AMS1117
0 . 8 A LOW DROPOUT VOLTAGE REGULATOR
Description
Features
The AMS1117 is a series of low dropout voltage
Low Dropout Voltage.
regulators which can provide up to 0.8A of output
Load regulation: 0.5% Max.
current. The AMS1117 is available in six fixed
Optimized for Low Voltage
voltage, 1.2, 1.5, 1.8, 2.5, 3.3 and 5.0V. Additionally
On-chip thermal limiting.
it is also available in adjustable version. On chip
Maximum Input Voltage : 18V
precision trimming adjusts the reference/ output
Adjustable Output Voltage or Fixed 1.2V,
voltage to within ± 2%. On-chip thermal limiting
1.5V, 1.8V, 2.5V, 3.3V,5V
provides protection against any combination of
overload and ambient temperatures that would
Standard SOT-223,TO-252 ,SOT89
Packages
create excessive junction temperatures.
Applications
The AMS1117 series is available in SOT-223, TO-
Post Regulator for switching DC/DC
Converter
252, SOT89 packages. A minimum of 10uF
tantalum capacitor is required at the output to
High Efficiency Linear Regulator
improve the transient response and stability.
Battery Chargers
PC Add on Card
Motherboard clock supplies
LCD Monitor r
Set-top Box
Block Diagram
www.slkormicro.com
1
AMS1117
Pin Description
Absolute Maximum Ratings
Symbol
VIN
IOUT
TJ
Description
Input Voltage
Max
18
DC Output Current
Operating Junction Temperature Range
Units
V
PD/(VIN-VOUT)
mA
-40 to 125
θ JA
Thermal Resistance (SOT-223)
150
℃/W
θ JA
Thermal Resistance (TO-252)
125
℃/W
θ JA
Thermal Resistance (SOT89)
225
℃/W
PD
Maximum Power Dissipation (SOT-223)
600
mW
PD
Maximum Power Dissipation (TO-252)
900
mW
PD
Maximum Power Dissipation (SOT89)
400
mW
www.slkormicro.com
2
AMS1117
Electrical Characteristics (Vin = 11μF.
www.slkormicro.com
5
AMS1117
Load Regulation
When the adjustable regulator is used (Fig.2), the best load regulation is accomplished when the top
of the resistor divider (R1) is connected directly to the output pin of the AMS1117. When so connected,
RP is not multiplied by the divider ratio. For Fixed output version, the top of R1 is internally connected to
the output and ground pins can be connected to low side of the load
Figure 2. Best Load Regulation Using Adjustable Output Regulator
Thermal Protection
AMS1117 has thermal protection which limits junction temperature to 150 ℃ . However, device
functionality is only guaranteed to a maximum junction temperature of +125℃. The power dissipation
and junction temperature for AMS1117 in DPAK package are given by
PD = (VIN – VOUT) * Iout
TJUNCTION = TAMBIENT + (PD * θ
JA)
Note: TJUNCTION must not exceed 125℃
Thermal Consideration
The AMS1117 series contain thermal limiting circuitry designed to protect itself from overtemperature conditions. Even for normal load conditions, maximum junction temperature ratings must
not be exceeded. As mention in thermal protection section, we need to consider
all sources of thermal
resistance between junction and ambient. It includes junction-to case, case-to-heat-sink interface, and
heat sink thermal resistance itself.
Junction-to-case thermal resistance is specified from the IC junction to the bottom of the case directly
below the die. Proper mounting is required to ensure the best possible thermal flow from this area of the
package to the heat sink. The case of all devices in this series is electrically connected to the output.
Therefore, if the case of the device must be electrically isolated, a thermally conductive spacer is
recomme
www.slkormicro.com
6
AMS1117
PACKAGE DESCRIPTION
SOT-223 PACKAGE OUTLINE DIMENSIONS
Dimensions ln Millimeters
Dimensions ln lnches
Symbol
Min
Max
Min
Max
A
1.520
1.800
0.060
0.071
A1
0.020
0.130
0.001
0.005
A2
1.500
1.700
0.059
0.067
b
0.660
0.840
0.026
0.033
c
0.230
0.350
0.009
0.014
D
6.450
6.850
0.254
0.270
D1
2.900
3.000
0.114
0.122
E
3.450
3.850
0.136
0.152
E1
6.830
7.070
0.269
0.278
e
0.091(BSC)
e1
4.500
4.700
0.177
0.185
L
0.900
1.150
0.035
0.045
θ
0°
10°
www.slkormicro.com
2.300(BSC)
7
0°
10
AMS1117
TO-252-2L PACKAGE OUTLINE DIMENSIONS
Symbol
Min
Max
Min
Max
2.400
0.087
0.094
A
2.200
A1
0.000
0.127
0.000
0.005
B
1.200
1.650
0.047
0.065
b
0.500
0.810
0.020
0.032
b1
0.700
0.900
0.028
0.035
c
0.460
0.580
0.018
0.023
c1
0.430
0.580
0.014
0.023
D
6.350
6.700
0.250
0.264
D1
5.200
5.400
0.205
0.213
E
5.400
6.200
0.213
0.244
e
2.300TYP
0.0901TYP
e1
4.500
4.700
0.177
0.185
L1
9.500
9.900
0.374
0.390
L2
0.950
1.600
0.037
0.063
L3
0.700
1.100
0.028
0.043
L4
2.550
2.900
0.100
0.114
V
www.slkormicro.com
3.80REF
8
0.150REF
AMS1117
SOT89 PACKAGE OUTLINE DIMENSIONS
Symbol
Min
Max
Min
Max
A
1.400
1.600
0.055
0.063
b
0.350
0.520
0.013
0.197
b1
0.400
0.580
0.016
0.023
c
0.350
0.450
0.014
0.018
D
4.400
4.600
0.173
0.181
D1
1.550
1.750
0.061
0.069
E
2.350
2.600
0.091
0.102
E1
3.720
4.530
0.146
0.178
e
1.500TYP
0.060TYP
e1
3.000TYP
0.118TYP
L
www.slkormicro.com
0.820
1.100
9
0.032
0.047
很抱歉,暂时无法提供与“AMS1117-3.3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31720
- 100+0.25488
- 300+0.22378
- 1000+0.17594
- 5000+0.15736
- 10000+0.14796
- 国内价格
- 10+0.29076
- 100+0.23364
- 200+0.23014
- 400+0.20513
- 1000+0.16127
- 国内价格
- 1+0.15290
- 1000+0.13750
