EA8101T5R
EA8101T5R
    EVERANALOG(申风)
    SOT23-5
    降压型 1A 2.5V~5.5V
EA8101T5R 数据手册
1A, 1.5MHz, High Efficiency Synchronous Buck Converter EA8101 Datasheet General Description The EA8101 is a high switching frequency, high efficiency synchronous buck regulator, designed to operate from 2.5V to 5.5V input voltage range. Built-in low RDS(ON) high/low side Power-MOSFETS not only reduce external components and has up to 95% efficiency, ideal for 1A output current applications. The EA8101 features 100% duty cycle low dropout operation, extending battery life in portable systems. Besides, this device is designed to take into account the light load mode operation and can provide high efficiency over a wide range of the load current. The internal compensation design not only allows users to more simplified application, and can reduce the cost of external components. The EA8101 is available in the SOT-23-5 and TSOT-23-5 packages and easy to use. Features               Built-in Low RDS(ON) Power-MOSFETS Efficiency Up to 95% 2.5V to 5.5V Input Voltage Range Adjustable Output Voltage Range from 0.6V to Vin Fixed 1.5MHz Switching Frequency 1A Continuous Load Current 100% Duty Cycle Low Dropout Operation 45uA Low Quiescent Current
