FLD0503-2.8YSOT235G/TR
    FULL-WAY(四方杰芯)
    SOT23-5
    FLD0503-2.8YSOT235G/TR 停产
FLD0503-2.8YSOT235G/TR 数据手册
FLD0503 500nA IQ, 300mA Low-Dropout Linear Regulator Description Features The FLD0503 ultra-low quiescent current regulator features low dropout voltage and low current in the standby mode. With less than 500nA quiescent current at no load, the FLD0503 is ideally suited for standby microcontrol-unit systems, especially for always-on applications like portable, and other battery operated systems. The FLD0503 retains all of the features that are common to low dropout regulators including a low dropout PMOS pass device, short circuit protection, and thermal shutdown. The FLD0503 has a 6V maximum operating voltage limit, a 0°C to 100° C operating temperature range, and ± 2% output voltage tolerance over the entire output current, input voltage, and temperature range. The FLD0503 is available in SOT89-3, SOT23-5, and DFN1X1 surface mount packages. ⚫ VIN Range up to 6V ⚫ Output Voltage Tolerances of ±2% Over the Temperature Range ⚫ Output Current of 300mA, Supports ⚫ Ultar Low Quiescent Current (IQ = 450mA peak Output 500nA) ⚫ Dropout Voltage Typically 400mV at IOUT =300mA ⚫ Internal Thermal Overload Protection ⚫ Internal Short-Circuit Current Limit ⚫ Ceramic Capacitor Stable APPLICATIONS ⚫ ⚫ ⚫ Portable, Battery Powered Equipment Ultra Low Power Microcontroller Notebook computers TYPICAL APPLICATION Figure 1.Typicla Application for FLD0503 http://www.full-way.com/ 1 IC your Idea, we see the Future FLD0503 Figure 2.Typicla Application for FLD0503 PIN CONFIGURATION Figure 3. Pin Assignment of FLD0503 Package SOT89-3 Figure 5. Pin Assignment of FLD0503 Package DFN1X1 Absolute Maximum Ratings ● VIN-----------------------------0.3V to +6.5V ● Junction Temperature -----------------125℃ ● Lead Temperature (Soldering, 10 sec.) -----------------------------------------------------300 ℃ ● Storage Temperature-------------------------------------------------------------65℃ to 150℃ Figure 4. Pin Assignment of FLD0503 Package SOT23-5 http://www.full-way.com/ 2 IC your Idea, we see the Future FLD0503 PIN DESCRIPTION Pin Pin Pin Pin Name No.SOT89-3 No.SOT23-5 No.DFN1X1 VOUT 3 5 1 Output Voltage Pin GND 2,4 2 2 Ground VIN 1 1 4 Input Voltage pin EN -- 3 3 Enable Pin Function FUNCTIONAL Block Diagram ELECTRICAL CHARACTERISTICS (VIN = VOUT + 1V, IOUT = 1mA, CIN = COUT = 1uF, TJ = 25℃, unless otherwise specified) Paramter Symbol Output Voltage Accuracy △VOUT Line Regulation △VLINE Load Regulation △VLOAD Dropout Voltage VDROP Conditions Min -2% mV 13 25 IOUT = 1mA to 300mA 25 40 IOUT = 100mA, VOUT = 3.3V 130 mV IOUT = 300mA, VOUT = 3.3V 400 mV TJ= 25℃ 0.5 360 Enable high level VENHI 0.6 Enable low level VENLO http://www.full-way.com/ V IOUT = 1mA to 150mA ICL Thermal Shutdown 2% 50 Current Limit PSRR Unit 20 IQ ratio Max VIN = VOUT + 1V to 5.5V Quiescent Current Power-supply rejection Typ 1 560 TSD 3 uA mA V 0.2 f = 1kHz mV V 60 dB 150 ℃ IC your Idea, we see the Future FLD0503 Thermal Shutdown Hy TSDHY 20 ℃ TYPICAL CHARACTERISTICS VIN = VOUT + 1V, IOUT = 1mA, VOUT = 3.3V, CIN = COUT = 1uF, TJ = 25℃, unless otherwise specified Fig 1. IQ vs VIN (IOUT = 0mA) Fig 2. VOUT vs VIN (IOUT = 1mA) Fig 3. VOUT vs Load Fig 4. VDROP vs Load http://www.full-way.com/ 4 IC your Idea, we see the Future FLD0503 Fig 5. VOUT vs Temperature (IOUT = 1mA) Operating Waveforms VIN=5V,VOUT=3.3V,TA=25°C,IOUT=300mA, unless otherwise specified Fig 1. VIN Power ON(IOUT=0mA) Fig 2. VIN Power ON(IOUT=300mA) CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH3:IOUT,200mA/Div,DC; TIME:1ms/Div CH3:IOUT,200mA/Div,DC; TIME:2ms/Div http://www.full-way.com/ 5 IC your Idea, we see the Future FLD0503 Fig 3. VIN Power OFF(IOUT=0mA) Fig 4. VIN Power OFF(IOUT=300mA) CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH3:IOUT, 200mA/Div,DC; TIME:5ms/Div CH3:IOUT,200mA/Div,DC; TIME:2ms/Div Fig 5. EN Power ON(IOUT=0mA) Fig 6. EN Power ON(IOUT=300mA) CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH3:IOUT,200mA/Div,DC; CH4:EN,2V/Div,DC CH3:IOUT,200mA/Div,DC; CH4:EN,2V/Div,DC TIME:1ms/Div TIME:1ms/Div Fig 7. EN Power OFF(IOUT=0mA) Fig 8. EN Power OFF(IOUT=300mA) http://www.full-way.com/ 6 IC your Idea, we see the Future FLD0503 CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC CH3:IOUT,200mA/Div,DC; CH4:EN,2V/Div,DC CH3:IOUT,200mA/Div,DC; CH4:EN,2V/Div,DC TIME:5ms/Div TIME:3ms/Div Fig 9. Load Transient (1mA to 300mA) Package Outline Dimensions(All dimensions in mm.) (1) Package Type: SOT89-3 http://www.full-way.com/ 7 IC your Idea, we see the Future FLD0503 (2)Package Type: SOT23-5 (3)Package Type: DFN1X1 http://www.full-way.com/ 8 IC your Idea, we see the Future FLD0503 http://www.full-way.com/ 9 IC your Idea, we see the Future
FLD0503-2.8YSOT235G/TR 价格&库存
很抱歉,暂时无法提供与“FLD0503-2.8YSOT235G/TR”相匹配的价格&库存,您可以联系我们找货
