LM2576S-3.3 P+
LM2576S-3.3 P+
    JSMSEMI(杰盛微)
    TO-263-5
LM2576S-3.3 P+ 数据手册
LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator FEATURES  3.3V, 5.0V, 12V and Adjustable Output Versions  Adjustable Version Output Voltage Range, 1.23 to 37V +/- 4% maximum over line and load conditions  Guaranteed 3.0A Output Current  Wide Input Voltage Range  Requires Only 4 External Components  52kHz Fixed Frequency Internal Oscillator  TTL Shutdown Capability, Low Power Standby Mode  High Efficiency  Uses Readily Available Standard Inductors  Thermal Shutdown and Current Limit Protection  Moisture Sensitivity Level 3 for SMD packages to r uc co Simple High-Efficiency Step-Down(Buck) Regulator Efficient Pre-Regulator for Linear Regulators On-Card Switching Regulators Positive to Negative Converter(Buck-Boost) Negative Step-Up Converters Power Supply for Battery Chargers Se mi       TO-263 PKG nd APPLICATION TO-220 PKG DESCRIPTION JS MI CR O The LM2576T-ADJ series of regulators are monolithic integrated circuits ideally suited for easy and convenient design of a step-down switching regulator (buck converter). All circuits of this series are capable of driving a 3.0A load with excellent line and load regulation. These devices are available in fixed output voltages of 3.3V, 5.0V, 12V and an adjustable output version. These regulators were designed to minimize the number of external components to simplify the power supply design. Standard series of inductors optimized for use with the LM2576T-ADJ are offered by several different inductor manufacturers. Since the LM2576T-ADJ converter is a switch-mode power supply, its efficiency is significantly higher in comparison with popular three-terminal linear regulators, especially with higher input voltages. In many cases, the power dissipated is so low that no heatsink is required or its size could be reduced dramatically. A standard series of inductors optimized for use with the LM2576T-ADJ are available from several different manufacturers. This feature greatly simplifies the design of switch-mode power supplies. The LM2576T-ADJ features include a guaranteed +/- 4% tolerance on output voltage within specified input voltages and output load conditions, and +/-10% on the oscillator frequency (+/- 2% over 0˚C to 125˚C). External shutdown is included, featuring 80㎂(typical) standby current. The output switch includes cycle-by- cycle current limiting, as well as thermal shutdown for full protection under fault conditions. www.jsmsemi.com 第1页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator LM 2576 Output Voltage : ADJ / 3.3V / 5.0V /12V Package Type : to r T : TO220-5L S : TO263-5L Root Name JS MI CR O Se mi co nd uc Product Code www.jsmsemi.com 第2页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator PIN CONFIGURATION O N /O F F FEEDBACK GND VOUT V IN O N /O F F FEEDBACK GND VOUT V IN TO263-5L to r TO220-5L PIN DESCRIPTION uc Package Symbol TO-220 5L Description TO-263 5L nd VIN 2 VOUT 3 GND 4 FEEDBACK Se mi O CR MI JS co 1 5 ON/OFF This pin is the positive input supply for the JSM2576 step–down switching regulator. In order to minimize voltage transients and to supply the switching currents needed by the regulator, a suitable input bypass capacitor must be present. (Cin in Figure 1). This is the emitter of the internal switch. The saturation voltage VSAT of this output switch is typically 1.5V. It should be kept in mind that the PCB area connected to this pin should be kept to a minimum in order to minimize coupling to sensitive circuitry. Circuit ground pin. See the information about the printed circuit board layout. This pin senses regulated output voltage to complete the feedback loop. The signal is divided by the internal resistor divider network R2, R1 and applied to