X503221602020B
X503221602020B
    STARWAVE(思大)
    SMD5032_2P
    无源晶振 16MHz ±20ppm 20pF 60Ω -40℃~+85℃
X503221602020B 数据手册
B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD GLASS XTAL 5.0*3.2 NOMINAL FREQ. : 16.000000MHz STARWAVE P/N : X503221602020B REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) STAR requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by STAR after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D B303-30 Tian an Cyber Park ,Huangge North Road ,Longgang District ,Shen Zhen , China TEL :+86(0)755-8327-9247 Fax :+86(0)755-8327-9247 http://www.starwavecorp.com E-mail :info@starwavecorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD GLASS XTAL 5.0*3.2 NOMINAL FREQ. : 16.000000MHz STARWAVE P/N : X503221602020B REVISION : A1 PE/RD 25-Jul-17 QA 25-Jul-17 MFG 25-Jul-17 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 03.09'06 VER.D P/N: X503221602020B Rev Revise page A1 N/A FMT-DOC024 Revise contents Initial released Date 25-Jul-17 REVISION: A1 Ref.No. N/A PAGE: 1 Reviser Yachuan Miao Issue Date: 03.09'06 VER.D P/N: X503221602020B REVISION: A1 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.046±0.001 g/pcs Parameters 1 Nominal Frequency SYM. Electrical Spec. MIN TYPE FL 16.000000 MAX Notes UNITS MHz - - Fundamental - - CL 20 pF - 4 Frequency Tolerance - ±20 ppm at 25 ℃ ± 3 ℃ 5 Frequency Tolerance - ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 2 Oscillation Mode 3 Load Capacitance 8 Drive Level DL ±30 -40 ~ 85 ±3 - ppm 10 - - ℃ 1st Year uW - 9 Effective Resistance Rr Rr - - 65 Ω - 10 Shunt Capacitance C0 C0 - - 2 pF - 11 Insulation Resistance - 500 - - MΩ 12 Storage Temperature Range - -40 ~ 105 ℃ FMT-DOC024 at DC 100V - Issue Date: 03.09'06 VER.D P/N: X503221602020B REVISION: A1 PAGE: 3 ■ DIMENSIONS Units:mm ■ MARKING   Frequency(MHz) ex:12.000=12.000000 Marking ■ SUGGESTED REFLOW PROFILE (℃) Total time : 200 sec. Max. 260 Solder melting point :220 ℃ 220 10 sec 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Date: 03.09'06 VER.D P/N: X503221602020B REVISION: A1 PAGE: 4 ■ STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS QTY 1 FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu 1 Color black 3 PAD Au Tungsten metalize 4 - + Ni plating + Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 4 Silicon resin 6 Electrode Ag + Cr 2 - FMT-DOC024 Issue Date: 03.09'06 VER.D P/N: X503221602020B REVISION: A1 PAGE: 5 ■ PACKING : (EIA-481-2) F E B H G C A DIMENSIONS D Feeding A B C D E F G H 1.40 5.40 3.60 8.00 12.00 4.00 1.55 1.75 (UNIT : mm) REMARK : Trailer Empty Sealed Parts Leader 160mm(Min) 160mm(Min) 230mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L L1 W W1 pcs / Reel (UNIT : mm) 180 13 16.5 12 Standard Reel Quantity is 1,000 pcs per reel Issue Date: 03.09'06 VER.D P/N: X503221602020B A1 REVISION: PAGE: 6 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1.1 Drop Test Test Methods REF.DOC JIS C6701 75 cm height,3 times on concrete floor . 1.2 Mechanical Shock 1.3 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours MIL-STD-202F MIL-STD-883E (Total test time 12 hours) 1.4 Gross Leak Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm 1.5 Fine Leak Helium Bombing 4.5 Kgf / cm2 for 2 hr 1.6 Solderability 2 MIL-STD-883E Temperature 260 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2.1 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2.2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 hours 2.3 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 hours REF. DOC MIL-STD-202F MIL-STD-883E Total 100 cycles of the following temperature cycle 1 cycle 125 ± 3 ℃ 2.4 Thermal Shock MIL-STD-883E 25 ℃ -55 ± 3 ℃ 10 min. 10 min. 10 min. max. 2.5 High Temp&Humidity 85℃ ± 3℃ , RH 85% , 1000Hrs JIS C5023 2.6 Pressure Cooker Storage 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 FMT-DOC024 Issue Date: 03.09'06 VER.D
X503221602020B 价格&库存
很抱歉,暂时无法提供与“X503221602020B”相匹配的价格&库存,您可以联系我们找货
X503221602020B
  • 5+1.50952
  • 50+1.19340
  • 150+1.05797
  • 1000+0.85126
库存:998
