PJ9500M15SE
PJ9500M15SE
    PJ(平晶)
    SOT23-5
    1.5V 500MA 6V
PJ9500M15SE 数据手册
PJ9500 Series Low Dropout Regulators Description PJ9500 Series is high accuracy,very low quiescent current,low-dropout linear regulator able to provide 500mA load current. PJ9500 Series features very fast response against line voltage transient and load current transient, and ensures no overshoot voltage during the LDO start up and short circuit recovery. PJ9500 Series integrated short circuit protection, current limiting protection and thermal protection function. By putting the EN pin down to turn on shuntdown mode. Features ⚫ Wide Input Voltage Range: 1.8V~6V ⚫ Maximum Output Current: 500mA ⚫ Standard Fixed Output Voltage Options: 1.2V,1.5V,1.8V,2.5V,2.8V,3V,3.3V,3.6V,etc ⚫ Low Quiescent Current: 800nA ⚫ PSRR=60dB@1KHz ⚫ Low Dropout: 130mV @ 100mA ⚫ Low Output Voltage Accuracy: ±2% ⚫ Short Circuit Protection ⚫ Current Limiting Protection ⚫ Thermal Shutdown Protection ⚫ Available Packages: SOT-23, SOT-23-3, SOT-89, SOT-23-5,DFN1x1-4L and SOT-89-5 Applications ⚫ Battery-Powered Equipment ⚫ Smoke Detector and Sensor ⚫ Micro Controller Applications Typical Application Circuit www.pingjingsemi.com Revision:1.0 Oct-2023 1 / 16 PJ9500 Series Low Dropout Regulators Pin Distribution SOT-23 SOT-89 SOT-23-3 3.VIN 2.VIN 3.VIN 1.GND 2.VOUT 1.GND 2.VIN 3.VOUT SOT-23-5 4. NC 5. VOUT 1.GND SOT-89-5 DFN1x1-4L 4. NC 5. VOUT 4.VIN 3.EN 2.VOUT GND 2.GND 1.VIN 3.EN 2.GND 1.VOUT (Bottom View) 1.VIN 2.GND 3.EN Functional Pin Description Pin Name Pin Function VIN Power Input Voltage GND Ground EN Chip Enable (Active High). Note that this pin is high impedance NC NO Connected VOUT Output Voltage Ordering Information PJ9500 Package Type SA:SOT-23 SQ:SOT-89 SC:SOT-23-3 SE:SOT-23-5 DE:DFN1x1-4L SR: SOT-89-5 Output Voltage 12 : 1.2V 15 : 1.5V 18 : 1.8V 25 : 2.5V 28 : 2.8V 30 : 3.0V 33 : 3.3V 36 : 3.6V Output current tap M : 500mA www.pingjingsemi.com Revision:1.0 Oct-2023 2 / 16 PJ9500 Series Low Dropout Regulators Ordering Information Continue Orderable Package Device Reel Package Qty (inch) (PCS) Eco Plan Note MSL Level Marking Code PJ9500M12SA PJ9500M15SA PJ9500M18SA PJ9500M25SA SOT-23 PJ9500M28SA 7 3000 RoHS & Green MSL1 PJ9500M30SA 9500 -XX XX:Output Voltage e.g. 3.0:3.0V PJ9500M33SA PJ9500M36SA PJ9500M12SQ PJ9500M15SQ PJ9500M18SQ PJ9500M25SQ SOT-89 PJ9500M28SQ 7/13 1000/3000 RoHS & Green MSL1 PJ9500M30SQ 9500 -XX XX:Output Voltage e.g. 3.0:3.0V PJ9500M33SQ PJ9500M36SQ PJ9500M12SC PJ9500M15SC PJ9500M18SC PJ9500M25SC PJ9500M28SC SOT-23-3 PJ9500M30SC PJ9500M33SC 7 3000 RoHS & Green MSL3 9500 -XX XX:Output Voltage e.g. 3.0:3.0V PJ9500M36SC www.pingjingsemi.com Revision:1.0 Oct-2023 3 / 16 PJ9500 Series Low Dropout Regulators PJ9500M12SE PJ9500M15SE PJ9500M18SE PJ9500M25SE PJ9500M28SE SOT-23-5 7 3000 RoHS & Green MSL3 PJ9500M30SE 9500 -XX XX:Output Voltage e.g. 3.0:3.0V PJ9500M33SE PJ9500M36SE PJ9500M12DE PJ9500M15DE DXX PJ9500M18DE PJ9500M25DE PJ9500M28DE DFN1x1-4L 7 1000 RoHS & Green MSL1 PJ9500M30DE D:Product Code e.g. D: PJ9500 Series XX:Output Voltage e.g. 30:30V PJ9500M33DE PJ9500M36DE PJ9500M12SR PJ9500M15SR PJ9500M18SR PJ9500M25SR PJ9500M28SR SOT-89-5 PJ9500M30SR PJ9500M33SR 7/13 1000/3000 RoHS & Green MSL1 9500 -XX XX:Output Voltage e.g. 3.0:3.0V PJ9500M36SR Note: 1. RoHS:PJ defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Green:PJ defines "Green" to mean Halogen-Free and Antimony-Free. www.pingjingsemi.com Revision:1.0 Oct-2023 4 / 16 PJ9500 Series Low Dropout Regulators Function Block Diagram www.pingjingsemi.com Revision:1.0 Oct-2023 5 / 16 PJ9500 Series Low Dropout Regulators Absolute Maximum Ratings Note1 Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Value Unit VIN -0.3 ~ 6 V VEN -0.3 ~ 6 V -0.3 ~ 5 V 500 mA SOT-23 300 mW SOT-89 400 mW SOT-23-3 250 mW SOT-23-5 250 mW DFN1x1-4L 250 mW SOT-89-5 400 mW SOT-23 330 °C/W SOT-89 250 °C/W SOT-23-3 400 °C/W SOT-23-5 400 °C/W DFN1x1-4L 400 °C/W SOT-89-5 250 °C/W Operating Ambient Temperature -40 ~ +125 °C Storage temperature range -40 ~ +150 °C Lead Temperature 300°C,10S -- HBM 4 KV CDM 200 V VIN,VEN to GND Voltage VOUT to VIN Voltage Maximum Load Current Power Dissipation Thermal Resistance,Junction-to-Ambient ESD Voltage Note1: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect. Recommended Operating Conditions Parameter Supply Voltage Maximum Output Current Operating Ambient Temperature www.pingjingsemi.com Revision:1.0 Oct-2023 Value Unit 1.8~6 V 500 mA -40 ~ +125 °C 6 / 16 PJ9500 Series Low Dropout Regulators Electrical Characteristics VIN=VOUT+1V, CIN=1µF, COUT=1µF, TA=25℃ , unless otherwise noted.) Parameter Input Voltage Test Conditions VIN Output Voltage Accuracy Quiescent Current Maximum Output Current Dropout Symbol Voltage Note Min. Typ. Max. Unit 1.8 -- 6 V ∆VOUT VIN=5V, IOUT=10mA -2 -- +2 % IQ VIN=5.0V, IOUT=0A -- 800 -- nA -- 500 -- mA VIN=0.98*VOUT, IOUT=100mA VOUT≥2.8V -- 120 -- mV VIN=0.98*VOUT, IOUT=100mA 1.8≤VOUT<2.8V -- 160 -- mV VIN=0.98*VOUT, IOUT=100mA VOUT=1.5V -- 190 -- mV VIN=0.98*VOUT, IOUT=100mA VOUT=1.2V -- 280 -- mV IOUT_Max VDROP Line Regulation ∆VLINE VIN=(VOUT+2V)~7V, IOUT=1mA -- 1 3 mV Load Regulation ∆VLOAD VOUT=4V, IOUT=1~200mA -- 0.1 0.2 mV/mA Short Circuit Current ISHORT -- 120 150 mA -- 700 -- mA Current Limit ILIMIT VEN=VIN VOUT Short to GND VIN=VOUT+1V EN Input Logic Low VIL -- -- 0.9 V Threshold Logic High VIH 1.2 -- -- V -- 60 -- dB -- 66 Shutdown, Temp increasing -- 129 -- °C Reset, Temp decreasing -- 105 -- °C Power Supply Rejection Rate PSRR VIN=5V, IOUT=10mA,f=1 KHz VIN= 5V, IOUT= 300mA, Output Noise Voltage eN f=10Hz to100KHz, -- μVRMS (VOUT=3.3V), COUT=1μF Thermal Shutdown Temperature Thermal Reset Temperature TSHDN Note:The dropout voltage difference is the voltage difference between the input and output, where the output voltage is 2% lower than its nominal value. www.pingjingsemi.com Revision:1.0 Oct-2023 7 / 16 PJ9500 Series Low Dropout Regulators Typical Electrical Curves TA=25°C, (unless otherwise noted) Line transient Line transient VIN=5V to 3.5V IOUT=1mA VIN=3.5V to 5V IOUT=1mA Load transient Load transient VIN=4V IOUT=100mA to 0mA VIN=4V IOUT=0mA to 100mA Power-on waveform Power-off waveform 2V/div 2V/div VIN 2V/div VIN VOUT VOUT IOUT VOUT=3.3V,VIN=5V,IOUT=0mA Time(200μs/div) www.pingjingsemi.com Revision:1.0 Oct-2023 2V/div 100mA/div VOUT=3.3V,VIN=5V,IOUT=100mA Time(400μs/div) 8 / 16 PSRR(dB) PJ9500 Series Low Dropout Regulators Frequency(Hz) www.pingjingsemi.com Revision:1.0 Oct-2023 9 / 16 PJ9500 Series Low Dropout Regulators Functional Description Input Capacitor A 1μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both VIN and GND. The input capacitor should be at least equal to, or greater than, the output capacitor for good load transient performance。 