O
OSCILLATOR UNIT
WITH
LVPECL
OUTPUT IN
S C I L L A T O R
U
N I T
1575P
SMD 7.0X5.0MM
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 7.0x5.0x1.6 with 6 solder pads.
Highly reliable seam sealed ceramic package.
Wide frequency range.
Low jitter and phase noise.
RoHS compliant, LEAD-FREE and HALOGEN-FREE.
APPLICATIONS
High speed communication
Telecom equipment
Handheld equipment
PRODUCT SPECIFICATIONS
1575P
PARAMETER
Nominal frequency range
CONDITIONS / REMARKS
10 ~ 800MHz
Supply voltage
2.5VDC
Supply current
Fund., Overtone or PLL
3.3VDC
Other option possible
100mA
Frequency stability
±25ppm
Operating temperature range
±50ppm
Maximum, Fund mode lower ICC
±100ppm
–10 to +70°C or –40 to 85°C
Output waveform and load
LVPECL
50Ω
See note below.
Other options available.
Into VCC–2
Output voltage level HIGH
VCC–1.025V
VCC–0.880V
Minimum / Maximum
Output voltage level LOW
VCC–1.810V
VCC–1.620V
Minimum / Maximum
Rise and Fall times
1.5ns
Symmetry (duty cycle)
@ 20~80~20%VCC
45~55%
Phase Jitter RMS
@ outputs cross point
很抱歉,暂时无法提供与“1575P-62.500K33DTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.35180
- 10+15.68895
- 30+14.10912
- 100+12.50943
- 500+11.77416
- 1000+11.43634
