TXM24.576M0004503LDCDO00T
    YJX(雅晶鑫)
    SMD5032_4P
    无源晶振 24.567MHz ±20ppm 20pF 30Ω -40℃~+85℃
TXM24.576M0004503LDCDO00T 数据手册
雅晶鑫 TXM24.576M0004503LDCDO00T ELECTRICAL PARAMETERS 谐振器产品技术指标 1.Holder Type(型号规格) 2.Mode of Oscillation(振动模式) 3.Frequency(标称频率) 4.Load Capacitance (CL)(负载电容) 5.Drive Level(激励功率) 6.Equivalent Resistance(谐振电阻) 7.Shunt Capacitance (Co)(静态电容) 8.Motional Capacitance (C1) (动态电容) 9.Frequency Tolerance at 25℃(调整频差) 10.Stability over operation temperance(温度频差) 11.Insulation Resistance (at DC 100V)(绝缘电阻) 12.Operating Temperature Range(工作温度范围) 13.Storage Temperature Range(储存温度范围) 14.Aging(老化率) 15.DLD2 16.FLD2 N/A 17.RLD2 18.SPDB N/A 19.Other(其它) ● OUTLINE DIMENSIONS(UNIT:mm)外形尺寸(单位:mm) Min Max Units SEAM 5.0*3.2 Fundamental MHZ 24.576000 pF 20 uw 100 Ω 30 pF 0 7 fF N/A ppm -20 20 ppm ± 20 MΩ 500 -40 85 ℃ -40 85 ℃ ±5 ppm/year N/A Ω N/A ppm N/A Ω N/A db N/A
TXM24.576M0004503LDCDO00T 价格&库存
很抱歉,暂时无法提供与“TXM24.576M0004503LDCDO00T”相匹配的价格&库存,您可以联系我们找货
  • 1+0.83533
  • 10+0.66167
  • 30+0.58725
  • 100+0.49443
  • 500+0.45306
  • 1000+0.37898
库存:777
