SUL6018S5-18
SUL6018S5-18
    SUNTEK(洺太电子)
    SOT23-5
    是一款超小型、超低静态电流的低压差线性稳压器 (LDO),可提供 350mA 的电流,具有出色的瞬态性能。超低静态电流为 1.3μA,专为对静态电流要求极低的应用而设计。即使在降压模式下,该器件也能保...
SUL6018S5-18 数据手册
SUL6018 1.3uA, High PSRR, 350mA Low-Dropout Linear Regulator FUNCTIONAL DESCRIPTION MAIN FEATURES The SUL6018 is an ultra-small, ultra-low quiescent current low-dropout linear regulator (LDO) that can source 350mA with excellent transient performance. ⚫ ⚫ ⚫ ⚫ The SUL6018, with an ultra-low IQ of 1.3μA, is designed specifically for applications where very-low quiescent current is a critical parameter. This device maintains low IQ consumption even in dropout mode to further increase the battery life. ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ The feature of 1.3μA low quiescent current and 0.05μA shutdown current are ideal for the battery application with long service life. The other features include current limit function, over temperature protection and output discharge function. Input Voltage Range: 1.2V to 5.5V Ultra Low IQ: 1.3μA High PSRR = 85dB @1KHz Output Voltage Range: - Adjustable Mode: 0.8V to 4.5V - Fixed Mode: 0.8V~4.5V, 0.05V step. High Output Accuracy: ±1% Ultra Low Dropout Voltage: 150mV @ 350mA when VOUT ≥ 3V Low Noise: 30 μVrms Current Limit Protection Over Temperature Protection Output Active Discharge Function APPLICATIONS The SUL6018 is available SOT-23-5 and DFN-1x1-4L Packages. Standard products are Pb-free and Halogen-free. ⚫ ⚫ Portable, Battery Powered Equipment Ultra Low Power Microcontrollers ⚫ Notebook Computers ORDERING INFORMATION PART NO PACAKGE TEMPERATURE TAPE & REEL SUL6018S5-XX Note SOT23-5L -40 ~ +85℃ 3000/REEL DFN1x1-4L -40 ~ +85℃ 10000/REEL SUL6018D4-XX Note Note:XX indicates Vout. For example, 28 means product outputs 2.8V 上海洺太电子科技有限公司 -1- SUNTEK MICRO LTD PACKAGE INFORMATION & PIN DESCRIPTION 上海洺太电子科技有限公司 -2- SUNTEK MICRO LTD ABSOLUTE MAXIMUM RATINGS RECOMMENDED OPERATING CONDITIONS ELECTROSTATIC DISCHARGE THERMAL DATA 260 (SOT23-5) 250 (DFN1x1-4) 上海洺太电子科技有限公司 -3- SUNTEK MICRO LTD Electrical Characteristics (VOUT + 1 < VIN < 5.5V, TA=25℃, unless otherwise specified) 上海洺太电子科技有限公司 -4- SUNTEK MICRO LTD Typical Application Circuit Fixed Mode ADJ Mode Functional Block Diagram Current Limit IN OUT Verf Active Discharge UVLO Thermal Shutdown Internal Controller VFB (optional) EN GND 上海洺太电子科技有限公司 -5- SUNTEK MICRO LTD TYPICAL CHARACTERISTICS VOUT=1.8V, IOUT=1mA VOUT=1.2V, IOUT=1mA VOUT=0.8V VOUT=1.2V VOUT=1.2V VOUT=1.2V 上海洺太电子科技有限公司 -6- SUNTEK MICRO LTD IOUT=300mA VOUT=1.2V Power On From VIN Power Off From VIN Ch1:VIN Ch3:VOUT Ch4:IOUT Ch1:VIN Ch3:VOUT Ch4:IOUT Power On From EN Power Off From EN Ch1:VIN Ch2:EN Ch3:VOUT Ch4:IOUT Ch1:VIN Ch2:EN Ch3:VOUT Ch4:IOUT 上海洺太电子科技有限公司 -7- SUNTEK MICRO LTD Line Transient Response Load Transient Response VIN=2.2V to 3.2V, IOUT=1mA IOUT=1mA to 350mA Ch1:VIN Ch3:VOUT Ch1:VIN Ch3:VOUT Ch4:IOUT Over Current Protection Output Short Protect Ch1:VIN Ch3:VOUT Ch4:IOUT Ch1:VIN Ch3:VOUT Ch4:IOUT PSRR vs. Frequency Output Noise vs. Frequency 上海洺太电子科技有限公司 -8- SUNTEK MICRO LTD PACKAGE OUTLINE Package SOT23-5L Devices per reel 3000Pcs Unit mm Package Dimension: Ɵ D 0.2 E E1 L b e c Symbol A2 A A1 e1 Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0℃ 8℃ 0℃ 8℃ 上海洺太电子科技有限公司 -9- SUNTEK MICRO LTD PACKAGE OUTLINE Package DFN1x1-4L Devices per reel 10000Pcs Unit mm Package Dimension #1: 上海洺太电子科技有限公司 - 10 - SUNTEK MICRO LTD PACKAGE OUTLINE Package DFN1x1-4L Devices per reel 10000Pcs Unit mm Package Dimension #2: 上海洺太电子科技有限公司 - 11 - SUNTEK MICRO LTD