the non–inverting input of the internal error amplifier. In the adjustable version of the LM2576 switching regulator this pin is the direct input of the error amplifier and the resistor network R2, R1 is connected externally to allow programming of the output voltage. It allows the switching regulator circuit to be shutdown using logic level signals, thus dropping the total input supply current to approximately 80uA. The threshold voltage is typically 1.4V. Applying a voltage above this value (up to +Vin) shuts the regulator off. If the voltage applied to this pin is lower than 1.4V or if this pin is left open, the regulator will be in the "on" condition www.jsmsemi.com 第3页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator Typical Application (Fixed Output Voltage Versions) JS MI CR O Se mi co nd uc to r Figure 1. Block Diagram and Typical Application www.jsmsemi.com 第4页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator ABSOLUTE MAXIMUM RATINGS (Absolute Maximum Ratings indicate limits beyond which damage to the device may occur) Value UNIT Maximum Supply Voltage Vin 45 V On/Off Pin Input Voltage - -0.3V ≤ V ≤ +Vin V Output Voltage to Ground (Steady-State) - -1.0 V PD θJA θJC PD θJA θJC TSTG Internally Limited 65 5 Internally Limited 70 5 -60 to +150 W ℃/W ℃/W W ℃/W ℃/W ℃ 2.0 kV - 260 ℃ TJ 150 ℃ Se mi co Maximum Junction Temperature - uc TO-220 5Lead Thermal Resistance, Junction to Ambient Thermal Resistance, Junction to Case TO-263 5Lead Thermal Resistance, Junction to Ambient Thermal Resistance, Junction to Case Storage Temperature Range Minimum ESD Rating(Human Body Model: C=100 pF, R=1.5kΩ Lead Temperature (Soldering, 10seconds) to r Symbol nd Rating OPERATING RATINGS (Operating Ratings indicate conditions for which the device is intended to be functional, but do not guarantee specific performance limits. For guaranteed specifications, see the Electrical Characteristics.) Symbol Value. Unit Operating Junction Temperature Range TJ -40 to +125 ℃ Supply Voltage Vin 40 V JS MI CR O Rating www.jsmsemi.com 第5页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator ELECTRICAL CHARACTERISTICS / SYSTEM PARAMETERS ([Note 1] Test Circuit Figure 15) (Unless otherwise specified, Vin = 12V for the 3.3V, 5.0V, and Adjustable version, Vin = 25V for the 12V version. ILoad = 500 mA. For typical values TJ = 25°C, for min/max values TJ is the operating junction temperature range that applies [Note 2], unless otherwise noted.) Min TYP Max Unit Vout 3.234 3.3 3.366 V Vout 3.168 3.135 - JSM2576-3.3V ([Note 1] Test Circuit Figure 2) Output Voltage (Vin = 12V, ILOAD=0.5A, TJ=25℃) Output Voltage (6.0V≤Vin≤40V, 0.5A≤ILOAD≤3.0A TJ=25℃ TJ= -40℃ ~ +125℃ Efficiency (Vin=12V, ILOAD=3.0A) 3.432 3.465 - % V 5.0 5.1 V nd O JSM2576T-ADJ ([Note 1] Test Circuit Figure 2) Feedback Voltage (Vin=12V, ILOAD=0.5A, TJ=25℃) 3.3 75 4.9 5.0 77 5.2 5.25 - V η 4.8 4.75 - % Vout 11.76 12 12.24 V Vout 12 88 12.48 12.6 - V η 11.52 11.4 - % Vout 1.217 1.23 1.243 V Vout 1.193 1.18 - 1.23 77 1.267 1.28 - V Vout Se mi JSM2576-12V ([Note 1] Test Circuit Figure 2) Output Voltage (Vin = 25V, ILOAD=0.5A, TJ=25℃) Output Voltage (15V≤Vin≤40V, 0.5A≤ILOAD≤3.0A TJ=25℃ TJ= -40℃ ~ +125℃ Efficiency (Vin=25V, ILOAD=3.0A) Vout co JSM2576-5.0V ([Note 1] Test Circuit Figure 2) Output Voltage (Vin = 12V, ILOAD=0.5A, TJ=25℃) Output Voltage (8.0V≤Vin≤40V, 0.5A≤ILOAD≤3.0A TJ=25℃ TJ= -40℃ ~ +125℃ Efficiency (Vin=12V, ILOAD=3.0A) η to r Symbol uc Characteristics Feedback Voltage (8.0V≤Vin≤40V, 0.5A≤ILOAD≤3.0A, Vout=5.0V) η % MI CR TJ=25℃ TJ= -40℃ ~ +125℃ Efficiency (Vin=12V, ILOAD=3.0A, Vout=5.0V) JS 1. External components such as the catch diode, inductor, input and output capacitors can affect switching regulator system performance. When the JSM2576 is used as shown in the Figure 15 test circuit, system performance will be as shown in system parameters section. 