D2632
High-Current Low-Dropout Adjustable Regulator
General Description
The D2632 is a high current, high accuracy and low-dropout voltage
regulator. This regulator features 300mV to 370mV (full load) dropout voltage
and very low ground current. Designed for high current load, the device also
finds applications in lower current, extremely low dropout-critical systems,
TO263-5L
where its tiny dropout voltage and ground current value are important attributes.
The D2632 is fully protected against over-current fault, reversed input polarity, reversed lead insertion,
over-temperature operation, and positive and negative transient voltage spikes.
On the D2632, the ENABLE pin may be tied to VIN if it is not required for ON/OFF control.
The D2632 is available in TO263-5L package.
Features
High Current Capability of 3A
Low-Dropout Voltage of 350mV at Full Load
Low Ground Current
Accurate 1% Guaranteed Tolerance
Extremely Fast Transient Response
Reverse-Battery and “Load Dump” Protection
Zero-Current Shutdown Mode
Also Characterized For Smaller Loads with Industry-Leading Performance Specifications
Adjustable Version
Applications
Battery Powered Equipment
High-Efficiency “Green” Computer Systems
Automotive Electronics
High-Efficiency Linear Power Supplies
High-Efficiency Post-Regulator for Switching Supply
Shaoxing silicore technology Co.,Ltd.
www. silicore. com. cn
CHMC
Jun. 2015 Rev. 1.0
Page 1 of 11
D2632
Functional Block Diagram
Pin Configuration
Pin Description
Pin Number
Pin Name
Function Description
1
EN
Enable pin
2
VIN
Power supply
3
GND
Ground
4
VOUT
Output
5
ADJ
Adjustable pin
Shaoxing Silicore Technology Co.,Ltd.
CHMC
Jun. 2015 Rev. 1.0
Page 2 of 11
D2632
Absolute Maximum Ratings
Parameter Name
Symbol
Value
Power Dissipation
PD
Internally Limited
Input Supply Voltage (*1)
VIN
-20~+50
V
Lead Temperature (soldering, 5 seconds)
TLEAD
260
Operating Junction Temperature
TOPR
-40~+125
Storage Temperature Range
TSTG
-55~+150
θJC
2
℃/W
Thermal Resistance(JC)
Unit
* 1: Maximum positive supply voltage of 50V must be of limited duration (
很抱歉,暂时无法提供与“D2632-ADJ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.71960
- 10+3.87720
- 50+3.14280
- 100+2.72160
- 500+2.47320
- 1000+2.34360
