SPX3819M5-L-3-6(MS)
SPX3819M5-L-3-6(MS)
    MSKSEMI(美森科)
    SOT23-5
SPX3819M5-L-3-6(MS) 数据手册
SPX3819M5-L-X-X(MS) Product specification SPX3819M5-L-X-X(MS) GENERAL DESCRIPTION The SPX3819M5-L-X-X(MS) series are a group of low-dropout ( LDO ) voltage regulators offering the benefits of wide input voltage range,low dropout voltage,low power consumption, and miniaturized packaging. Quiescent current of only 1.5µA makes these devices ideal for powering the battery-powered,always-on systems that require very little idle-state power dissipation to a longer service life. The SPX3819M5-L-X-X(MS) series of linear regulators are stable with the ceramic output capacitor over its wide input range from 2V to 24V and the entire range of output load current ( 0mAto 500mA ). Applications Features  1.5μA Ground Current at no Load  Portable, Battery Powered Equipment  ±2% Output Accuracy  Low Power Microcontrollers  500mA Output Current  Laptop, Palmtops and PDAs  Wide Operating Input Voltage Range: 2V to 24V  Wireless Communication Equipment  Dropout Voltage: 0.35V at 100mA / VOUT  Audio/Video Equipment  Support Fixed Output Voltage 1.8V, 3.3V, 5V  Car Navigation Systems  Stable with Ceramic or Tantalum Capacitor  Industrial Controls  Current Limit Protection  Weighting Scales  Over-Temperature Protection  Meters  SOT-23-5 Packages Available  Home Automation 5V Reference News&Marking SOT-23-5 Pin Configurations NC SPX3819M5-L-1-5(MS) |W324 4 SPX3819M5-L-2-5(MS) |H333 SPX3819M5-L-3-0(MS) SPX3819M5-L(MS) |J303 SPX3819M5-L-3-6(MS) |P336 Copyright© Msksemi Incorporated SPX3819M5-L-1-8(MS) |G323 SPX3819M5-L-2-8(MS) |Q328 SPX3819M5-L-3-3(MS) |L352 SPX3819M5-L-5-0(MS) |M321 www.msksemi.com SPX3819M5-L-X-X(MS) Part Number Code —— SPX3819M5-L- X-X (MS) brand identity SOT-23-5 Output voltage:1-5=1.5V 1-8=1.8V 2-5=2.5V 2-8=2.8V 3-0=3.0V 3-3=3.3V 3-6=6.6V 5-0=5.0V Notes:ADJ=SPX3819M5-L(MS) Description of Functional Pins Pin No Pin Name Pin Function 2 GND Ground 5 VOUT Output of the Regulator 1 VIN Input of Supply Voltage. 4 3 NC No Internal Connection. . Enable Control Input. Copyright© Msksemi Incorporated CE www.msksemi.com SPX3819M5-L-X-X(MS) Typical Application Circuits Figure 1: Application circuit of Fixed VOUT LDO Function Block Diagram Copyright© Msksemi Incorporated www.msksemi.com SPX3819M5-L-X-X(MS) Absolute Maximum Ratings (Note 1) VIN to GND ------------------------------------------------------------------------------------------------------------------- -0.3V to 28V VOUT to GND 1.8V,3.3V,5V----------------------------------------------------------------------------------------------------- -0.3V to 6.0V VOUT to VIN ----------------------------------------------------------------------------------------------------- -28V to 0.3V Package Thermal Resistance (Note 2) θJA ------------------------------------------------------------------------------------------- 200 oC /W - 10 sec.) --------------------------------------------------------------------------------------Lead Temperature (Soldering, Junction Temperature -------------------------------------------------------------------------------------------------------------- 260 oC 150 oC Storage Temperature Range ------------------------------------------------------------------------------------------ -40 oC to 150 oC ESD Susceptibility HBM ----------------------------------------------------------------------------------------------------------------------------- 2KV MM --------------------------------------------------------------------------------------------------------------------------- 200V Recommended Operating Conditions Input Voltage VIN ------------------------------------------------------------------------------------------------------------Junction Temperature Range ---------------------------------------------------------------------------------------Ambient Temperature Range ------------------------------------------------------------------------------------------ Copyright© Msksemi Incorporated 2.0V to 24V -40 oC to 125 oC -40 oC to 85 oC www.msksemi.com SPX3819M5-L-X-X(MS) Electrical Characteristics (VIN =15V, VEN =5V, TA=25oC unless otherwise specified) Parameter Supply Voltage Symbol VIN DC Output Voltage Accuracy VDROP Dropout