R1245x Series
AEC-Q100 Compliant
1.2 A, 30 V Step Down DC/DC Converter for Automotive Applications
No. EC-269-201022
OUTLINE
The R1245x is a Step-down DC/DC converter with internal N-channel high side Tr. That is developed with
CMOS process technology. The ON resistance of the built-in high-side transistor is 0.35 and the R1245x
can provide the maximum 1.2 A output current. Each of the ICs consists of an oscillator, a PWM control
circuit, a voltage reference unit, an error amplifier, a phase compensation circuit, a slope compensation
circuit, a soft-start circuit, protection circuits, an internal voltage regulator, and a switch for bootstrap circuit.
The ICs can make up a step-down DC/DC converter with an inductor, resistors, a diode, and capacitors.
The R1245x is a current mode operating type DC/DC converter without an external current sense resistor,
and realizes fast response and high efficiency. As an output capacitor, a ceramic type capacitor can be used
with the R1245x. The options of the internal oscillator frequency are preset at 330 kHz for version A and B,
500 kHz for version C and D, 1000 kHz for version E and F, 2400 kHz for version G and H.
As for protection, an Lx peak current limit circuit cycle by cycle, a thermal shutdown function and an under
voltage lockout (UVLO) function are built in. Furthermore, there are two types for short protection, for
A/C/E/G version, a latch protection function which makes the output latch off if the output voltage keeps
lower than the set output voltage for a certain time after detecting current limit is built in, for B/D/F/H version,
a fold-back protection function which changes the oscillator frequency slower after detecting short circuit or
equivalent. As for the packages of the R1245x, HSOP-8E and DFN2020-8 are available.
FEATURES
Input Voltage Range (Maximum Rating) ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 4.5 V to 30 V (32 V)
Operating Temperature ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ −40°C to 105°C
Internal N-channel MOSFET Driver ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. RON = 0.35
Adjustable Output Voltage with External Resistor ꞏꞏꞏꞏꞏꞏ 0.8 V or more
Feedback Voltage and Tolerance ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 0.8 V1.0%
Peak Current Limit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 2.0 A
UVLO Function Released Voltage ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 4.0 V
Operating Frequency ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 330 kHz (A/B version), 500 kHz (C/D version),
1000 kHz (E/F version), 2400 kHz (G/H version)
Fold-back Protected Frequency ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ 170 kHz (B/D version), 250 kHz (F version),
400 kHz (H version)
Latch Protection Delay Time ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 4 ms for A/C/E/G version
Built-in Thermal Shutdown Circuit ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 160°C
Ceramic Capacitors Recommended for Input and Output
Stand-by Current ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Typ. 0 A
Packages ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ HSOP-8E, DFN2020-8
1
R1245x
No. EC-269-201022
APPLICATIONS
Power source for car accessories including car audio equipment, car navigation system, and ETC system.
Power source for control units including EV inverter and charge control.
SELECTION GUIDE
In the R1245x, the package, type of short protection (Latch or Fold-back), and the oscillator frequency can be
selected with the user’s request.
Selection Guide
Product Name
Package
Quantity per Reel
Pb Free
Halogen Free
R1245S003-E2-#E
HSOP-8E
1,000 pcs
Yes
Yes
R1245L003-TR-AE
DFN2020-8
3,000 pcs
Yes
Yes
: Designation of the oscillator frequency and the protection function option.
Symbol
A
B
C
D
E
F
G
H
Oscillator Frequency
330 kHz
330 kHz
500 kHz
500 kHz
1000 kHz
1000 kHz
2400 kHz
2400 kHz
Latch Protection
Fold-back Protection
#: Designated Automotive Class Code
A
Range
−40°C to 105°C
Guaranteed Specs
Temperature Range
25°C
High Temperature
J
−40°C to 105°C
−40°C to 105°C
High and low Temperature
Screening
Automotive class code (A, J) varies depending on the package and function.
