TFOM50M4OZKCNT2T
TFOM50M4OZKCNT2T
    YJX(雅晶鑫)
    SMD7050_4P
    停产
TFOM50M4OZKCNT2T 数据手册
雅晶鑫電子 Shenzhen Yajingxin Electron Co.,Ltd Customer Production Name SMD OCSECSC4R Customer P/N SEAM 7.0*5.0 N/A P/N TFOM50M4OZKCNT2T Revision A Print Date 2018-12-15 Drawn Checked Approved RoHS Compliant Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 ■ Electrical Specifications 1.Model No 7050 OSC 2.Nominal Frequency 50.000MHz 3.Mode of Oscillation 3rd 4.Operating Temperature Range -40℃ to85℃ 5.Storage Temperature Range -55℃ to +125℃ 6.Frequency Stability ±50ppm 7.Power Supply Voltage 3.3V±10% 8.Input Current 10mA Max. 15mA Max. 25mA Max. 60mA Max. 9.Output Voltage Logic High(Voh) Logic Low(Vol) :1.500- 32.000MHz :32.001- 50.000MHz :50.000- 70.000MHz :70.001- 125.00MHz 90%Vdd Min 10%Vdd Max 10.Output Load 15pF max CMOS Load 11.Semmetry (at 50%VDD) 40-60%Normal 12.Rise & Fall Time 8ns Max. 13.E/D or N/C. Tri-state 14.Output Disable Time 100nsec 15.Output Enable Time(start-up time) 10msec 16.Aging ±3ppm/year max 17.Unit Weight ********************************************************************** p2/7 Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 ■ Dimensions Pad Connection 1 N.C.(INH) 2 GND 3 OUTPUT 4 VDD ■ Marking 50.000 MHz Line 1: 客户指定印字 Line 2: ********************************************************************** p3/7 Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 ■ Measurement Circuit Output Wave Form ■ Input Output Condition ********************************************************************** p4/7 Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 ■ Reflow Profile ■ Reliability Specifications No Test Item Test Methods Device are dropped from a height of 75 cm onto 3 mm 1 DROP TEST thickness stainless plate executing 3 times of random drops. Device are shocked to half sine wave (1000 G) three 2 MECHANICAL SHOCK 3 High Temp and Humidity Test 85℃/RH 85%, 4 High temp storage test 125℃+/-2℃ 5 Low temp storage test -40℃ 6 Thermal shock test -40℃~+85℃ 7 Aging test 85℃ 1000Hrs mutually perpendicular axes each 3 times. 500Hrs 500Hrs 500Hrs DWEL 60' 100cycles ********************************************************************** p5/7 Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 8 Resistance 9 to solder VIBRATION heat 260℃ 10S Frequency range Amplitude Sweep Sweep Time Test Time 10-2000 Hz 1.5 mm 20 minute 2 hours MIL - STD - 20E Method 208C Temperature 10 SOLDERABILITY Material 245°C±5°C H63A (Silver 2-3 %) Immersion depth 0.5 mm minimum Immersion time 3 ± 0.5 seconds Flux Rosin resin methyl ■ Packing A0:5.40±0.1 P0: 4.0±0.1 F: 7.50±0.1 B0:7.40±0.3 P : 8.0±0.1 K0:1.90±0.1 W:16.2±0.3 P2: 2.0±0.1 E1:1.75±0.1 D: phi 1.50±0.1 ********************************************************************** p6/7 Shenzhen Yajingxin Electron Co.,Ltd Tel:+86-755-83657231 +86-755-83657232 移动:138-0255-9153 ■ Reel Dimension A: phi 180±1.0 E: 1.9±0.5 NOTE: 1. packgeing q’ty B: phi 60±1.0 W: 25.5+1.0 C: phi 13.0±0.5 D: phi 12.0±1.0 1000PCS /REEL ********************************************************************** p7/7
TFOM50M4OZKCNT2T 价格&库存
很抱歉,暂时无法提供与“TFOM50M4OZKCNT2T”相匹配的价格&库存,您可以联系我们找货
