LM29302AS/TR
LM29302AS/TR
    HGSEMI(华冠)
    TO-263-5
LM29302AS/TR 数据手册
LM29xxxA LM29152/29302/29502/29752 High-Current Low-Dropout Regulators General Description Features The LM29150/29300/29500/29750 are high current, high accuracy, low-dropout voltage regulators. Using proprietary Super β eta PNP® process with a PNP pass element, these regulators feature 350mV to 425mV (full load) typical dropout voltages and very low ground current. Designed for high current loads, these devices also find applications in lower current, extremely low dropout-critical systems, where their tiny dropout voltage and ground current values are important attributes. The LM29150/29300/29500/29750 are fully protected against overcurrent faults, reversed input polarity, reversed lead insertion, overtemperature operation, and positive and negative transient voltage spikes. Five pin fixed voltage versions feature logic level ON/OFF control and an error flag which signals whenever the output falls out of regulation. Flagged states include low input voltage (dropout), output current limit, overtemperature shutdown, and extremely high voltage spikes on the input. On the 29xx1 and 29xx2, the ENABLE pin may be tied to VIN if it is not required for ON/OFF control. The LM29150/29300/29500 are available in 3-pin and 5-pin TO-220 and surface mount TO-263 (D2Pak) packages. The 29750 7.5A regulators are available in 3-pin and 5-pin TO-247 packages. The 1.5A, adjustable output 29152 is available in a 5-pin power D-Pak (TO-252) package. For applications with input voltage 6V or below, see HGSEMI LDOs. • High current capability LM29150/29151/29152/29153.................................1.5A LM29300/29301/29302/29303.................................... 3A LM29500/29501/29502/29503.................................... 5A • Low-dropout voltage • Low ground current • Accurate 1% guaranteed tolerance • Extremely fast transient response • Reverse-battery and “Load Dump” protection • Zero-current shutdown mode (5-pin versions) • Error flag signals output out-of-regulation (5-pin versions) • Also characterized for smaller loads with industryleading performance specifications • Fixed voltage and adjustable versions Applications • • • • • Battery powered equipment High-efficiency “Green” computer systems Automotive electronics High-efficiency linear lower supplies High-efficiency lost-regulator for switching supply _________________________________________________________________________________________________________________________ Typical Application** LM29152 LM29300-3.3 Adjustable Output Voltage Fixed Output Voltage (*See Minimum Load Current Section) http://www.hgsemi.com.cn 1 2021 DEC LM29xxxA ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM29150T-XX TO220-3L LM29150-XX TUBE 1000pcs/box LM29300T-XX TO220-3L LM29300-XX TUBE 1000pcs/box LM29500T-XX TO220-3L LM29500-XX TUBE 1000pcs/box LM29150S-XX/TR TO263-3L LM29150-XX REEL 500pcs/reel LM29300S-XX/TR TO263-3L LM29300-XX REEL 500pcs/reel LM29152DT/TR TO252-5L LM29152 REEL 2000pcs/reel LM29151T-XX TO220-5L LM29151-XX TUBE 1000pcs/box LM29301T-XX TO220-5L LM29301-XX TUBE 1000pcs/box LM29501T-XX TO220-5L LM29501-XX TUBE 1000pcs/box LM29751T-XX TO220-5L LM29751-XX TUBE 1000pcs/box LM29151S-XX/TR TO263-5L LM29151-XX REEL 500pcs/reel LM29301S-XX/TR TO263-5L LM29301-XX REEL 500pcs/reel LM29501S-XX/TR TO263-5L LM29501-XX REEL 500pcs/reel LM29751S-XX/TR TO263-5L LM29751-XX REEL 500pcs/reel LM29152T TO220-5L LM29152 TUBE 1000pcs/box LM29302AT TO220-5L LM29302A TUBE 1000pcs/box LM29502T TO220-5L LM29502 TUBE 1000pcs/box LM29152S/TR TO263-5L LM29152 REEL 500pcs/reel LM29302AS/TR TO263-5L LM29302A REEL 500pcs/reel LM29502S/TR TO263-5L LM29502 REEL 500pcs/reel LM29153T TO220-5L LM29153 TUBE 1000pcs/box LM29303T TO220-5L LM29303 TUBE 1000pcs/box LM29503T TO220-5L LM29503 TUBE 1000pcs/box LM29153S/TR TO263-5L LM29153 REEL 500pcs/reel LM29303S/TR TO263-5L LM29303 REEL 500pcs/reel LM29503S/TR TO263-5L LM29503 REEL 500pcs/reel Notes: “ xx ” may be 1.5V, 1.8V, 2.5V, 3.3V, 5.0V. http://www.hgsemi.com.cn 2 2021 DEC LM29xxxA Pin Configuration 3-Pin TO-220 (T) LM29150/29300/29500 5-Pin TO-220 Fixed Voltage (T) LM29151/29301/29501/29751 5-Pin TO-220 Adjustable Voltage (T) LM29152/29302/29502 5-Pin TO-220 Adjustable with Flag (T) LM29153/29303/29503 5-Pin TO-263 (D2Pak) Fixed Voltage (U) LM29151/29301/29501 5-Pin TO-263 (D2Pak) Adjustable Voltage (U) LM29302/29502 5-Pin TO-263 (D2Pak) Adjustable with Flag (U) LM29153/29303/29503 5-Pin TO-252 (D-Pak) Adjustable Voltage (D) LM29152 3-Pin TO-263 (D2Pak) (UT) LM29150/29300 http://www.hgsemi.com.cn 3 2021 DEC LM29xxxA Pin Description Pin Number TO-220 TO-263 Pin Name 1 INPUT: Supplies the current to the output power device 2 GND: TAB is also connected internally to the IC’s ground on D-PAK. 3 OUTPUT: The regulator output voltage Pin Description Pin Number Fixed TO-220 TO-263 Pin Number Adjustable TO-220 TO-252 TO-263 Pin Number Adj. with Flag TO-220 TO-263 1 1 — ENABLE: CMOS compatible control input. Logic high = enable, logic low = shutdown. 