Package
HSOP-8E
DFN2020-8
2
Function
A
J
A, B, G, H
C, D, E, F
A, B, C, D, E, F, G, H
R1245x
No. EC-269-201022
BLOCK DIAGRAM
V IN
Thermal Shutdown
C
E
UVLO
5V
Regulator
Regulator
BST
Shutdown
SETPULSE
Oscillator
*1
FB
MAXDUTY
S
D
Lx
R
Reference
Soft Start
Circuit (1 ms)
0.8 V
Limit Latch
Circuit (4 ms)
*1
Current Slope
Circuit
Peak Current
Limit Circuit
GND
R1245x Block Diagram
*1
Version
A
B
C
D
E
F
G
H
330 kHz
330 kHz
500 kHz
500 kHz
1000 kHz
1000 kHz
2400 kHz
2400 kHz
Short Protection Type
Latch
Fold-back
Latch
Fold-back
Latch
Fold-back
Latch
Fold-back
3
R1245x
No. EC-269-201022
PIN DESCRIPTIONS
Top View
8
7
6
Bottom View
5
5
6
7
Top View
8
8
7
6
Bottom View
5
1
2
3
4
4
3
6
7
8
3
2
1
∗2
∗1
1
5
2
2
3
4
4
1
SOP-8E Pin Configuration
DFN2020-8 Pin Configuration
R1245S Pin Description
Pin No.
Symbol
Description
1
Lx
Lx Switching Pin
2
VIN
Power Supply Pin
3
CE
Chip Enable Pin (Active with ”H”)
4
TEST
TEST pin (must be open for user side.)
*1
5
GND
Ground Pin
6
FB
Feedback Pin
7
NC
No connection
8
BST
Bootstrap Pin
*1
Connect the backside heat radiation tab to GND or same as GND level (recommendation). The tab is connected to
the GND pin.
R1245L Pin Description
Pin No.
Symbol
1
Lx
2
VIN
3
VIN
4
CE
5
GND∗2
6
FB
7
TEST
8
BST
*2
Description
Lx Switching Pin
Power Supply Pin
Power Supply Pin
Ground Pin
Feedback Pin
Test Pin (must be open for user side)
Bootstrap Pin
the GND pin.
4
R1245x
No. EC-269-201022
INTERNAL EQUIVALENT CIRCUIT FOR EACH PIN
Regulator
VIN
BST
LX
LX
Regulator
VIN
CE
FB
Regulator
TEST
5
R1245x
No. EC-269-201022
ABSOLUTE MAXIMUM RATINGS
(GND = 0 V)
Absolute Maximum Ratings
Symbol
VIN
Rating
Unit
−0.3 to 32
V
VLX − 0.3 to VLX + 6
V
Input Voltage
VBST
BST Pin Voltage
VLX
Lx Pin Voltage
−0.3 to VIN + 0.3
V
VCE
CE Pin Input Voltage
−0.3 to VIN + 0.3
V
VFB
Feedback Pin Voltage
−0.3 to 6
V
PD
Tj
Tstg
*1
Item
Power Dissipation (HSOP-8E)*1
Power Dissipation (DFN2020-8)*1
Ultra High Wattage Land
Pattern
3600
Standard Land Pattern
1100
mW
Junction Temperature
−40 to 150
°C
Storage Temperature Range
−55 to 150
°C
Refer to POWER DISSIPATION for detailed information.
Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause the permanent
damages and may degrade the lifetime and safety for both device and system using the device in the field.
The functional operation at or over these absolute maximum ratings is not assured.
RECOMMENDED OPERATING CONDITIONS
Recommended Operating Conditions
Symbol
Item
VIN
Input Voltage
Ta
Operating Temperature Range
Rating
Unit
4.5 to 30
V
−40 to 105
°C
All of electronic equipment should be designed that the mounted semiconductor devices operate within the
recommended operating conditions. The semiconductor devices cannot operate normally over the recommended
operating conditions, even if when they are used over such conditions by momentary electronic noise or surge. And
the semiconductor devices may receive serious damage when they continue to operate over the recommended
6
R1245x
No. EC-269-201022
ELECTRICAL CHARACTERISTICS
VIN = 12 V, unless otherwise noted.
The specifications surrounded by
are guaranteed by design engineering at –40°C ≤ Ta ≤ 105°C.
(Ta = 25°C)
R1245x003x-AE Electrical Characteristics
Symbol
Item
Conditions
IIN
VIN Consumption Current
VIN = 30 V, VFB = 1.0 V
VUVLO1
UVLO Detect Voltage
Falling
3.55
VUVLO2
UVLO Released Voltage
Rising
3.75
VFB
VFB Voltage Tolerance
Ta = 25°C
0.792 0.800 0.808
–40°C ≤ Ta ≤ 105°C
0.781
Version A/B
Version C/D
fOSC
Version E/F
Version G/H
fFLB
Maxduty
tstart
tDLY
Fold-back Frequency
Oscillator Maximum
Duty Cycle
Min.
