HG8805M5/TR
HG8805M5/TR
    HGSEMI(华冠)
    SOT23-5
    1.2V~6V 600MA 8V
HG8805M5/TR 数据手册
HG8805 600mA LOW DROPOUT CMOS VOLTAGE REGULATORS FEATURES  Maximum output current 600mA  Highly accurate output voltage: +/-1.5%  Low power consumption  On-chip protections: thermal, short-circuit  Small input/output differential: 600mV at 600mA  Adjustable version SOT23-5 SOT-223 SOT89-5 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty 8805 REEL 3000pcs/reel 8805-12 REEL 3000pcs/reel 8805-18 REEL 3000pcs/reel 8805-25 REEL 3000pcs/reel HG8805M5-2.6/TR 8805-26 REEL 3000pcs/reel HG8805M5-3.3/TR 8805-33 REEL 3000pcs/reel HG8805MP-1.2/TR 8805-12 REEL 1000pcs/reel HG8805MP-1.8/TR 8805-18 REEL 1000pcs/reel 8805-25 REEL 1000pcs/reel HG8805MP-2.6/TR 8805-26 REEL 1000pcs/reel HG8805MP-3.3/TR 8805-33 REEL 1000pcs/reel HG8805MK-1.2/TR 8805-12 REEL 2000pcs/reel HG8805MK-1.8/TR 8805-18 REEL 2000pcs/reel 8805-25 REEL 2000pcs/reel HG8805MK-2.6/TR 8805-26 REEL 2000pcs/reel HG8805MK-3.3/TR 8805-33 REEL 2000pcs/reel HG8805M5/TR HG8805M5-1.2/TR HG8805M5-1.8/TR HG8805M5-2.5/TR HG8805MP-2.5/TR HG8805MK-2.5/TR http://www.hgsemi.com.cn SOT23-5L SOT-223 SOT89-5 1/9 2020 SEP HG8805 PRODUCT DESCRIPTION The HG805 series is a low-dropout linear regulator. This device is designed specifically for battery-operated systems. Its ground current is very small - 50 A (typ.) that significantly extends the battery life. The low power consumption and high accuracy are achieved through CMOS and programmable fuse technologies. Its versions are HG8805-adj (Vref=1.27V),HG8805 -1.2, HG8805 -1.8, HG8805 -2.5, HG8805 -2.6, HG8805 -3.3. It is possible to extend the output voltage range from 1.2V to 6.0V. The AME8805 consists of a high-precision voltage reference, an error-correction circuit, and a current-limited output driver. With good transient responses the device output remains stable even when the load changes. The EN (Shutdown) input enables the output to be turned off resulting in reduced power consumption. The HG8805 can stably work with cheap MLCC output capacitors. Owing to high ripple rejection ratios, the AME8805 series can be used in the case of a power supply with noise. A 470pF capacitor from the BP (bypass) input to the ground reduces the noise, which is present on the internal reference, and that, in turn, significantly reduces the output noise. If that noise is not a concern, the said input may be left unconnected. Larger CBP capacitor values may be used, but that extends a time period until the rated output voltage is reached after the power has been initially applied. The HG8805 incorporates both over-temperature and over-current protections. The small packages - SOT23-5 (300mW) and SOT-89 (500mW) - are usable too. APPLICATIONS  Battery-operated systems  Portable computers  Portable cameras and video recorders  Reference voltage sources  Instrumentation  Pagers http://www.hgsemi.com.cn 2/9 2020 SEP HG8805 PIN CONFIGURATION ABSOLUTE MAXIMUM RATINGS Input voltage Output current Output voltage PARAMETER Continuous total powerdissipation Operating ambient temperature Storage temperature SYMBOL RATING Vin Iout Vout SOT-23-5 SOT-89 SOT-223 UNIT 8 1 -0.3 to Vin+0.3 300 500 625 -40 to +125 -40 to +125 PD TOpr TSTG V A V mW ℃ ℃ ELECTRICAL CHARACTERISTICS (At TA = 25℃, Vin = Vout (nominal)+1V, unless otherwise noted) PARAMETER CONDITIONS MIN Output voltage accuracy Reference voltage in Adj version Iout = 1mA Iout = 1 to 600mA -1.5 -3 Line Regulation Vout/VinVout Iout =1mA, (Vout+1V) < Vin < 6.5V -0.3 Load regulation (Note1) 1mA ≤ Iout ≤ 600mA, Cout = 1µF Dropout voltage for Vout > 2.8V 2.0V < Vout ≤ 2.8V Vout ≤ 2.0V Maximum output current Iout = 600mA Vout > 0.96*Vrating PSRR Output voltage noise CBP = 0µF, Cout = 1 VEN = Vin VEN = Gnd VEN = Gnd FIout =-100mA UNIT +1.5 +2 % 0.05 0.3 %/V Fig.1 0.5 1.5 % Fig.2 600 800 1300 750 1000 1600 mV mA 1300 mA 600 µsec nA µA µA V V µA °C °C ppm 100 -1 Vin = 2.5 to 5.5V Vin = 2.5 to 5.5V Iout = 0mA to 600mA Iout = 10mA Iout = 