RS3219-1.8YF5
RS3219-1.8YF5
    RUNIC(润石)
    SOT23-5
    1.8V 300MA 7.5V
RS3219-1.8YF5 数据手册
RS3219 Low Power, Low Dropout, 300-mA Low-Noise, Low-IQ LDO FEATURES DESCRIPTION  Low Output Noise The RS3219 series low-power, low-dropout, CMOS LDO operate from 1.7V to 7.5V input voltage that can supply up to 300 mA of output current. Designed to meet the requirements of RF and analog circuits, the RS3219 series device provides low noise, high PSRR, low quiescent current, and low line and load transient response. The device is designed to work with a 1-µF input and a 1-µF output ceramic capacitor. Other features include a 10nA logic-controlled shutdown mode and thermal shutdown protection. The RS3219 series is available in Green SOT23-3, SOT23-5 and UTDFN-1x1-4 packages. It operates over an ambient temperature range of -40°C to +85°C.  Low Dropout Voltage  Thermal-Overload Protection  10nA Logic-Controlled Shutdown  Available in Multiple Output Voltage Versions  Fixed Outputs of 1.2V, 1.5V, 1.8V, 2.5V, 2.8V, 3.0V,3.3V APPLICATIONS  Cellular Telephones  Camera Modules  Sensors  HiFi Audio Radio Transceivers Device Information (1)  PLL/Synthesizer, Clocking PART NUMBER  Medium-Current, Noise-Sensitive Applications RS3219 (1) UTDFN-1×1-4 BODY SIZE (NOM) 1.00mm×1.00mm SOT23-3 1.60mm×2.92mm SOT23-5 1.60mm×2.92mm PACKAGE For all available packages, see the orderable addendum at the end of the data sheet. Functional Block Diagram IN OUT 1.2V VREF Error amp Internal Controller Thermal Shutdown EN NC GND REV B.2 1 / 15 Copyright © 2017, RUNIC Technology www.run-ic.com RS3219 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date B.0 2019/03/24 B.1 2020/01/15 B.2 2021/11/18 Change Item Initial version completed 1) Added output voltage 2) Added SOT23-3 package Change SOT23-5 and SOT23-3 Thermal Information on Page 6 @B.1 Version. 2 / 15 www.run-ic.com RS3219 Pin Configuration and Functions (Top View) (TOP VIEW) (TOP VIEW) 1 IN 5 OUT GND 2 EN UTDFN-1×1-4 UTDFN-1×1-4 NUMBER NAME DESCRIPTION OUT O Regulator Output. 2 GND G Ground. 3 EN I 4 IN I - - Enable Input. A logic low reduces the supply current to 10nA. Connect to IN for normal operation. Regulator Input. Supply voltage can range from 1.7V to 7.5V. Bypass with a 1μF capacitor to GND. Connect the thermal pad to a large-area ground plane. This pad is not an electrical connection to the device ground. SOT23-5 NUMBER NAME 4 NC SOT23-5 I/O 1 Thermal Pad 3 DESCRIPTION I/O 1 IN I Regulator Input. Supply voltage can range from 1.7V to 7.5V. Bypass with a 1μF capacitor to GND. 2 GND G Ground. 3 EN I Enable Input. A logic low reduces the supply current to 10nA. Connect to IN for normal operation. 4 NC - No internal connect. 5 OUT O Regulator Output. 3 / 15 www.run-ic.com RS3219 Pin Configuration and Functions (Top View) (TOP VIEW) GND 1 3 OUT IN 2 SOT23-3 SOT23-3 NUMBER NAME DESCRIPTION I/O 1 GND G Ground. 2 OUT O Regulator Output. 