O
OSCILLATOR UNIT
WITH
LVDS
OUTPUT IN
SMD 7.0X5.0MM
S C I L L A T O R
U
N I T
1575D
CERAMIC SEAM SEAL PACKAGE.
PRODUCT FEATURES
PRODUCT PHOTO
(NOT IN SCALE)
Small dimensions 7.0x5.0x1.6 with 6 solder pads.
Highly reliable seam sealed ceramic package.
Wide frequency range.
Low jitter and phase noise.
RoHS compliant, LEAD-FREE and HALOGEN-FREE.
APPLICATIONS
High speed communication
Telecom equipment
Handheld equipment
PRODUCT SPECIFICATIONS
1575D
PARAMETER
Nominal frequency range
CONDITIONS / REMARKS
10 ~ 800MHz
Supply voltage
2.5VDC
Supply current
Fund., Overtone or PLL
3.3VDC
Other option possible
100mA
Frequency stability
±25ppm
Operating temperature range
Maximum, Fund mode lower ICC
±50ppm
±100ppm
–10 to +70°C or –40 to 85°C
Output waveform and load
LVDS
100Ω
See note below.
Other options available.
RL between outputs
Output voltage level HIGH
1.40V
Typical
Output voltage level LOW
1.10V
Typical
Rise and Fall times
1.5ns
@ 20~80~20%VCC
Symmetry (duty cycle)
45~55%
Phase Jitter RMS
@ outputs cross point
1575D-122.880G33DTL 价格&库存
很抱歉,暂时无法提供与“1575D-122.880G33DTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.49090
- 10+15.64920
- 30+13.87066
- 100+12.04244
- 500+11.21775
- 1000+10.86999
