MIC29302WU
High- Current Low- Dropout Adjustable Regulator
General Description
The MIC29302WU is a high current, high accuracy and low-dropout voltage
regulator. This regulator features 300mV to 370mV (full load) dropout voltage
and very low ground current. Designed for high current load, the device also
finds applications in lower current, extremely low dropout-critical systems,
where its tiny dropout voltage and ground current value are important attributes.
TO263-5L
The MIC29302WU is fully protected against over-current fault, reversed input polarity, reversed lead insertion,
over-temperature operation, and positive and negative transient voltage spikes.
On the MIC29302WU , the ENABLE pin may be tied to VIN if it is not required for ON/OFF control.
The MIC29302WU is available in TO263-5L package.
Features
l
High Current Capability of 3A
l
Low-Dropout Voltage of 350mV at Full Load
l
Low Ground Current
l
Accurate 1% Guaranteed Tolerance
l
Extremely Fast Transient Response
l
Reverse-Battery and “Load Dump” Protection
l
Zero-Current Shutdown Mode
l
Also Characterized For Smaller Loads with Industry-Leading Performance Specifications
l
Adjustable Version
Applications
l
Battery Powered Equipment
l
High-Efficiency “Green” Computer Systems
l
Automotive Electronics
l
High-Efficiency Linear Power Supplies
l
High-Efficiency Post-Regulator for Switching Supply
www.slkormicro.com
1
MIC29302WU
Functional Block Diagram
Pin Configuration
Pin Description
Pin Number
Pin Name
Function Description
1
EN
Enable pin
2
VIN
Power supply
3
GND
Ground
4
VOUT
Output
5
ADJ
Adjustable pin
www.slkormicro.com
2
MIC29302WU
Absolute Maximum Ratings
Parameter Name
Symbol
Value
Unit
PD
Internally Limited
-20~+50
V
260
-40~+125
Power Dissipation
Input Supply Voltage (*1)
Lead Temperature (soldering, 5 seconds)
Operating Junction Temperature
VIN
TLEAD
TOPR
Storage Temperature Range
TSTG
-55~+150
θJC
2
℃/W
Thermal Resistance(JC)
* 1: Maximum positive supply voltage of 50V must be of limited duration (
很抱歉,暂时无法提供与“MIC29302WU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.39800
- 10+6.11280
- 30+5.41080
- 100+4.61160
- 500+4.19040
- 800+4.02840
