B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China
TEL :+86(0)755-8327-9247
Fax :+86(0)755-8327-9247
http://www.starwavecorp.com
E-mail :info@starwavecorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD GLASS XTAL 5.0*3.2
NOMINAL FREQ.
8.000000MHz
STARWAVE P/N
SWXHHBCVH0-8.000000
REVISION
A1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by STAR after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
RoHS Compliant
FMT-DOC024
Issue Date: 03.09'06 VER.D
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
8.000000MHz
STARWAVE P/N
SWXHHBCVH0-8.000000
REVISION
A1
PE/RD
QA
MFG
04-Dec-23
04-Dec-23
04-Dec-23
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
RoHS Compliant
FMT-DOC024
STARWAVE P/N:SWXHHBCVH0-8.000000 REVISION:
Rev
Revise page
A1
N/A
FMT-DOC024
Revise contents
Initial released
Date
04-Dec-23
Ref.No.
N/A
A1
PAGE: 1
Reviser
Yachuan Miao
A1
PAGE: 2
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by HP E5100A or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.046±0.001 g/pcs
Parameters
1 Nominal Frequency
SYM.
Electrical Spec.
MIN
TYPE
FL
8.000000
MAX
Notes
UNITS
MHz
Fundamental
CL
pF
4 Frequency Tolerance
±20
ppm
at 25 ℃ ± 3 ℃
5 Frequency Tolerance
ppm
Over Operating Temp. Range (Reference 25℃)
6 Operating Temperature
7 Aging
2 Oscillation Mode
3 Load Capacitance
8 Drive Level
DL
±30
-40
85
±3
ppm
10
1st Year
uW
9 Effective Resistance Rr
Rr
100
Ω
10 Shunt Capacitance C0
C0
2
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
105
FMT-DOC024
at DC 100V
A1
PAGE: 3
■ DIMENSIONS
Units:mm
■ MARKING
Frequency(MHz)
ex:12.000=12.000000
Marking
■ SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max.
260
Solder melting point :220 ℃
220
10 sec
180
150
Time (sec)
120 sec
FMT-DOC024
60 sec
A1
PAGE: 4
■ STRUCTURE ILLUSTRATION
NO
COMPONENTS
MATERIALS
QTY
1
FINISH/SPECIFICATIONS
1 Lid
Kovar (Fe/Co/Ni)
2 Base(Package)
Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu 1
Color black
3 PAD
Au
Tungsten metalize
4
+ Ni plating
+ Au plating
4 Crystal blank
SiO2
1
5 Conductive adhesive
Ag
4
Silicon resin
6 Electrode
Ag + Cr
2
FMT-DOC024
A1
PAGE: 5
■ PACKING : (EIA-481-2)
F
E
B
H
G
C
A
DIMENSIONS
D
Feeding
A
B
C
D
E
F
G
H
1.40
5.40
3.60
8.00
12.00
4.00
1.55
1.75
(UNIT : mm)
REMARK :
Trailer
Empty Sealed
Parts
Leader
160mm(Min)
160mm(Min)
230mm(Min)
User direction of feed
W
W1
2.0
L1
DIMENSIONS
FMT-DOC024
L
L
L1
W
W1
pcs / Reel (UNIT : mm)
180
13
16.5
12
Standard Reel Quantity is 1,000 pcs per reel
A1
PAGE: 6
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
Test Item
1.1 Drop Test
Test Methods
REF.DOC
JIS C6701
75 cm height,3 times on concrete floor .
1.2 Mechanical Shock
1.3 Vibration
Device are shocked to half sine wave ( 1000 G ) three mutually
perpendicular axes each 3 times. 0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
MIL-STD-202F
MIL-STD-883E
(Total test time 12 hours)
1.4 Gross Leak
Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm
1.5 Fine Leak
Helium Bombing 4.5 Kgf / cm2 for 2 hr
1.6 Solderability
2
MIL-STD-883E
Temperature
260 ℃ ± 5℃
Immersing depth
0.5 mm minimum
Immersion time
5 ± 1 seconds
Flux
Rosin resin methyl alcohol
MIL-STD-883E
solvent ( 1 : 4 )
2.Environmental Endurance
No.
Test Item
2.1 Resistance To Soldering Heat
Test Methods
Pre-heat temperature
125 ℃
Pre-heat time
60 ~ 120 sec.
Test temperature
260 ± 5 ℃
Test time
10 ± 1 sec.
2.2 High Temp. Storage
+ 125 ℃ ± 3 ℃ for 1000 ± 12 hours
2.3 Low Temp. Storage
- 40 ℃ ± 3 ℃ for 1000 ± 12 hours
REF. DOC
MIL-STD-202F
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
125 ± 3 ℃
2.4 Thermal Shock
MIL-STD-883E
25 ℃
-55 ± 3 ℃
10 min.
10 min.
10 min. max.
2.5 High Temp&Humidity
85℃ ± 3℃ , RH 85% , 1000Hrs
JIS C5023
2.6 Pressure Cooker Storage
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
FMT-DOC024
SWXHHBCVH0-8.000000 价格&库存
很抱歉,暂时无法提供与“SWXHHBCVH0-8.000000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68826
- 50+1.30864
- 150+1.14599
- 1000+0.94306
