1553H-33.333333KWVDTSL
    HCI(杭晶)
    SMD5032_4P
    有源晶振 33.333333MHz ±10ppm 1.8V~3.3V-40℃~+85℃ HCMOS
1553H-33.333333KWVDTSL 数据手册
O S C I L L A T O R U N I T 1553H OSCILLATOR UNIT WITH CMOS OUTPUT IN SMD 5.0X3.2MM CERAMIC SEAM SEAL PACKAGE. PRODUCT PHOTO (NOT IN SCALE) PRODUCT FEATURES  Small dimensions 5.0x3.2x1.2 with 4 solder pads.  Tight stabilities over temperature range.  Tri-state enable/ disable function (pad 1).  Automotive compliance to AEC-Q200 available.  RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant. APPLICATIONS  WiFi / WLAN / Ethernet / GPS  Mobil phone  Notebook  DSC / PDA PRODUCT SPECIFICATIONS PARAMETER Frequency range 1.8V SUPPLY VOLTAGE 2.5V 3.3V 0.137~135MHz 0.137~160MHz 0.137~160MHz Frequency stability ±20ppm / ±25ppm / ±50ppm Operating temperature range ±3.0ppm Supply current 32.768kHz available See note below –10 to +60°C / –20 to +70°C / –40 to +85°C Aging first year REMARKS Options up to +125°C @+25°C 7~15mA 8~18mA 10~20mA 1~40~75MHz @15pF 25mA 30mA 35mA ≥75~135MHz @15pF 40mA 45mA ——Output waveform and load LVCMOS 15pF ≥135MHz @15pF 30pF optional Output voltage level HIGH 1.62V 2.25V 2.97V Minimum Output voltage level LOW 0.18V 0.25V 0.33V Maximum 5ns 5ns 5ns 1~100MHz @10~90% of VCC 3ns 3ns 3ns ≥100MHz @10~90% of VCC Rise and Fall times Symmetry (duty cycle) 45~55% or 40~60% Phase jitter RMS @ 50%VCC
1553H-33.333333KWVDTSL 价格&库存
很抱歉,暂时无法提供与“1553H-33.333333KWVDTSL”相匹配的价格&库存,您可以联系我们找货
