LP4068H
36V/800mA Standalone Single-Cell Linear Charger
General Description
Features
Easy-to-use standalone single-cell charger
The LP4068H device is a highly advanced linear charger
High input voltage linear charger
for single-cell Li-Ion and Li-Polymer batteries. The device
Support up to 7V input voltage with 36V absolute
maximum input rating
Maximum BAT withstand voltage up to 14V
Programmable up to 800mA fast charge current
Trickle current 10% of fast charge current
Termination current 10% of fast charge current
High integration
is ideally suited for portable applications due to the small
SOT23-5
and low
number
of
external
components required.
The device employs a full charge algorithm with trickle
current, constant current (CC), constant voltage (CV)
modes, charge termination and automatic recharge. The
device
Integrated reverse blocking MOSFET
Built-in charge current sensing
Internal loop compensation
Integrated charge status indication
package
supports
charge
current
up
to
800mA,
programmed by an external resistor. The device can
withstand an input voltage up to 36V, which can protect
the charger from the accidental insertion of high voltage
and hot plug-in. The device can withstand a BAT voltage
Support full charge cycle of trickle current mode,
constant current (CC) mode, constant voltage (CV)
mode, charge termination and automatic recharge
BAT leakage current 30nA typical
Protection features
up to 14V, which is suited for power battery applications.
Without an input supply, the battery reverse current is
only 30nA typical.
The device provides various safety features for battery
charging, including input under voltage lockout (UVLO),
Input under-voltage lockout (UVLO)
Over-voltage protection (OVP)
Battery reverse connection protection
Thermal regulation foldback
RoHS Compliant and 100% Lead (Pb)-Free
Package: SOT23-5
input over-voltage protection (OVP), battery reverse
connection protection, and thermal regulation foldback
protection that is implemented by reducing the charge
current while the junction temperature reaches 140℃.
The LP4068H is available in a SOT23-5 package.
Order Information
LP4068H
Applications
Wireless Speaker
Cordless Power Tools
Gaming Devices
Portable Media Players
Handheld Battery-Powered Devices
Charging Docks and Cradles
Power Bank
E-Cigarettes
Battery Voltage
Default:4.20V
405:4.05V
F: Pb-Free
Package Type
B6: SOT23-6
LP4068H Rev0.5
www.lowpowersemi.com
Email: marketing@lowpowersemi.com
Sep.2023
Page 1 of 15
LP4068H
Device Information
Part Number
Top Marking
LP4068
YWXA0
LPS
BcYWX
LP4068HB5F
LP4068HB5F-405
Battery Voltage
Moisture Sensitivity
Level
Package
Shipping
4.20V
MSL3
SOT23-5
3K/REEL
4.05V
MSL3
SOT23-5
3K/REEL
Marking indication:
Y: Production year. W: Production week. X: Series number.
Typical Application Circuit
VIN
VBAT
IN
RIN
4.7Ω
(0603)
R1
2kΩ
BAT
COUT
1-10μF
LP4068H
Battery
CHRG
CIN
LED1
ISET
1-10μF
RISET
GND
LP4068H Rev0.5
Sep.2023
Page 2 of 15
LP4068H
Pin Diagram
SOT23-5 (Top View)
CHRG
1
ISET
5
GND
2
BAT
IN
3
4
Pin Description
Pin
Name
Description
Open-Drain Charge Status Output. When the device is in charging state, the
1
CHRG
CHRG pin is pulled low by an internal NMOS. When the charge cycle is
completed, the internal NMOS turned-off, the pin could be pulled high by an
external pull-up resistor.
2
GND
GND. Connect to the system ground.
3
BAT
Battery Pin. Connect to the battery, A 1-10µF capacitor is needed typically.
Positive Supply Voltage Input. Place a 4.7Ω resistor and a 1-10µF ceramic
4
IN
capacitor in series from IN to GND and place the components as close as
possible to IC.
5
ISET
Fast Charge Current Program Pin. Connect this pin with an external resistor
RISET to GND to program the fast charge current.
LP4068H Rev0.5
Sep.2023
Page 3 of 15
LP4068H
Absolute Maximum Ratings
(1)
IN to GND -------------------------------------------------------------------------------------------------------- -0.3V to 36V
CHRG to GND -------------------------------------------------------------------------------------------------- -0.3V to 28V
BAT to GND -------------------------------------------------------------------------------------------------------- -5V to 14V
ISET to GND ----------------------------------------------------------------------------------------------------- -0.3V to 6.5V
Maximum Junction Temperature (TJ) ----------------------------------------------------------------------------- 150℃
Storage Temperature -------------------------------------------------------------------------------------- -55℃ to 150℃
Maximum Soldering Temperature (at leads, 10 sec) --------------------------------------------------------- 260℃
Note: (1) Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device
reliability.
ESD Susceptibility
HBM (Human Body Model) --------------------------------------------------------------------------------------------- 2kV
MM (Machine Model) -------------------------------------------------------------------------------------------------- 200V
Recommended Operating Conditions
Input Voltage ------------------------------------------------------------------------------------------------------ 4.5V to 6V
Maximum Charge Current ------------------------------------------------------------------------------------------ 800mA
Operating Junction Temperature Range (TJ) --------------------------------------------------------- -20℃ to 140℃
Operating Ambient Temperature Range (TA) --------------------------------------------------------- -20℃ to 85℃
LP4068H Rev0.5
Sep.2023
Page 4 of 15
LP4068H
Electrical Characteristics
(The specifications are at TA=25℃, VIN = 5V, unless otherwise noted.)
Symbol
Parameter
Condition
Min
Typ
Max
Units
4.5
5
6
V
INPUT VOLTAGE AND CURRENT
VIN
Input Voltage Range
IStandby
Input Standby Current
Standby mode
(Charge terminated)
VUVLO
Under Voltage
Lockout of VIN
VIN Rising
VUVLO_HYS
VOVP
VUVLO Hysteresis
Over-Voltage Protection
Threshold Voltage
VIN Falling
OVP Hysteresis
VIN Falling
VOVP_HYS
VIN Rising
190
3.3
3.5
μA
3.7
V
200
6.7
7
mV
7.3
V
300
mV
BATTTERY CHARGER
VFLOAT
ICC
Regulated Output
Voltage
Fast Charge Current
LP4068HB5F
4.179
4.2
4.24
V
LP4068HB5F-405
4.01
4.05
4.09
V
RISET=3.4kΩ, Constant
Current Mode
450
500
550
mA
RISET=17kΩ, Constant
Current Mode
90
100
110
mA
ITERM
Termination Current
Threshold
Voltage Mode
10%
ICC
ITRIKL
Trickle Charge Current
VBAT
很抱歉,暂时无法提供与“LP4068HB5F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75125
- 50+0.54045
- 150+0.41728
- 500+0.36952
- 3000+0.33121
- 6000+0.31213
- 国内价格
- 1+0.51920
- 200+0.33550
- 1500+0.29040
- 3000+0.25740