3 IN I Regulator Input. Supply voltage can range from 1.7V to 7.5V. Bypass with a 1μF capacitor to GND. 4 / 15 www.run-ic.com RS3219 PACKAGE/ORDERING INFORMATION MODEL VOUT(V) PIN- PACKAGE ORDERING NUMBER PACKAGE MARKING(1) PACKAGE OPTION RS3219-1.2 1.2V UTDFN-1x1-4 RS3219-1.2YUTDN4 AC Tape and Reel, 10000 RS3219-1.5 1.5V UTDFN-1x1-4 RS3219-1.5YUTDN4 AD Tape and Reel, 10000 RS3219-1.8 1.8V UTDFN-1x1-4 RS3219-1.8YUTDN4 AE Tape and Reel, 10000 RS3219-2.5 2.5V UTDFN-1x1-4 RS3219-2.5YUTDN4 AG Tape and Reel, 10000 RS3219-2.8 2.8V UTDFN-1x1-4 RS3219-2.8YUTDN4 AH Tape and Reel, 10000 RS3219-3.0 3.0V UTDFN-1x1-4 RS3219-3.0YUTDN4 AI Tape and Reel, 10000 RS3219-3.3 3.3V UTDFN-1x1-4 RS3219-3.3YUTDN4 AJ Tape and Reel, 10000 RS3219-1.2 1.2V SOT23-5 RS3219-1.2YF5 LA12 Tape and Reel, 3000 RS3219-1.5 1.5V SOT23-5 RS3219-1.5YF5 LA15 Tape and Reel, 3000 RS3219-1.8 1.8V SOT23-5 RS3219-1.8YF5 LA18 Tape and Reel, 3000 RS3219-2.5 2.5V SOT23-5 RS3219-2.5YF5 LA25 Tape and Reel, 3000 RS3219-2.8 2.8V SOT23-5 RS3219-2.8YF5 LA28 Tape and Reel, 3000 RS3219-3.0 3.0V SOT23-5 RS3219-3.0YF5 LA30 Tape and Reel, 3000 RS3219-3.3 3.3V SOT23-5 RS3219-3.3YF5 LA33 Tape and Reel, 3000 RS3219-1.2 1.2V SOT23-3 RS3219-1.2YF3 LA12 Tape and Reel, 3000 RS3219-1.5 1.5V SOT23-3 RS3219-1.5YF3 LA15 Tape and Reel, 3000 RS3219-1.8 1.8V SOT23-3 RS3219-1.8YF3 LA18 Tape and Reel, 3000 RS3219-2.5 2.5V SOT23-3 RS3219-2.5YF3 LA25 Tape and Reel, 3000 RS3219-2.8 2.8V SOT23-3 RS3219-2.8YF3 LA28 Tape and Reel, 3000 RS3219-3.0 3.0V SOT23-3 RS3219-3.0YF3 LA30 Tape and Reel, 3000 RS3219-3.3 3.3V SOT23-3 RS3219-3.3YF3 LA33 Tape and Reel, 3000 NOTE: (1) There may be additional marking, which relates to the lot trace code information (include data code and vendor code), the logo or the environmental category on the device. 5 / 15 www.run-ic.com RS3219 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) (2) MIN MAX UNIT VIN Input voltage -0.3 8 V VOUT Output voltage -0.3 VIN + 0.3 V VEN Enable input voltage -0.3 VIN V TJ Junction temperature 150 °C dissipation (3) PD Continuous power Tstg Storage temperature (1) (2) (3) W Internally Limited -65 °C 150 Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltages are with respect to the GND pin. Internal thermal shutdown circuitry protects the device from permanent damage. ESD Ratings VALUE V(ESD) Electrostatic discharge UNIT Human-body model (HBM) ±6000 V Machine model (MM) ±500 V Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) (1) MIN MAX UNIT VIN Input supply voltage 1.7 7.5 V VOUT Output voltage 1.2 5 V VEN Enable input voltage 0 VIN V IOUT Output current 0 300 mA TJ Junction temperature -40 85 °C UNIT (1) All voltages are with respect to the GND pin. Thermal Information RS3219 THERMAL METRIC SOT23-5 SOT23-3 UTDFN-1x1-4 5 PINS 3 PINS 4 PINS RθJA Junction-to-ambient thermal resistance 250 312.5 312.5 °C/W RθJC(top) Junction-to-case (top) thermal resistance 84.3 134.3 137.9 °C/W RθJB Junction-to-board thermal resistance 39.5 84.5 83.5 °C/W ψJT Junction-to-top characterization parameter 2.86 4.8 5.3 °C/W ψJB Junction-to-board characterization parameter 58.7 81.5 83.8 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance N/A N/A 71.8 °C/W Pd Power Dissipation 0.5 0.4 