8153H-10.000MK33DTL
8153H-10.000MK33DTL
    HCI(杭晶)
    SMD5032_4P
    TCXO 5032 4P 10MHZ CMOS 3.3V ±1.5PPM -40℃~+85℃(±2.5PPM)
8153H-10.000MK33DTL 数据手册
TEMPERATURE COMPENSATED CRYSTAL OSCILLATOR 8153H TCXO UNIT WITH HCMOS SMD 5.0X3.2MM OUTPUT IN CERAMIC SEAM SEAL PACKAGE. PRODUCT FEATURES PRODUCT PHOTO (NOT IN SCALE)  Small dimensions 5.0x3.2x1.1 with 4 solder pads.  Tight stabilities over temperature range.  RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant. APPLICATIONS  WiMAX / WLAN / Ethernet  Telecommunication  Mobil applications PRODUCT SPECIFICATIONS PARAMETER 1.8V SUPPLY VOLTAGE 2.5V 2.8/ 3.0/ 3.3V Frequency range 10 ~ 52MHz REMARKS —- Frequency tolerance ±2.0ppm Initial tol. @+25°C Frequency stability ±0.5ppm / ±1.0; 1.5ppm / ±2.0ppm; ±2.5ppm See note below table Operating temperature range –10 to +70°C / –30 to +85°C / –40 to +85°C Aging per year ±1.0ppm In combination to above stabilities. @+25°C Output waveform and load LVCMOS 15pF Output voltage level HIGH 90%Vcc Minimum Output voltage level LOW 10%Vcc Maximum Rise and Fall times 5ns —- 6ns Symmetry (duty cycle) 8ns 45~55% Phase noise (example 19.2MHz) @ 50%VCC -115dBc/Hz / -135dBc/Hz / -148dBc/Hz Phase jitter RMS
8153H-10.000MK33DTL 价格&库存
很抱歉,暂时无法提供与“8153H-10.000MK33DTL”相匹配的价格&库存,您可以联系我们找货