2 2 2 INPUT: Supplies the current to the output power device 3, TAB 3, TAB 3, TAB 4 4 4 OUTPUT: The regulator output voltage — 5 5 ADJUST: Adjustable regulator feedback input that connects to the resistor voltage divider that is placed from OUTPUT to GND in order to set the output voltage. 5 — 1 FLAG: Active low error flag output signal that indicates an output fault condition http://www.hgsemi.com.cn Pin Name GND: TAB is also connected internally to the IC’s ground on D-PAK. 4 2021 DEC LM29xxxA Absolute Maximum Ratings(1) Operating Ratings(2) Input Supply Voltage (VIN)(1) ........................... 7V to +26V Enable Input Voltage (VEN)................................ –0.3V to VIN Lead Temperature (soldering, 5sec.)......................... 260°C Power Dissipation .....................................Internally Limited Storage Temperature Range ....................–65°C to +150°C ESD Rating................................................................ Note 3 Operating Junction Temperature .............. –40°C to +125°C Maximum Operating Input Voltage ................................26V Package Thermal Resistance TO-220 (θJC).........................................................2°C/W TO-263 (θJC).........................................................2°C/W TO-252 (θJC).........................................................3°C/W TO-252 (θJA) ......................................................56°C/W Electrical Characteristics(4,13) VIN = VOUT + 1V; IOUT = 10mA; TJ = 25°C, bold values indicate –40°C≤ TJ ≤ +125°C, unless noted. Parameter Condition Output Voltage IOUT = 10mA Min Max Units –1 1 % –2 2 % 0.06 0.5 % 0.2 1 % 20 100 ppm/°C IOUT = 100mA IOUT = 750mA IOUT = 1.5A IOUT = 100mA IOUT = 1.5A IOUT = 3A IOUT = 250mA IOUT = 2.5A IOUT = 5A IOUT = 250mA IOUT = 4A IOUT = 7.5A 80 220 350 80 250 370 125 250 370 80 270 425 200 mV IOUT = 750mA, VIN = VOUT + 1V IOUT = 1.5A IOUT = 1.5A, VIN = VOUT + 1V IOUT = 3A IOUT = 2.5A, VIN = VOUT + 1V IOUT = 5A IOUT = 4A, VIN = VOUT + 1V IOUT = 7.5A 8 22 10 37 15 70 35 120 20 mA 35 mA 50 mA 75 mA IGRNDDOGround Pin Current at Droupout VIN = 0.5V less than specified VOUT × IOUT = 10mA LM29150 LM29300 LM29500 LM29750 0.9 1.7 2.1 3.1 Current Limit LM29150 LM29300 LM29500 LM29750 10mA ≤ IOUT ≤ IFL, (VOUT + 1V) ≤ VIN ≤26V Line Regulation Load Regulation IOUT = 10mA, (VOUT + 1V) ≤ VIN ≤26V VIN = VOUT + 5V, 10mA ≤ IOUT ≤ 1.5A (5,9) (9) ∆VO ∆T Output Voltage Temperature Coefficient. Dropout Voltage ∆VOUT = -1% (6) LM29150 LM29300 LM29500 LM29750 Ground Current (5) LM29150 LM29300 LM29500 LM29750 Note 8 http://www.hgsemi.com.cn VOUT = 0V (7) VOUT = 0V (7) VOUT = 0V (7) VOUT = 0V (7) Typ 2.1 4.5 7.5 9.5 5 600 175 600 250 600 200 750 mA mA mA mA 3.5 5.0 10.0 15 2021 DEC A A A A LM29xxxA Parameter Condition Min en, Output Noise Voltage (10Hz to 100kHz) IL = 100mA CL = 10µF 400 CL = 33µF 260 Ground Current in Shutdown 29150/1/2/3 only V Reference LM29xx2/29xx3 EN = 0.4V Reference Voltage 1.228 1.215 Reference Voltage 1.203 Adjust Pin Bias Current Reference Voltage Temperature Coefficient Typ Adjust Pin Bias Current Temperature Coefficient Units µV (rms) 2 10 30 µA µA 1.240 1.252 1.265 V V 1.277 V 80 120 nA 40 (10) Max 20 ppm/°C 0.1 nA/°C Flag Output (Error Comparator) LM29xx1/29xx3 Output Leakage Current VOH = 26V 0.01 1.00 2.00 µA Output Low Voltage Device set for 5V, VIN = 4.5V IOL = 250µA 220 300 400 mV Upper Threshold Voltage Device set for 5V (11) Lower Threshold Voltage Device set for 5V (11) 75 Hysteresis Device set for 5V (11) 15 ENABLE Input 40 25 mV 95 140 mV mV LM29xx1/29xx2 Input Logic Voltage Low (OFF) High (ON) Enable Pin 60 V 0.8 2.4 VEN = 26V Input Current VEN = 0.8V Regulator Output Current in Shutdown (12) http://www.hgsemi.com.cn 100 0.7 10 6 600 750 µA 2 4 µA 500 µA 2021 DEC LM29xxxA Notes: 1. Maximum positive supply voltage of 26V must be of limited duration (
LM29302AS/TR 价格&库存
很抱歉,暂时无法提供与“LM29302AS/TR”相匹配的价格&库存,您可以联系我们找货
