凯越翔
深圳市凯越翔电子有限公司
贴片晶振规格书
产品名称:
贴片晶振
产品型号:
5032/16.000 MHZ
产品参数:
20PF/±10ppm
原厂型号:
K5A160002010
凯越翔技术部:
董宗全
客 户 确 认 栏
认 证 印 章
年
月
日
负 责 人 印 章
年
月
日
本规格章程连同本页共 5 页
工厂地址:深圳市龙华新区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823
FAX:0755-89315223 官网:www.kaiyuexiang.com
89315866
深圳市凯越翔实业
1. General item
Nominal frequency: 16.000 MHz
Vibration mode: AT Fund.
Operation temperature range:-40℃~+85℃
Storage temperature rang:-40℃~+85℃
Test machine: S&A 250B
Drive level: 100μW
Load capacitance: 20 pF
2. Electrical characteristics
Condition:25±3℃ Relatively humidity≤60%
2.1 Frequency tolerance: ±10ppm
2.2 Equivalent resistance:≤60Ω
2.3 Temperature characteristics: ±20ppm
2.4 Shunt capacitance:≤7pF
2.5 Insulation resistance:≥500MΩ/100±15V DC
2.6 Aging characteristics: ±5ppm/year
3. Reliability specification
3.1 Drop characteristics
Condition: height 50cm, 3 times, test after 1 hour
Equipment: S&A250B, thickness 3cm hard wood
Standard: frequency change:≤±5ppm, Rr as specification
3.2 Shake characteristics
Condition: shake frequency 10~55Hz, cyc1~2 minutes, swing 1.5mm,
direction x/y/z, all 30 minutes. Test after 1 hour
Equipment: S&A250B, test machine
工厂地址:深圳市龙华区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 89315866 FAX:0755-89315223
深圳市凯越翔实业
3.3 Airproof characteristics
Condition: put crystal into the pressure cabin with alcohol, keep
pressure 0.4-0.5mpa 10 minutes, then take out and blow for 5
minutes
Equipment: IR machine
Standard: IR≥500 mΩ
3.4 Weld characteristics
Condition: 235±5℃、3 seconds
Equipment: test machine
Standard: 90% adhibit tin ok
3.5 Humidity characteristics
Condition:40℃±2℃, humidity 90-95%,250 hours.
Equipment: S&A250B, test cabin
3.6 Low temperature characteristics
Condition: -30℃±2℃, after 250 hours, put in room temperature 1 hour
3.7 High temperature characteristics
Condition: 85℃±2℃, after 250 hours, put in room temperature 1 hour
3.8 Temperature cycling
Condition:
深圳市凯越翔实业
Equipment:S&A250B,test machine。
3.9 Refluence examination
Condition:
Standard: frequency change:≤±10ppm,
Rr as specification
深圳市凯越翔实业
很抱歉,暂时无法提供与“K5A160002010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.59233
- 50+2.05341
- 150+1.82250
- 1000+1.53436
- 2000+1.40606
- 5000+1.32905
