雅晶鑫電子
Shenzhen Yajingxin Electron Co.,Ltd
Customer
Production Name
SMD OSC
Customer P/N
SEAM 3.2*2.5
N/A
P/N
TFOM16M4RWKCNT2T
Revision
A
Print Date
2020-6-16
Drawn
Checked
Approved
RoHS Compliant
1.Model No
3225 OSC
2.Nominal Frequency
16.000MHz
3.Mode of Oscillation
Fundamental
4.Operating Temperature Range
-40℃ to 85 ℃
5.Storage Temperature Range
-55℃ to +125℃
6.Frequency Stability
±50ppm
7.Power Supply Voltage
3.3±10%
10mA Max.
15mA Max.
25mA Max.
60mA Max.
8.Input Current
9.Output Voltage
Logic High(Voh)
Logic Low(Vol)
:1.500- 32.000MHz
:32.001- 50.000MHz
:50.000- 70.000MHz
:70.001- 125.00MHz
90%Vdd Min
10%Vdd Max
10.Output Load
15pF max
CMOS Load
11.Semmetry (at 50%VDD)
40-60%Normal
12.Rise & Fall Time
8ns Max.
13.E/D or N/C.
Tri-state
14.Output Disable Time
100nsec
15.Output Enable Time(start-up time)
10msec
16.Aging
±3ppm/year
max
17.Unit Weight
2
■ Dimensions
3
■ Marking
Line 1: 客户指定印字
Line 2:
■ Measurement Circuit
16.000
MHZ
Output Wave Form
4
■ Input Output Condition
■ Reflow Profile
5
■ Reliability Specifications
No
Test Item
Test Methods
Device are dropped from a height of 75 cm onto 3 mm
1
thickness stainless plate executing 3 times of random
DROP TEST
drops.
Device are shocked to half sine wave (1000 G) three
2
MECHANICAL SHOCK
3
High Temp and Humidity Test
85℃/RH 85%,
4
High temp storage test
125℃+/-2℃
5
Low temp storage test
-40℃
6
Thermal shock test
-40℃~+85℃
7
Aging test
85℃ 500Hrs
8
9
Resistance
to
solder
VIBRATION
heat
mutually perpendicular axes each 3 times.
500Hrs
500Hrs
500Hrs
260℃
DWEL 60' 100cycles
10S
Frequency range
Amplitude Sweep
Sweep Time
Test Time
10-2000 Hz
1.5 mm
20 minute
2 hours
MIL - STD - 20E Method 208C
Temperature
10
SOLDERABILITY
Material
245°C±5°C
H63A (Silver 2-3 %)
Immersion depth
0.5 mm minimum
Immersion time
3 ± 0.5 seconds
Flux
Rosin resin methyl
6
■ Packing
7
8
很抱歉,暂时无法提供与“TFOM16M4RWKCNT2T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.19143
- 50+1.74777
- 150+1.55769
- 500+1.19459
- 3000+1.08897
- 6000+1.02557