Ta = 25°C
300
–40°C ≤ Ta ≤ 105°C
280
Ta = 25°C
450
–40°C ≤ Ta ≤ 105°C
430
Ta = 25°C
900
–40°C ≤ Ta ≤ 105°C
870
Ta = 25°C
2200
Typ.
Max.
Unit
0.5
1.80
mA
VUVLO2 VUVLO2
−0.2 −0.05
4.0
0.819
330
500
1000
2400
Version D
VFB < 0.56 V
170
Version F
VFB < 0.56 V
250
Version H
VFB < 0.56 V
400
Version E/F
86
Version G/H
74
1100
kHz
2600
2650
170
91
550
1140
VFB < 0.56 V
Version C/D
V
360
590
Version B
91
V
380
–40°C ≤ Ta ≤ 105°C 2150
Version A/B
4.25
V
kHz
Soft-start Time
VFB = 0.72 V
1.0
ms
Delay Time for Latch
Protection
Version A/G
4
ms
7
R1245x
No. EC-269-201022
(Ta = 25°C)
Symbol
Item
Conditions
Typ.
Max.
Unit
Lx High Side Switch ON
Resistance
Lx High Side Switch
Leakage Current
Lx High Side Switch
Limited Current
VIN = 30 V, VCE = 0 V
VCEL
CE “L” Input Voltage
VIN = 30 V
VCEH
CE “H” Input Voltage
VIN = 30 V
1.6
IFB
VFB Input Current
–0.3
μA
ICEL
CE “L” Input Current
–0.3
μA
ICEH
CE “H” Input Current
VIN = 30 V, VCE = 30 V
–0.3
μA
Standby Current
VIN = 30 V
μA
RLXH
ILXHOFF
ILIMLXH
Istandby
0.35
VBST - VLX = 4.5 V
VBST - VLX = 4.5 V
All of units are tested and specified under load conditions such as Tj ≈ Ta = 25°C.
8
Min.
5.0
2.0
μA
A
0.3
V
V
R1245x
No. EC-269-201022
(–40°C ≤ Ta ≤ 105°C)
R1245x003x-JE Electrical Characteristics
Symbol
Item
Conditions
Typ.
Max.
Unit
IIN
0.5
1.80
mA
VUVLO1
UVLO Detect Voltage
Falling
3.55
VUVLO2
−0.2
VUVLO2
−0.05
V
VUVLO2
Rising
3.75
4.0
4.25
V
VFB
Ta = 25°C
0.792 0.800
0.808
–40°C ≤ Ta ≤ 105°C
0.781
0.819
Version A/B
fOSC
Version G/H
Min.
Ta = 25°C
300
–40°C ≤ Ta ≤ 105°C
280
Ta = 25°C
2200
330
360
380
2400
V
2600
kHz
2650
Version B
VFB < 0.56 V
170
Version H
VFB < 0.56 V
400
kHz
fFLB
Fold-back Frequency
Maxduty
Oscillator Maximum.
Duty Cycle
Version A/B
91
Version G/H
74
Soft-start Time
VFB = 0.72 V
1.0
ms
Version A/G
4
ms
0.35
tstart
tDLY
RLXH
ILXHOFF
ILIMLXH
Protection
Resistance
Lx High Side Switch
Leakage Current
Lx High Side Switch
Limited Current
VBST − VLX = 4.5 V
VBST - VLX = 4.5 V
1.2
5.0
2.0
μA
A
0.3
V
VCEL
VIN = 30 V
VCEH
VIN = 30 V
1.6
IFB
VFB Input Current
VIN = 30 V, VFB =1.0 V
–0.3
μA
ICEL
–0.3
μA
ICEH
–0.3
μA
Standby Current
VIN = 30 V
μA
Istandby
V
9
R1245x
No. EC-269-201022
OPERATING DESCRIPTIONS
OPERATION OF THE BUCK CONVERTER AND THE OUTPUT CURRENT
The DC/DC converter charges energy in the inductor when the switch turns on, and discharges the energy
from the inductor when the switch turns off and controls with less energy loss, so that a lower output voltage
than the input voltage is obtained. Refer to the following figures.
