K5A240002020
K5A240002020
    KYX(凯越翔电子)
    SMD5032_4P
    无源晶振 24MHz ±20ppm 20pF
K5A240002020 数据手册
凯越翔 深圳市凯越翔电子有限公司 贴片晶振规格书 产品名称: 贴片晶振 产品型号: 5032/24.000 MHZ 产品参数: 20 PF/±20ppm 原厂型号: K5A240002020 凯越翔技术部: 董宗全 客 户 确 认 栏 认 证 印 章 年 月 日 负 责 人 印 章 年 月 日 本规格章程连同本页共 5 页 工厂地址:深圳市龙华新区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 FAX:0755-89315223 官网:www.kaiyuexiang.com 89315866 深圳市凯越翔实业 1. General item Nominal frequency: 24.000 MHz Vibration mode: AT Fund. Operation temperature range:-40℃~+85℃ Storage temperature rang:-40℃~+85℃ Test machine: S&A 250B Drive level: 100μW Load capacitance: 20 pF 2. Electrical characteristics Condition:25±3℃ Relatively humidity≤60% 2.1 Frequency tolerance: ±20ppm 2.2 Equivalent resistance:≤40Ω 2.3 Temperature characteristics: ±20ppm 2.4 Shunt capacitance:≤7pF 2.5 Insulation resistance:≥500MΩ/100±15V DC 2.6 Aging characteristics: ±5ppm/year 3. Reliability specification 3.1 Drop characteristics Condition: height 50cm, 3 times, test after 1 hour Equipment: S&A250B, thickness 3cm hard wood Standard: frequency change:≤±5ppm, Rr as specification 3.2 Shake characteristics Condition: shake frequency 10~55Hz, cyc1~2 minutes, swing 1.5mm, direction x/y/z, all 30 minutes. Test after 1 hour Equipment: S&A250B, test machine Standard: frequency change:≤±5ppm, Rr as specification 工厂地址:深圳市龙华区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 89315866 FAX:0755-89315223 官网:www.kaiyuexiang.com 深圳市凯越翔实业 3.3 Airproof characteristics Condition: put crystal into the pressure cabin with alcohol, keep pressure 0.4-0.5mpa 10 minutes, then take out and blow for 5 minutes Equipment: IR machine Standard: IR≥500 mΩ 3.4 Weld characteristics Condition: 235±5℃、3 seconds Equipment: test machine Standard: 90% adhibit tin ok 3.5 Humidity characteristics Condition:40℃±2℃, humidity 90-95%,250 hours. Equipment: S&A250B, test cabin Standard: frequency change:≤±5ppm, Rr as specification 3.6 Low temperature characteristics Condition: -30℃±2℃, after 250 hours, put in room temperature 1 hour Equipment: S&A250B, test machine Standard: frequency change:≤±5ppm, Rr as specification 3.7 High temperature characteristics Condition: 85℃±2℃, after 250 hours, put in room temperature 1 hour Equipment: S&A250B, test machine Standard: frequency change:≤±5ppm, Rr as specification 3.8 Temperature cycling Condition: 工厂地址:深圳市龙华区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 89315866 FAX:0755-89315223 官网:www.kaiyuexiang.com 深圳市凯越翔实业 ℃ ℃ ℃ ℃ ℃ ℃ Equipment:S&A250B,test machine。 Standard: frequency change:≤±5ppm, Rr as specification 3.9 Refluence examination Condition: ℃ ℃ ℃ ℃ Equipment: S&A250B, test machine Standard: frequency change:≤±10ppm, Rr as specification 工厂地址:深圳市龙华区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 89315866 FAX:0755-89315223 官网:www.kaiyuexiang.com 深圳市凯越翔实业 工厂地址:深圳市龙华区观澜人民路蔡发工业城 1 栋 4 楼 TEL:0755-89315823 89315866 FAX:0755-89315223 官网:www.kaiyuexiang.com
K5A240002020 价格&库存
很抱歉,暂时无法提供与“K5A240002020”相匹配的价格&库存,您可以联系我们找货
K5A240002020
    • 5+2.59233
    • 50+2.05341
    • 150+1.82250
    • 1000+1.53436
    • 2000+1.40606
    • 5000+1.32905
    库存:14
