VOLTAGE
CRYSTAL
CONTROLLED
OSCILLATOR
V175H
VCXO UNIT
WITH
HCMOS
SMD 7.0X5.0MM
OUTPUT IN
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 7.0x5.0x1.7 with 6 solder pads.
Tight stabilities over temperature range.
Tristate enable/ disable function (pad 2).
RoHS compliant, LEAD-FREE, HALOGEN-FREE and REACH compliant.
APPLICATIONS
WiMAX / WLAN / Ethernet
DSL / VoIP
Cable modem
Set-top box / HDTV
PRODUCT SPECIFICATIONS
PARAMETER
1.8V
SUPPLY VOLTAGE
2.5V
Frequency range
3.3V
15 ~ 250MHz
Frequency stability
±20ppm / ±25ppm / ±30ppm / ±50ppm
Operating temperature range
–10 to +60°C / –20 to +70°C / –40 to +85°C
Aging first year
±3.0ppm
Frequency pulling range
See note below
Options available
@+25°C
±50ppm ~ ±250ppm
Supply current
REMARKS
Depending on frequency
10mA
1.5~15MHz @15pF
40mA
50mA
20~30mA
≥15~80MHz @15pF
70mA
80mA
40~90mA
≥80MHz @15pF
Output waveform and load
LVCMOS 15pF
30pF optional
Output voltage level HIGH
1.62V
2.25V
2.97V
Minimum
Output voltage level LOW
0.18V
0.25V
0.33V
Maximum
4ns
4ns
5ns
1~50MHz @10~90% of VCC
2ns
2ns
3ns
≥50MHz @10~90% of VCC
Rise and Fall times
Symmetry (duty cycle)
40~60% or 45~55%
Phase jitter RMS
@ 50%VCC
V175H-50.000K33DTJL 价格&库存
很抱歉,暂时无法提供与“V175H-50.000K33DTJL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 型号:V175H-50.000K33DTJL
- 品牌:HCI(杭晶)
- 封装:SMD7050_6P
- 描述:高频,低相噪,VCXO,封装:7050,6P,频率:50MHz,输出模式:HCMOS,工作电压:3.3V,总频差:±25ppm,工作温度:-40℃~+85℃,牵引范围>±80ppm
- 国内价格
- 1+18.53982
- 10+15.79014
- 30+14.14854
- 100+13.52268
- 500+12.76344
- 1000+12.41460