ILmax
IL
ILmin
i1
VIN
Switch
L
Diode
i2
topen
VOUT
COUT
GND
ton
toff
t=1/fosc
Basic Circuit
Current flowing through the Inductor
Step 1: The switch turns on and current IL (= i1) flows, and energy is charged into COUT. At this moment, IL
increases from ILmin (= 0) to reach ILmax in proportion to the on-time period (ton) of the switch.
Step 2: When the switch turns off, the diode turns on in order to maintain IL at ILmax, and current IL (= i2) flows.
Step 3: IL (= i2) decreases gradually and reaches IL = ILmin = 0 after a time period of topen, and the diode
turns off. This case is called as discontinuous mode. If the output current becomes large, next switching
cycle starts before IL becomes 0 and the diode turns off. In this case, IL value increases from ILmin (>
0), and this case is called continuous mode.
In the case of PWM control system, the output voltage is maintained by controlling the on-time period (ton),
with the oscillator frequency (fosc) being maintained constant.
10
R1245x
No. EC-269-201022
TYPICAL APPLICATION CIRCUIT
R1245x00xA/B Typical Application Circuit, 330 kHz, VOUT = 1.2 V, VIN = 24 V
R1245x00xC/D Typical Application Circuit, 500 kHz, VOUT = 3.3 V, VIN = 24 V
*TEST pin must be open.
11
R1245x
No. EC-269-201022
R1245x00xE/F Typical Application Circuit, 1000 kHz, VOUT = 3.3 V VIN = 12 V
R1245x00xG/H Typical Application Circuit, 2400 kHz, VOUT = 5. 0 V, VIN = 12 V
12
R1245x
No. EC-269-201022
OUTPUT CURRENT AND SELECTION OF EXTERNAL COMPONENTS
The calculation method of output current and the relation between the output current and external components
are as follows:
When the switch of Lx turns on:
(Wherein, the peak to peak value of the ripple current is described as IRP, the ON resistance of the switch is
described as RONH, and the diode forward voltage as VF, and the DC resistance of the inductor is described as
RL, and on time of the switch is described as ton)
VIN = VOUT + (RONH + RL) IOUT + L IRP / ton ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 1
When the switch turns off (the diode turns on) as toff:
L IRP / toff = VF + VOUT + RL IOUT ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 2
Put Equation 2 to Equation 1 and solve for ON duty of the switch, ton / (toff + ton) = DON,
DON = (VOUT + VF + RL IOUT) / (VIN + VF - RONH IOUT)ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 3
Ripple Current is as follows:
IRP = (VIN −VOUT −RONH IOUT −RL IOUT) DON / fosc / L ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 4
wherein, peak current that flows through L, and the peak current ILmax is as follows:
ILmax = IOUT + IRP / 2 ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 5
As for the valley current ILmin,
ILmin = IOUT - IRP / 2 ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 6
If ILmin < 0, the step-down DC/DC converter operation becomes current discontinuous mode.
Therefore the current condition of the current discontinuous mode, the next formula is true.
IOUT < IRP / 2 ꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏꞏ Equation 7
Consider ILmax and ILmin, conditions of input and output and select external components.
13
R1245x
No. EC-269-201022
Ripple Current and Lx current limit
The ripple current of the inductor may change according to the various reasons. In the R1245x, as an Lx
current limit, Lx peak current limit is used. Therefore the upper limit of the inductor current is fixed.
The peak current limit is not the average current of the inductor (output current). If the ripple current is
large, peak current becomes also large. The characteristic is used for the fold-back current limit of version
B/D/F/H. In other words, the peak current limit is maintained and the switching frequency is reduced, as a
result, the average current of the inductor is reduced. To release this condition, at 170 kHz for version B/D,
at 250 kHz for version F, at 400 kHz for version H must not be beyond the peak current limit. In the Figure
1, the sequence of the Lx current limit function is described.
VOUT
VOUT
Limit Latch
(R1245x00x
A/C/E/G)
open
4msec
short
4msec
t
shutdown
restart
(CE=0→"H")
VOUT
VOUT
Fold Back
FB