10mA Iout = 10mA Iout =100mA,Cout = 2.2µF, f = 100Hz f = 20Hz to 100kHz Iout = 10mA TEST CIRCUIT MAX 600 Current limit EN exit delay EN input bias current EN input Low current EN supply current EN input threshold Low EN input threshold High Gnd (Ground) pin current Over-temperature shutdown Over-temperature hysteresis VOUT temperature coefficient TYP -0.3 0.01 1 0.4 2 50 155 10 30 85 55 dB 12 µVrms Fig.3 Note: The Load regulation is measured by using pulse techniques with the duty cycle < 5% The Reference voltage nominal value of the adjustable version is 1.27V http://www.hgsemi.com.cn 3/9 2020 SEP HG8805 TEST CIRCUITS HG8805 HG8805 Fig.1. Line regulation Fig.2. Load regulation HG8805 Fig.3. Ground current TYPICAL CHARACTERISTICS http://www.hgsemi.com.cn 4/9 2020 SEP HG8805 Functional Block Diagram http://www.hgsemi.com.cn 5/9 2020 SEP HG8805 http://www.hgsemi.com.cn 6/9 2020 SEP HG8805 Physical Dimensions SOT23-5 Dimensions In Millimeters(SOT23-5) A A1 B C C1 D Min: 1.05 0.00 2.82 2.65 1.50 0.30 0° 0.30 Max: 1.15 0.15 3.02 2.95 1.70 0.60 8° 0.40 Symbol: Q a b e 0.95 BSC 1.90 BSC SOT89-5 B d e D C C1 A a L b Dimensions In Millimeters(SOT89-5) A B C C1 D L a b d e Min: 1.40 4.40 4.25 2.30 0.90 0.35 0.40 1.50 3.0 1.55 Max: 1.60 4.60 4.65 2.60 1.20 0.44 0.55 BSC BSC BSC Symbol: http://www.hgsemi.com.cn 7/9 2020 SEP HG8805 Physical Dimensions SOT223 Dimensions In Millimeters(SOT223) A A1 B C C1 D Min: 1.50 0.05 6.30 6.70 3.30 0.65 0° 0.66 Max: 1.70 0.20 6.70 7.30 3.70 1.10 8° 0.84 Symbol: http://www.hgsemi.com.cn 8/9 Q a b e 2.30 BSC 3.00 BSC 2020 SEP HG8805 IMPORTANT STATEMENT: Huaguan Semiconductor reserves the right to change its products and services without notice. Before ordering, the customer shall obtain the latest relevant information and verify whether the information is up to date and complete. Huaguan Semiconductor does not assume any responsibility or obligation for the altered documents. Customers are responsible for complying with safety standards and taking safety measures when using Huaguan Semiconductor products for system design and machine manufacturing. You will bear all the following responsibilities: select the appropriate Huaguan Semiconductor products for your application; Design, validate and test your application; Ensure that your application meets the appropriate standards and any other safety, security or other requirements. To avoid the occurrence of potential risks that may lead to personal injury or property loss. Huaguan Semiconductor products have not been approved for applications in life support, military, aerospace and other fields, and Huaguan Semiconductor will not bear the consequences caused by the application of products in these fields. The technical and reliability data (including data sheets), design resources (including reference designs), application or other design suggestions, network tools, safety information and other resources provided for the performance of semiconductor products produced by Huaguan Semiconductor are not guaranteed to be free from defects and no warranty, express or implied, is made. The use of testing and other quality control technologies is limited to the quality assurance scope of Huaguan Semiconductor. Not all parameters of each device need to be tested. The documentation of Huaguan Semiconductor authorizes you to use these resources only for developing the application of the product described in this document. You have no right to use any other Huaguan Semiconductor intellectual property rights or any third party intellectual property rights. It is strictly forbidden to make other copies or displays of these resources. You should fully compensate Huaguan Semiconductor and its agents for any claims, damages, costs, losses and debts caused by the use of these resources. Huaguan Semiconductor accepts no liability for any loss or damage caused by infringement. http://www.hgsemi.com.cn 9/9 2020 SEP
HG8805M5/TR 价格&库存
很抱歉,暂时无法提供与“HG8805M5/TR”相匹配的价格&库存,您可以联系我们找货
