SL9650 Series
Low Dropout Regulators
SOT-23
Description
3.VIN
The SL9650 Series is a low dropout, positive linear regulator with very low
quiescent current. It can supply 600mA output current with a input range from
1.7V to 7V, which makes it suitable for all kinds of applications.
SL9650 Series use advanced CMOS technology to achieve very low dropout
1.GND
voltage (300mV @600mA). Fast structural design achieves 75dB PSRR at 1kHz
2.VOUT
SOT-23-3
while still maintaining a small 50uA quiescent current.
3.VIN
Trimming technique is used to guarantee output voltage accuracy within ±2%
(Fixed Output); ±1%(Adjustable Output). SL9 650 Series provides full fault protection
including current limit, short circuit protection and thermal shutdown protection.
Features
⚫ Fixed Output Voltages:
1.GND
0.7V,1.0V,1.2V,1.5V,1.8V,2.5V,2.8V,3.0V,3.3V,3.6V,Other output can be customized
2.VOUT
⚫ Adjustable Output from 0.6V to (VIN-VDROP)
⚫ Maximum Output Current:600mA
SOT-89-5
SOT-89
⚫ Input Voltage Range:1.7V~7V
⚫ Low Quiescent Current:50uA(Typ.)
4.VIN
5.VOUT
2.VIN
⚫ Very low dropout voltage:
300mV@600mA(Vout=3.3V)
⚫ Highly Accurate:±2%(Fixed Output)
⚫ 0.02%/V Line Regulation
1.NC
1.GND 2.VIN 3.VOUT
2.GND 3.EN
⚫ Auto discharge function
⚫ 75dB PSRR @ 1KHz
SOT-23-5 Fixed
⚫ -40°C~125°C Wide Operating Temperature
5. VOUT
⚫ 2000V HBM ESD
SOT-23-5 ADJ
4. NC
5. VOUT
3.EN
1.VIN
4. FB
⚫ 150 °C Thermal Protection
Applications
⚫ Battery powered portable devices
⚫ Smart phone, tablet
1.VIN
2.GND
2.GND
3.EN
⚫ Hi resolution camera sensor power
⚫ Wireless modules
DFN2x2C-6L
DFN1x1-4L
⚫ RF,PLL,VCO clock power
Bottom View
Bottom View
3.EN
2.GND
GND
4.VIN
1.VOUT
www.slkormicro.com
1
6. FB
1.EN
5.NC
2.GND
4.VOUT
3.VIN
Rev.1 -- 20 August 2017
SL9650 Series
Functional Pin Description
Pin Name
Pin Function
VIN
Power Input Voltage
GND
Ground
EN
Chip Enable (Active High). Note that this pin is high impedance
NC
NO Connected
FB
Feedback Pin (adjustable voltage version only). Connect this pin to the midpoint of
an external resistor divider to adjust the output voltage
VOUT
Output Voltage
Marking Code
2.DFN
1.SOT
9650
-XX
BXX
B:Product Code
XX:Output Voltage
e.g. 30:3.0V
XX:Output Voltage
e.g. 3.0:3.0V
AJ:ADJ
Ordering Information
SL9650
Package Type
SA:SOT-23 SC:SOT-23-3
SQ:SOT-89 SR:SOT-89-5
SE:SOT-23-5 DE:DFN1x1-4L
DFC:DFN2x2C-6L
Fixed Output Voltage Version
10 : 1.0V 12 : 1.2V 15 : 1.5V
18 : 1.8V 25 : 2.5V 28 : 2.8V
30 : 3.0V 33 : 3.3V 36 : 3.6V
ADJ:Adjustable Output Voltage Version
Output current tap
M : 600mA
www.slkormicro.com
2
SL9650 Series
Function Block Diagram(Package in SOT-23-5)
5
1
VIN
Current Limit
VOUT
4
NC
3
Enable
EN
TSD
Bandgap
2
GND
VIN
1
5
VOUT
Current Limit
3
EN
4
Enable
Bandgap
TSD
www.slkormicro.com
3
2
FB
GND
SL9650 Series
Typical Application Circuit
VIN
CIN
1F
VOUT
VIN
VOUT
EN
NC
GND
COUT
1F
VOUT
VIN
VIN
VOUT
R1
FB
EN
CIN
1F
GND
COUT
1F
R2
Note:
1. Input capacitor (CIN=1uF) and Output capacitor (COUT=1uF) are recommended in all application circuit.
2. VOUT=VFB x (1+R1/R2),VFB=0.6V.
www.slkormicro.com
4
SL9650 Series
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Value
Unit
Maximum Input Voltage
8.5
V
Output Current
600
mA
SOT-23
350
mW
SOT-89
590
mW
SOT-23-3
450
mW
SOT-23-5
450
mW
DFN1x1-4L
550
mW
SOT-23
280
°C/W
SOT-89
170
°C/W
SOT-23-3
220
°C/W
SOT-23-5
220
°C/W
DFN1x1-4L
180
°C/W
Maximum Junction Temperature
150
°C
Operating Ambient Temperature
-40 ~ +125
°C
Storage Temperature Range
-55~ +150
°C
Lead Temperature&Time
260°C,10S
Power Dissipation
Thermal Resistance,Junction-to-Ambient
Note1: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect.
Recommended Operating Conditions
Parameter
Supply Voltage
www.slkormicro.com
5
Value
Unit
1.7~7
V
600
mA
-40 ~ +125
°C
SL9650 Series
Electrical Characteristics
CIN=1µF, COUT=1µF, TA=25℃ , unless otherwise noted.)
Parameter
Symbol
Input Voltage
Test Conditions
VIN
Min.
Typ.
Max.
Unit
1.7
7
V
VIN=VOUT+1V
VOUT
1mA
很抱歉,暂时无法提供与“SL9650MADJSE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.28901
- 6000+0.28420
- 12000+0.27697
- 24000+0.26493
