OT8EL89CJI-111YLC-7.3728M 数据手册
Crystal Oscillator
YSO110TR
Applications
‧Consumer Electronics
Industrial Control
IOT
Wide Voltage
Features
‧Frequency range: 1MHz-54MHz..
‧Package Size: 1.6*1.2, 2.0*1.6
‧Ultra Small SMD seam sealed crystal
oscillator units.
2.5*2.0, 3.2*2.5, 5.0*3.2, 7.0*5.0mm
Specifications(规格参数)
Item
Symbol
Specifications
f₀
1MHz to 54MHz,or specify
Vcc
1.8V~3.3V
CMOS
f_tol
±10ppm,±20ppm,or specify
L_cmos
15pF
Operating Temperature(工作温度)
T_use
-40~+85℃,or specify
Storage Temperature(储存温度)
T_stg
-55~+125℃
Frequency Versus Temperature Characteristics(频率-温度特性)
f_tem
± 20ppm, ± 30ppm, ± 50ppm, or specify
Duty Cycle(占空比)
SYM
45~55%
Start-up Time(启动时间)
t_str
3ms Max.
Rise Time/Fall Time(上升沿/下降沿)
tr/tf
4ns Max
Phase Jitter [12 kHz ~ 20 MHz](相位抖动)
tpj
0.7ps max
f_age
±3ppm/year Max.
Frequency Range(额定频率范围)
Supply Voltage(电源电压)
Output Type(输出方式)
Frequency Tolerance(频率偏差) (at 25℃ )
Output Load(输出负载)
Frequency Aging(老化)(at 25℃ )
Current Consumption(消耗电流)
Power Dissipation Vcc=1.8~3.3V 15pF only
1.000~40.000MHZ
Supply Voltage (V)
1.8V
2.5V
3.3V
41.000~54.000MHZ
7050/5032/3225
2520/2016/1612
7050/5032/3225/2520
2016/1612
4mA max
4.5mA max
5mA max
4mA max
9mA max
10mA max
12mA max
10mA max
Pin Dimension(脚位尺寸)
Pin
#1
#2
#3
#4
FUNCTION
Tri-state
GND
OUTPUT
VDD
*The picture on the right is only for PIN function description.
www.yxc.hk
1
Crystal Oscillator
YSO110TR
Wide Voltage
Dimensions and Recommended land pattern(外观尺寸及推荐焊盘)
Package Size - Dimensions(Unit:mm)
Recommended Land Pattern(Unit:mm)
3.2*2.5mm
www.yxc.hk
2
Crystal Oscillator
YSO110TR
Wide Voltage
Notes:
1.A capacitor value-0.01uf~0.1uf or higher between Vdd and GND is required.
Test Circuit(测试电路)
CMOS
www.yxc.hk
3
OT8EL89CJI-111YLC-7.3728M 价格&库存
很抱歉,暂时无法提供与“OT8EL89CJI-111YLC-7.3728M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.84653
- 10+3.05856
- 30+2.66458
- 100+2.28096
- 500+2.05287
- 1000+1.92845
