XC6219B152MR-MS
XC6219B152MR-MS
    MSKSEMI(美森科)
    SOT23-5
    1.5V 300MA 8V
XC6219B152MR-MS 数据手册
XC6219 Product specification XC6219 General Description The XC6219 series are highly accurate, low noise, CMOS LDO Voltage Regulators.Offering low output noise, high ripple rejection ratio,low dropout and very fast turn-on times, the XC6219 series is ideal for today’s cutting edge mobile phone. Internally the XC6219 includes a reference voltage source, error a mplifiers, driver transistors, current limiters and phase compensators. The output voltage is set by current trimming. Voltages are selectable in 1 0 0 mV steps within a ran ge of 1.2V to 5.0V. The XC6219 series is also fully compatible with low ESR ceramic capacitors,reducing cost and improving output stability.This high level of output stability is maintained even during fr equent load fluctuations,due to the excellent transient response performance and high PSRR achieved across a broad range of frequencies.The CE function allows the output of regulat or to be turned off,resulting in greatly reduced power consumption. Features Application  Low power consumption:40uA (Typ.)  Battery-powered equipment  Low voltage drop:  Communication equipment 0. 12V@ 100mA@VOUT=3.3V(Typ.)  Mobile phones  Standby Mode: 0. 1uA  Portable games  Low temperature coefficient  Cameras, Video cameras  High input voltage (up to 8V)  Reference voltage sources  Output voltage accuracy: tolerance ±2%  SOT23-5、SOT89package Reference News PACKAGE OUTLINE SOT-23-5 Copyright© Msksemi Incorporated Block Diagram SOT-89 www.msksemi.com XC6219 Ordering Information XC6219 brand identity MR:SOT-23-5 PR :SOT-89 serie Without pull-down accuracy resistor Output voltage Item number package Output voltage Item number package Output voltage XC6219B122MR-MS SOT-23-5 1.2V XC6219B122PR-MS SOT-89 1.2V XC6219B152MR-MS SOT-23-5 1.5V XC6219B152PR--MS SOT-89 1.5V XC6219B182MR-MS SOT-23-5 1.8V XC6219B182PR--MS SOT-89 1.8V XC6219B252MR-MS SOT-23-5 2.5V XC6219B252PR--MS SOT-89 2.5V XC6219B282MR-MS SOT-23-5 2.8V XC6219B282PR--MS SOT-89 2.8V XC6219B302MR-MS SOT-23-5 3V XC6219B302PR--MS SOT-89 3V XC6219B332MR-MS SOT-23-5 3.3V XC6219B332PR-MS SOT-89 3.3V Copyright© Msksemi Incorporated www.msksemi.com XC6219 Package and Pin assignment SOT23-5 (Top View) PIN NUMBER SYMBOL FUNCTION 1 VIN Power Input Pin 2 GND Ground 3 CE Chip Enable Pin 4 NC No Connection 5 VOUT Output Pin SOT89 (Top View) PIN NUMBER SYMBOL FUNCTION 1 GND Ground 2 VIN Power Input Pin 3 VOUT Output Pin Absolute Maximum Ratings Supply Voltage -0.3V to 8V Operating Temperature Storage Temperature ..................-50C to 125C -40C to 85C Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute Maximum Ratings” may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. Thermal Information Symbol Parameter Thermal Resistance ( Junction to θJA PD Ambient) (Assume no ambient airflow, no heat sink) Power Dissipation Package Max. SOT23-5 500 SOT89 200 SOT23-5 0.25 SOT89 0.5 Unit ℃/W W Note:PDismeasuredatTa=25℃ Copyright© Msksemi Incorporated www.msksemi.com XC6219 Electrical Characteristics XC6219 series Parameter (Ta=25℃) Symbol Conditions Vin=Vout+1V Output Voltage Vout Output Current* 1 Iout Vin-Vout=1V Line Regulation △Vout1/ (△Vin·Vout) 4.3V≤Vin≤8V Load Regulation △Vout Output voltage Temperature △Vout/(Ta· Vout) Coefficiency Supply Current Iss1 Input Voltage Vin PSRR PSRR 1.0mA≤ Iout≤30mA Iout=10mA Min. Vout×0.98 Iout=30mA 0 C≤ Ta≤ 7 0 C --F=1KHz, Vin=4.3Vdc+1Vpp -- Max. Vout×1.02 Unit V -- 350 -- mA -- 0.05 0.2 %/V -- 10 30 Vin= 4.3V 1.0mA≤ Iout≤100mA Typ. -- ± 100 -- V Ppm/ C -- 40 -- uA -- -- 8 V -- 60 -- dB TypicalApplicationCircuit Copyright© Msksemi Incorporated www.msksemi.com XC6219 Operational Explanation The P-channel MOSFET is connected to the VOUT pin, driven by the subsequent output signal. The output voltage at the VOUT pin is controlled and stabilized by a system of negative feedback. The IC's internal circuitry can shut-down by the CE pin's signal With the XC6219 series, a stable output voltage is achievable even if used with low ESR capacitors as a phase compensation circuit is built-in. In order to ensure the effectiveness of the phase compensation, we suggest that an output capacitor (CL) is connected as close as possible to the output pin (VOUT) and the GND pin. Please use an output capacitor with a capacitance value of at least 10uF. Also, please connect an input capacitor (CIN) of 10uF between the VIN pin and the GND pin in order to ensure a stable power input. Stable phase compensation may not be ensured if the capacitor runs out capacitance when depending on bias and temperature. In case the capacitor depends on the bias and temperature, please make sure the capacitor can ensure the actual capacitance. The IC's internal circuitry can be shutdown via the signal from the CE pin with the XC6219 series. The operational logic of the IC's CE pin is selectable (please refer to the selection guide). Although the CE pin is equal to an inverter input with CMOS hysteresis, with either the pull-up or pull-down options, the CE pin input current will increase when the IC is in operation. We suggest that you use this IC with either a VIN voltage or a VSS voltage input at the CE pin. If this IC is used with the correct specifications for the CE pin, the operational logic is fixed and the IC will operate normally. However, supply current may increase as a result of through current in the IC's internal circuitry. Notes on Use 1. Please use this IC within the stated absolute maximum ratings. The IC is liable to malfunction should the ratings be exceeded. 2. Where wiring impedance is high, operations may become unstable due to noise and/or phase lag depending on output current. Please keep the resistance low between VIN and VSS wiring in particular. 3. Please wire the input capacitor (CIN) and the output capacitor (CL) as close to the IC as possible. Copyright© Msksemi Incorporated www.msksemi.com XC6219 SOT-23-5 Package Outline Dimensions Symbol Dimensions In Millimeters Min. Dimensions In Inches Max. Min. Max. A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 b 1.050 1.150 0.041 0.045 0.300 0.500 0.012 0.020 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 2.650 2.950 0.104 0.116 E1 e 1.500 1.700 0.950(BSC) 0.059 0.067 0.037(BSC) e1 1.800 2.000 0.071 0.079 L θ 0.300 0.600 0.012 0.024 0° 8° 0° 8° c SOT-23-5L Suggested Pad Layout Copyright© Msksemi Incorporated www.msksemi.com XC6219 SOT-89 Package Outline Dimensions Symbol A b b1 c D D1 E E1 e Dimensions Min 1.400 0.320 0.400 0.350 4.400 Millimeters Ma x Dimensions Inches Ma x 1.600 0.520 0.580 0.063 0.020 0.023 0.440 4.600 0.014 0.173 0.017 0.181 2.600 4.250 0.091 0.155 0.061 REF. 1.500 TYP . 3.000 TYP . 0.900 In Min 0.055 0.013 0.016 1.550 REF. 2.300 3.940 e1 L In 0.102 0.167 0.060 TYP. 0.118 TYP. 1.200 0.035 0.047 SOT-89 Suggested Pad Layout Copyright© Msksemi Incorporated www.msksemi.com XC6219 Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
XC6219B152MR-MS 价格&库存
很抱歉,暂时无法提供与“XC6219B152MR-MS”相匹配的价格&库存,您可以联系我们找货
XC6219B152MR-MS
  • 20+0.22279
  • 200+0.17613
  • 600+0.15280
  • 3000+0.13531
  • 9000+0.12131
  • 21000+0.11421
库存:1485
