ω Max 10 ~ 10.9MHz 12 ~ 12.9MHz 8 ~ 66MHz YSX321SC 250Ω Max ±2ppm/year Max 13 ~ 15.9MHz 80Ω Max 21 ~ 29.9MHz 60Ω Max 16 ~ 20.9MHz 100Ω Max 30 ~ 66.0MHz Dimensions and Recommended Land Pattern (外观尺寸及推荐焊盘) Dimensions (Unit: mm) 70Ω Max 50Ω Max Recommended Land Pattern (Unit: mm) www.yxc.hk 1
XC32252712MOB4SA-18 价格&库存
很抱歉,暂时无法提供与“XC32252712MOB4SA-18”相匹配的价格&库存,您可以联系我们找货
XC32252712MOB4SA-18
  • 5+1.44256
  • 50+1.14038
  • 150+1.01099
  • 500+0.84942
  • 3000+0.74153
  • 6000+0.69833
库存:3502
