S603527.120M10PF20PPM 数据手册
四川索斯特电子有限公司
Sichuan Source-Set Electronics Co., Ltd
承 认 书
SPECIFICATIONS FOR APPROVAL
客户名称:
Customer
产品名称:
石英晶体谐振器
Description:
CRYSTAL RESONATOR
产品型号:
6035 27.120M 10PF 20PPM
SPECIES
标称频率:
FREQUENC
料
27.120MHz
号:
MATERIAL CODE
供应商确认
品管部
QC Dept
工程部
Engineer
Dept
业务部
Trade
Dept
莫
梁
陈
平
雄
晓
会
客户确认
群
合格 PASS
不合格 NG
品管部
工程部
采购部
QC Dept
Engineer
Purchase
Dept
Dept
合格 PASS
不合格 NG
公司地址:四川省泸州市泸县工业园 B 区明星路 204 号(坤羽)五、六栋
电话:0830-8172777、0830-8106299
传真:0830-8106266
1
四川索斯特电子有限公司
GENERAL SPECIFICATIONS(电气特性):
No.
Parameters
1
Nominal Frequency
2
Overtone order
3
Frequency Tolerance
4
Operating Temperature
Range
5
Frequency Stability
6
Storage Temperature
7
Load capacitance
8
Equivalent resistance
9
Level of drive
Symb.
Electrical Specification
Min.
F0
Typ.
Notes
Max. Units
27.12000
MHz
Fundamental
ppm at 25℃±3℃
△F/F0
-20
+20
TOPR
-40
+85
TC
-30
+30
ppm
TSTG
-55
+150
CL
10
pF
ESR
40
Ω
DL
100
300
μW
500
MΩ DC100V ±15V.
pF
10 Insulation Resistance
11 Shunt Capacitance
C0
7
12 Aging Per Year
Fa
-3
+3
13 Package type
The reference temperature
shall be +25°C
ppm First Year
6035 seam
2
四川索斯特电子有限公司
DIMENSIONS SPECIFICATIONS(外形尺寸)
#4
1
#3
1
27.120
MHZ
#1
#2
1
3
四川索斯特电子有限公司
Tape Dimensions(unit : mm)
E
D
A
B
C
F
A
B
C
D
E
F
1.50
4.0
8.0
5.5
12.0
1.5
Reel Dimensions(unit: mm)
J
G
K
H
I
M
L
G
H
I
J
K
L
M
2.5
13.5
21.6
60.0
178
13.5
1.6
*1000pcs/Reel
4
四川索斯特电子有限公司
No.
1
Test Item
Test Conditions
Spec Code
High Temperature
Storage
Temperature: 125℃±5℃
Time:
1000±12 Hours
A
Temperature 1: -55℃±5℃
Temperature 2: 125℃±5℃
2
Temperature Cycle
Temperature change between T1 and T2 at soonest
Run 1000 cycles, maintain T1 and T2 30 minutes each
in one cycle
A
3
High Temperature,
High Humidity
Storage
Temperature: 85℃±5℃
Relative Humidity: 80%--85%
Time: 250Hours±24 Hours
A
4
Steam Aging
Temperature: 97℃±5℃; Time: 24 Hours
260℃ solder pot to check solderability
A
Pre-heat temperature: +150±10℃
Pre-heat time:60~120s
When the temperature of the specimen is reached
5
Solderability
at+215±3℃, it shall be left for 30±1sec.
B
Peak temperature 240±5℃
Material: Pb-free (Sn-3.0Ag-0.5Cu)
6
7
8
Flux: Rosin resin methyl alcohol solvent (1: 4)
Temperature: 85℃±5℃; Time: 250±12Hours
Aging
A
Drop Test
Preparation: Test pieces should be fixed on the
dummy load with 200g weight.
Condition: Height 1.5m onto concrete
Drop times :10 times in 6 mutually perpendicular axes
A
Vibration
Frequency Range: 10Hz~2000Hz
Amplitude:
1.5mm or 20G
4Hours in each direction, total 12Hours
A
Pre-heat temperature : +150~180℃
Pre-heat time: 90±30s
9
Reflow resistance
Heat temperature : more than +230℃
Heat time: 30s ±10s
A
Peak temperature : +260±5℃
Peak time: less than 10s
Specification code
A
B
Specification
∆f/f ≤±3 ppm
∆CI/CI ≤±15 % or 5 Ωmake use larger value
The electrodes should be covered by a new solder at least 90% of
immersed area.
5
S603527.120M10PF20PPM 价格&库存
很抱歉,暂时无法提供与“S603527.120M10PF20PPM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.14280
- 10+2.49480
- 30+2.21400
- 100+1.86840