Voltage (ILOAD =100mA) Ground Current (ILOAD = 0mA) Test Conditions 2 -- 24 V 2 % -- 0.35 VDROP_3.3V VOUT = 3.3V 0.42 VDROP_1.8V VOUT = 1.8V 0.5 VOUT = 5V 2.2 μA 0.3 % 0.1 % 700 mA 70 dB IQ Load Regulation ΔLOAD 1mA≤ ILOAD ≤ 0.2A Thermal Shutdown Hysteresis Unit VOUT ≥ 5V ILOAD =1mA, 5 ≤ VIN ≤ 30V Thermal Shutdown Temperature Max -2 ΔLINE Power Supply Rejection Ratio Typ ILOAD =0.1mA Line Regulation Output Current Limit Min ILIM PSRR TSD ΔTSD VOUT =0 -- 501 VOUT =5V, ILOAD =1mA, VIN = 12V, f = 100Hz ILOAD =10mA -- 160 15 V -- °C °C Note 1. Stresses beyond those listed “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may affect device reliability. Copyright© Msksemi Incorporated www.msksemi.com SPX3819M5-L-X-X(MS) Application Guideline Input and Output Capacitor Requirements resistor in dropout condition. The external input and output capacitors of As any linear regulator, PSRR and transient response SPX38 19M5-L-X-X(MS) series must be properly selected are degraded as ( VIN – VOUT ) approaches dropout for stability and performance. Use a 1μF or larger in condition. put capacitor and place it close to the IC's VIN and GN D pins. Any output capacitor meeting the minimum 1m OTP (Over Temperature Protection) Ω ESR ( Equivalent Series Resistance ) and effective c The over temperature protection function of apacitance between 1μF and 22μF requirement may 19M5-L-X-X(MS) series will turn off the P-MOSFET w be used. Place the output capacitor close to the IC's V hen the junction temperature exceeds 160°C (typ.). OUT and GND pins.Increasing capacitance and de Once the junction temperature cools down by appro creasing ESR can improve the circuit's PSRR and lin ximately 15°C, the regulator will automatically resume e transient response. operation. Current Limit Thermal Application The For continuous operation, do not exceed the absolute SPX3819M5-L-X-X(MS) series contain the curren SPX38 t limiter of output power transistor, which monitors a maximum junction temperature. The maximum power nd controls the transistor, limiting the output cur dissipation depends on the thermal resistance of the rent to 700mA ( typical ). IC package, PCB layout, rate of surrounding airflow, The output can be shorted to ground indefinitely and without damaging the part. temperature. The maximum power dissipation can be Dropout Voltage The SPX3819M5-L-X-X(MS) series use a PMOS pas s transistor to achieve low dropout. When ( VIN – VOUT ) is less than the dropout voltage ( VDROP ), t he PMOS pass device is in the linear region of operati on and the input-to-output resistance is the RDS(ON) o f the PMOS pass element. VDROP scales approximatel y with the output current because the PMOS devic difference between junction and ambient calculated as below: The max PD (Max)= (125°C − 25°C) / (200°C/W) = 0.5W . Power dissipation (PD) is equal to the product of the output current and the voltage drop across the output pass element, as shown in the equation below: PD = ( VIN – VOUT ) × IOUT e behaves as a Layout Consideration By placing input and output capacitors on the same side of the PCB as the LDO, and placing them as close as is practical to the package can achieve the best performance. The ground connections for input and output capacitors must be back to the SPX3819M5-L-X-X(MS) ground pin using as wide and as short of a copper trace as is practical. Connections using long trace lengths, narrow trace widths, and/or connections through via must be avoided. These add parasitic inductances and resistance that results in worse performance especially during transient conditions. Copyright© Msksemi Incorporated www.msksemi.com SPX3819M5-L-X-X(MS) Package Outline Dimensions Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 2.650 2.950 0.104 0.116 E1 1.500 1.700 0.950(BSC) 0.059 e 0.067 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° Suggested Pad Layout REEL SPECIFICATION P/N SPX3819M5-L-X-X(MS) Copyright© Msksemi Incorporated PKG SOT-23-5 QTY 3000 www.msksemi.com SPX3819M5-L-X-X(MS) Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
SPX3819M5-L-3-6(MS) 价格&库存
很抱歉,暂时无法提供与“SPX3819M5-L-3-6(MS)”相匹配的价格&库存,您可以联系我们找货
SPX3819M5-L-3-6(MS)
    • 5+0.44611
    • 50+0.43575
    • 150+0.42887
    • 500+0.42199
    库存:771
