HT6030SRZ
HT6030SRZ
HT6030SRZ
TO-263-5
Rev. 01
HT6030SRZ
Rev. 01
HT6030SRZ
TO-263-5
Rev. 01
HT6030SRZ
降压稳压器设计程序(可调输出)
通孔输出电解
输出电压
(V)
2
4
6
9
12
15
24
28
Panasonic
HFQ 系列
(uf/V)
820/35
560/35
470/25
330/25
330/25
220/25
220/35
100/50
表面贴装输出电容
Nichicon
PL 系列
(uf/V)
820/35
470/35
470/35
330/25
330/25
220/35
150/35
100/50
AVX TPS
前馈电容
系列
33nf
10nf
3.3nf
1.5nf
1nf
680pf
560pf
390pf
(uf/V)
330/6.3
330/6.3
220/10
100/16
100/16
68/20
33/25
10/35
Sprague
595D 系列
(uf/V)
470/4
390/6.3
330/10
180/16
180/16
120/20
33/25
15/50
前馈电容
33nf
10nf
3.3nf
1.5nf
1nf
680pf
220pf
220pf
肖特基二极管选型表
当前
表面安装
1A
3A
通孔安装
VR ( 与系统最大输入电压相同 )
20V
1N5817
30V
1N5818
40V
1N5819
1N5820
1N5821
1N5822
MBR320
MBR330
MBR340 MBR350
MBR360
SK32
SK33
SK34
SK36
30WQ03
30WQ04 30WQ05
31DQ03
31DQ04
31DQ05
SR305
SR306
5A
50V
SK35
60V
SR302
SR303
SR304
1N5823
1N5824
1N5825
SR502
SR503
SR504
SR505
SR506
SB520
SB530
SB540
SB550
SB560
50WQ03
50WQ04 50WQ05
Rev. 01
4
HT6030SRZ
HT6030SRZ
Characteristics
HT6030SRZ–3.3 ([Note 1] Test Circuit Figure 3)
Output Voltage
Output Voltage (6.0 V Vin 60 V, 0.5 A ILoad 3.0
A)
TJ = 25°C
TJ = –40 to +125°C
Efficiency (Vin = 12 V, ILoad = 3.0 A)
HT6030SRZ–5 [Note 1]
Output Voltage
Output Voltage (8.0 V Vin 60 V, 0.5 A ILoad
3.0 A)
TJ = 25°C
TJ = –40 to +125°C
HT6030SRZ–12 [Note 1]
Output Voltage
Output Voltage (15.0 V Vin 60 V, 0.5 A ILoad 3.0
A)
TJ = 25°C
TJ = –40 to +125°C
HT6030SRZ–15 [Note 1]
Output Voltage
Output Voltage (18 V Vin 60 V, 0.5 A ILoad 3.0
A)
TJ = 25°C
TJ = –40 to +125°C
HT6030SRZ-ADJUSTABLE VERSION [Note 1]
Feedback Voltage (Vin = 12 V, ILoad = 0.5 A, Vout = 5.0 V, TJ
= 25°C)
Feedback Voltage (8.0 V Vin 60 V, 0.5 A ILoad
3.0 A, Vout = 5.0 V)
TJ = 25°C
TJ = –40 to +125°C
Efficiency (Vin = 12 V, ILoad = 3.0 A, Vout = 5.0 V)
Symbol
Vout
Vout
Min
Max
Unit
3.234
3.366
3.168
3.135
3.432
3.465
65
Vout
Vout
4.9
5.1
V
V
4.8
4.75
5.2
5.25
67
Vout
Vout
11.76
12.24
V
V
11.52
11.4
12.48
12.6
78
Vout
Vout
14.7
15.3
V
V
14.4
14.25
15.6
15.75
78
Vout
1.217
1.243
V
Vout
V
V
V
1.193
1.18
67
1.267
1.28
Rev. 01
HT6030SRZ
封装外形图
TO263-5
A
A1
D
q
D1
G
B
F
E
C
d
0.25
a
b
UNIT:mm
DIM.
A
A1
B
a
b
C
D
MIN
4.520
1.250
10.030
1.680
0.710
1.890
14.280
TYP
4.570
1.270
10.130
1.700
0.810
2.040
14.380
MAX
4.620
1.290
10.330
1.720
0.910
2.190
14.480
DIM.
D1
E
F
G
d
q
MIN
8.690
0.950
TYP
8.740
0.100
7.800
7.97
0.380
1.0
MAX
8.790
0.200
0.395
0.120
Rev. 01
很抱歉,暂时无法提供与“HT6030SRZ-12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.87320
- 10+6.51240
- 30+5.76720
- 100+4.92480
- 500+4.53600
- 1000+4.37400