Output Capacitor An output capacitor is required for the stability of the LDO. The recommended output capacitance is from 1μF to 10μF, Equivalent Series Resistance (ESR) is from 5mΩ to 500mΩ, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to OUT and GND pins. ON/OFF Input Operation The PJ9500 EN pin is internally held low by a 1-MΩ resistor to GND. The PJ9500 is turned on by setting the EN pin higher than VIH threshold, and is turned off by pulling it lower than VIL threshold. If this feature is not used, the EN pin should be tied to IN pin to keep the regulator output on at all time. Low Quiescent Current Cellular phone baseband internal digital circuits typically operate all the time. That requires LDO stays on at all times. However, in the standby mode, the microprocessor consumes only around 100~300μA. Since the phone stays in standby for the longest percentage of time, using a 0.8μA quiescent current LDO, instead of 100μA, saves 99.2μA and can substantially extends the battery standby time. The PJ9500, consuming only 0.8μA quiescent current, provides great power saving in portable and low power applications. Current Limit Protection When output current at the OUT pin is higher than current limit threshold or the OUT pin is short-circuiting to GND, the current limit protection will be triggered and clamp the output current to a pre-set level to prevent over-current and to protect the regulator from damage due to overheating. Thermal Overload Protection The 9500 has internal thermal protection. When the temperature is too high, such as a short circuit in the output pins or a device with a very large load current and a large voltage drop, the internal thermal protection circuit will be triggered, which will shut down the power supply MOSFET and prevent LDO damage. Once the excessive thermal conditions are eliminated and the temperature of the device drops, the thermal protection circuit will restore control of the power MOSFET and allow the LDO device to enter normal operation www.pingjingsemi.com Revision:1.0 Oct-2023 10 / 16 PJ9500 Series Low Dropout Regulators Package Outline SOT-23 Dimensions in mm www.pingjingsemi.com Revision:1.0 Oct-2023 11 / 16 PJ9500 Series Low Dropout Regulators Package Outline SOT-89 Dimensions in mm www.pingjingsemi.com Revision:1.0 Oct-2023 12 / 16 PJ9500 Series Low Dropout Regulators Package Outline SOT-23-3 Dimensions in mm 1.6 2.8 ±0.1 10 0.127 +0.05/-0.02 ±0.1 ±0.1 2.92 12 R0.15MAX 0.95±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 www.pingjingsemi.com Revision:1.0 Oct-2023 13 / 16 PJ9500 Series Low Dropout Regulators Package Outline SOT-23-5 Dimensions in mm 2.92 ±0.1 1.6 2.8 ±0.1 ± 0.1 10 0.127 +0.05/-0.02 1.9±0.1 12 R0.15MAX 0.95 ±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 www.pingjingsemi.com Revision:1.0 Oct-2023 14 / 16 PJ9500 Series Low Dropout Regulators Package Outline DFN1x1-4L Dimensions in mm 0.625 BSC 1±0.05 0.25±0.05 1±0.05 05 0. 0. 5± 0. 05 5± 0. PIN1 PIN 1 0.225±0.05 TOP VIEW 0.125 BSC +0.05 0.5±0.05 BOTTOM VIEW SIDE VIEW www.pingjingsemi.com Revision:1.0 Oct-2023 15 / 16 PJ9500 Series Low Dropout Regulators Package Outline SOT-89-5 Dimensions in mm www.pingjingsemi.com Revision:1.0 Oct-2023 16 / 16
PJ9500M15SE 价格&库存
很抱歉,暂时无法提供与“PJ9500M15SE”相匹配的价格&库存,您可以联系我们找货
PJ9500M15SE
库存:59