2. Tested junction temperature range for the JSM2576: Tlow = –40°C Thigh = +125°C www.jsmsemi.com 第6页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator ELECTRICAL CHARACTERISTICS / Device Parameters (Unless otherwise specified, Vin = 12V for the 3.3V, 5.0V, and Adjustable version, Vin = 25V for the 12V version. ILoad = 500 mA. For typical values TJ = 25°C, for min/max values TJ is the operating junction temperature range that applies [Note 2], unless otherwise noted.) Characteristics Symbol MIN. TYP. MAX. Unit Ib - 25 - 100 200 nA 47 42 52 - 58 63 - 1.5 - 1.8 2 V DC 94 98 - % ICL 4.2 3.5 5.8 - 6.9 7.5 A IL - 0.8 6 50 30 mA IQ - 5 - 9 11 mA - 80 - 200 400 µA 2.2 2.4 1.4 - - - 1.2 - 1 0.8 V - 15 0 30 0.5 µA CR MI JS Feedback Bias Current (Vout=5.0V [Adjustable Version Only]) TJ=25℃ TJ= -40 to +125℃ Oscillator Frequency [Note 3] TJ=25℃ TJ= 0 to +125℃ TJ= -40 to +125℃ Saturation Voltage (Iout=3.0A [note 4]) TJ= 25℃ TJ= -40 to +125℃ nd VSAT O ISTBY JS VIL IIH IIL r TJ= -40 to +125℃ ON/OFF Pin Input Current (Test Circuit Figure 15) ON/OFF Pin = 5.0V (Regulator OFF), TJ=25℃ ON/OFF Pin = 0V (Regulator ON), TJ=25℃ to MI VIH uc nd CR co mi Se mi Se ON/OFF Pin Logic Input Level (Test circuit Figure 15) Vout=0V TJ=25℃ TJ= -40 to +125℃ Vout=Nominal Output Voltage TJ=25℃ uc FOSC co O Max Duty Cycle (“0”) [Note 5] Current Limit (Peak Current [Note 3 and 4]) TJ= 25℃ TJ= -40 to +125℃ Output Leakage Current [Note 6 and 7], TJ=25℃ Output = 0V Output = -1.0V Quiescent Current [Note 6] TJ= 25℃ TJ= -40 to +125℃ Standby Quiescent Current (ON/OFF Pin = 5.0V ("off")) TJ=25℃ TJ= -40 to +125℃ to r All Output Voltage Versions kHz V 3. The oscillator frequency reduces to approximately 18 kHz in the event of an output short or an overload which causes the regulated output voltage to drop approximately 40% from the nominal voltage. This self protection feature lowers the average dissipation of the IC by lowering the minimum duty cycle from 5% down to approximately 2% 4. Output sourcing current. No diode, inductor or capacitor connected to output pin. 5. Feedback removed from output and connected to 0V. 6. Feedback removed from output and connected to +12V for the Adjustable, 3.3V, and 5.0V versions, and +25V for the 12V version, to force the output transistor “off”. 7. Vin = 40V. www.jsmsemi.com 第7页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator uc CR MI JS to r TYPICAL PERFORMANCE CHARACTERISTICS (Circuit of Figure 15) Figure 3. Line Regulation CR O nd co mi Se mi Se co O nd Figure 2. Normalized Output Voltage Figure 5. Current Limit JS r to MI uc Figure 4. Dropout Voltage Figure 6. Quiescent Current www.jsmsemi.com Figure 7. Standby Quiescent Current 第8页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator uc CR MI JS to r TYPICAL PERFORMANCE CHARACTERISTICS (Circuit of Figure 15) Figure 9. Switch Saturation Voltage O Figure 11. Minimum Operating Voltage JS r to MI uc CR Figure 10. Oscillator Frequency nd co mi Se mi Se co O nd Figure 8. Standby Quiescent Current Figure 12. Feedback Pin Current www.jsmsemi.com 第9页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator uc to r TYPICAL PERFORMANCE CHARACTERISTICS Figure 14. Load Transient Response nd Figure 13. Switching Waveforms co Vout = 15V A : Output Pin Voltage, 10V/DIV C: Inductor Current, 2.0A/DIV Se mi B: Inductor Current, 2.0A/DIV D: Output Ripple Voltage, 50mV/DIV, AC-Coupled JS MI CR O Horizontal Time Base : 5.0 µ s/DIV www.jsmsemi.com 第10页,共11页 LM2576S/T系列 SIMPLE SWITCHER 3A Step-Down Voltage Regulator nd uc to r Outline Drawing:TO-220-5 JS MI CR O Se mi co Outline Drawing:TO-263-5 www.jsmsemi.com 第11页,共11页
LM2576S-3.3 P+ 价格&库存
很抱歉,暂时无法提供与“LM2576S-3.3 P+”相匹配的价格&库存,您可以联系我们找货
