AH03270014
AH03270014
    TXC(台晶)
    SMD3215_2P
    无源晶振 32.768kHz ±10ppm 12.5pF 70kΩ -40℃~+85℃
AH03270014 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CN: CUSTOMER : PRODUCT TYPE : SMD TUNING FORK 3.2X1.5 NOMINAL FREQ. : 32.768KHz TXC P/N : AH03270014 REVISION : A1 CUSTOMER P/N : PM / SALES : DATE : 0 CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC015 Halogen Free RoHS Compliant Issue Date: 03.18'14 VER.B TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET CN: PRODUCT TYPE : SMD TUNING FORK 3.2X1.5 NOMINAL FREQ. : 32.768KHz TXC P/N : AH03270014 REVISION : A1 RD QA MFG Robin Huang Samson Xiong Jake Liu 23-Nov-15 23-Nov-15 23-Nov-15 NOTE: (1)The green product standard set by TXC is based upon the international standards. Related information is publicly described on the TXC's Website, and updated regularly. The document is compliant with the latest green product quality system directives at the time. (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required Halogen Free RoHS Compliant FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION Rev Revise page S1 NA Initial release A1 NA S Turn A FMT-DOC015 TXC P/N: AH03270014 Revise contents REVISION: A1 PAGE: 1 Date Ref.No. Reviser 2-Jul-15 - Xiaoyan Jiang 23-Nov-15 - Xiaoyan Jiang Issue Date: 03.18'14 VER.B TXC P/N: AH03270014 TXC CORPORATION REVISION: A1 PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Parameters Sym. 1 Nominal Frequency Electrical Spec. Min F0 2 Frequency Tolerance Typical Max Notes Unit 32.768 KHz - ∆f/fo ± 10 ppm 3 Load Capacitance CL 12.5 pF - 4 Driver Level DL - 0.1 0.5 μW - ESR - - 70 KΩ at 25 ℃ ±3℃ 6 Turnover Temperature Tp 20 25 30 ℃ at 25 ℃ ±5℃ 7 Parabolic Curvature Constant K - - -0.04 8 Operating Temperature - -40 ~ 85 5 Equivalent Series Resistance at 25 ℃ ±3℃ ppm/℃2 ℃ - 9 Storage Temperature - -40 ~ 125 ℃ - 10 Insulation Resistance IR 500 - - MΩ at DC 100V±15V 11 Shunt Capacitance C0 - 1 - pF - 12 Aging ∆f/f ■ DIMENSIONS ±3 ppm 1st Year ■ RECOMMENDED SOLDER PAD (UNIT:mm) (UNIT:mm) 0.65 1.50 ± 0.10 1.50 ± 0.10 3.20 ± 0.10 1.70 ± 0.10 1.8 0.75 ± 0.10 1.0 ■ SUGGESTED REFLOW PROFILE 1.5 1.0 ■ TEMPERATURE V.S FREQENCY CURVE Total time : 200 sec. Max. -40 Solder melting point :220℃ (℃) 25 85 TEMP (oC) 10 sec 260 220 -130 180 150 △f/fo(ppm) Time (sec) 120 sec FMT-DOC015 60 sec Issue Date: 03.18'14 VER.B TXC P/N: AH03270014 TXC CORPORATION REVISION: A1 PAGE: 3 ■ MARKING TXC Use Frequency/CL Code Frequency /CL Code Date Code KHz PF CODE 32.768 12.5 A 32.768 7.0 B 32.768 9.0 C 32.768 6.0 D 32.768 7.6 E XXXXX TXC Use Code Date Code MONTH JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC YEAR 2001 2005 2009 2013 2017 A B C D E F G H J K L M 2002 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2003 2007 2011 2015 2019 a b c d e f g h j k l m 2004 2008 2012 2016 2020 n p q r s t u v w x y z This date code will be cycled every four years ■ PACKING Ao= 1.8±0.10 mm Bo= 3.5±0.10 mm L L1 Ko= 0.87±0.10 W1 W CARRIER TAPE DIMENSIONS REEL DIMENSIONS REMARK : 1. K1 P0 P1 P2 D0 D1 – 4 4 2 E F 10P0 W 1.55 1.1 1.75 5.5 W W1 16±1.4 13±0.3 L 40 T pcs / Reel 12 0.25 3K L1 180+0/-3 60.2±0.5 230 mm (9.05) minimum leader which consist of carrier and/or tape followed by a minimum of 160 mm (6.3) of empty carrier tape sealed with cover tape. 2. FMT-DOC015 160 mm (6.3) minimum trailer of empty carrier tape sealed with cover tape. Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AH03270014 REVISION: A1 PAGE: 4 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Label B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AH03270014 REVISION: A1 PAGE: 5 ■ STRUCTURE ILLUSTRATION 1 4 6 2 5 NO 1 Lid 3 COMPONENTS MATERIALS FINISH/SPECIFICATIONS Kovar(Fe+Co+Ni) Alloy - 2 Base(Package) Ceramic(AI2O3) Alumina Ceramics 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal chip SiO2 - 5 Conductive adhesive Ag Silicon resin 6 Electrode Au+Cr - ■ UNIT WEIGHT: 0.01197g/pcs FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AH03270014 REVISION: A1 PAGE: 6 ■ RELIABILITY SPECIFICATIONS (AEC-Q200 Compliant) 1.Mechanical Endurance No. Test Item 1 Drop Test Test Methods REF. DOC MIL-STD-202 150 cm height, fall freely onto concrete floor 3 times. 1 Mechanical Shock 1 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm,20G Sweep time 20 minute Perpendicular axes each test time 4 hours MIL-STD-202 MIL-STD-883 (Total test time 12 hours) 1 Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol MIL-STD-883 solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Item 2 Resistance To Soldering Heat Test Methods Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. REF. DOC MIL-STD-202 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 hours MIL-STD-883 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 hours MIL-STD-883 2 Temperature cycling -40°C to 125°C ,10min dwell time at each temperature extreme. 1 min. maximum transition time.1000cycles. MIL-STD-883 3 Pressure Cooker Storage 121 ± 3℃, RH100%, 2 bar, for 240 hours EIA-JESD22 3 High Temp&Humidity 85℃ ± 3℃, RH 85% , 1000Hrs EIA-JESD22 FMT-DOC015 Issue Date: 03.18'14 VER.B TXC CORPORATION TXC P/N: AH03270014 REVISION: A1 PAGE: 7 ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Re-solder times: twice ■ FACTORY LOCATION TXC (NINGBO) CORPORATION NO.189 Huang Shan West Road, Beilun District, Ningbo Zhejiang China FMT-DOC015 Issue Date: 03.18'14 VER.B
AH03270014 价格&库存
很抱歉,暂时无法提供与“AH03270014”相匹配的价格&库存,您可以联系我们找货