0.4 W 6 / 15 www.run-ic.com RS3219 ELECTRICAL CHARACTERISTICS (VIN = VOUT (NOMINAL) + 0.5V (1), Full = -40℃ to +85℃, unless otherwise noted.) PARAMETER SYMBOL Input Voltage CONDITIONS TEMP VIN Output Voltage Accuracy (1) Maximum Output Current IOUT = 0.1mA (1) Ground Pin Current IQ No load, EN = VIN IOUT = 300mA ,VOUT=3.3V TYP MAX UNITS +25°C 1.7(1) 7.5 V +25°C -2.5 +2.5 % +25°C 300 +25°C IOUT = 1mA ,VOUT=3.3V Dropout Voltage (2) MIN mA 120 200 0.95 +25°C 280 400 0.09 µA mV Line Regulation (1) ΔVLNR VIN = 1.7V or (VOUT + 0.5V) to 5.5V, IOUT = 1mA +25°C 0.03 Load Regulation ΔVLDR IOUT =0.1mA to 300mA, COUT = 1µF, +25°C 0.002 0.005 f = 0.1Hz to 10Hz, COUT = 1µF +25°C 38 µVPP ILOAD = 50mA, COUT = 1μF, VIN = VOUT+1V f = 217Hz +25°C 56 dB f = 1kHz +25°C 55 dB Output Voltage Noise en Power Supply Rejection Ratio SHUTDOWN PSRR %/V %/mA (3) VIH VIL EN Input Threshold VIH VIL Full VIN = 1.7V Full Full VIN = 7.5V IB(SHDN) EN = 0V or EN = VIN Shutdown Supply Current IQ(SHDN) EN = 0.4V Shutdown Exit Delay 0.3 2.0 Full EN Input Bias Current (4) 1.4 COUT = 1μF, No Load 0.3 1 V V +25°C 0.01 Full 0.01 Full 0.01 μA +25°C 50 μs μA THERMAL PROTECTION Thermal Shutdown Temperature TSHDN 150 °C Thermal Shutdown Hysteresis ΔTSHDN 15 °C NOTES: 1. VIN = VOUT (NOMINAL) + 0.5V or 1.7V, whichever is greater. 2. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT + 0.5V. (Only applicable for VOUT = +1.2V to +5.0V.) 3. VEN = -0.3V to VIN 4. Time needed for VOUT to reach 90% of final value. 7 / 15 www.run-ic.com RS3219 TYPICAL APPLICATION CIRCUIT 5Pin Typical Circuit VIN OUT CIN 1uF COUT 1uF RS3219 ON OFF EN NC GND 3Pin Typical Circuit VIN OUT CIN 1uF COUT 1uF RS3219 GND 8 / 15 www.run-ic.com RS3219 TYPICAL PERFORMANCE CHARACTERISTICS VIN = VOUT (NOMINAL) + 0.5V, CIN = 1μF, COUT = 1μF, TA = +25℃, unless otherwise noted. SHUTDOWN START UP 2V 2V 0V 0V 3.3V 3.3V 0V EN 0V VIN=3.8V VOUT=3.3V CIN=COUT=1uF ILO AD=1mA VOUT IOUT=50mA VOUT=3.3V Time(20us/div) Time(200us/div) LOAD-TRANSIENT RESPONSE LOAD-TRANSIENT RESPONSE 300mA ILOAD 50mA 0mA ILOAD 0mA 3.5V 3.5V VOUT 3.3V VOUT 3.3V 3.1V 3.1V VIN=VOUT+0.5V ILOAD=0mA to 200mA CIN=1uF VIN=VOUT+0.5V ILOAD=0mA to 50mA CIN=1uF Time(100us/div) Time(100us/div) LINE TRANSIENT RESPONSE VOUT=3.3V VIN=4.3V to 5.3V,IOUT=30mA 20mV/div VOUT Output Voltage(V) 3 1V/div VIN OUTPUT VOLTAGE vs INPUT VOLTAGE 3.5 2.5 2 1.5 1 0.5 0 Time(200us/div) 0 9 / 15 1 2 3 4 Input Votage(V) 5 www.run-ic.com RS3219 TYPICAL PERFORMANCE CHARACTERISTICS VIN = VOUT (NOMINAL) + 0.5V, CIN = 1μF, COUT = 1μF, TA = +25℃, unless otherwise noted. OUTPUT VOLTAGE ACCURACY vs TEMPERATURE GROUND CURRENT vs TEMPERATURE 0.4 160 Output Voltage Accuracy(%) Ground Current(uA) VOUT=3.3V 150 140 130 120 0.3 0.2 0.1 0 -0.1 -0.2 -0.3 -0.4 110 -40 -15 10 35 60 -40 85 -15 Temperature(ºC) VENH 1.6 60 85 VENL Threshold vs Input Voltage 1.2 1 VENL Thresholds(V) VENH Thresholds(V) 1.8 35 Temperature(ºC) VENH Threshold vs Input Voltage 2 10 1.4 1.2 1 0.8 0.6 0.4 VENL 0.8 0.6 0.4 0.2 0.2 0 0 1.5 2.5 3.5 4.5 5.5 6.5 7.5 1.5 2.5 3.5 Input Voltage(V) Power Supply Rejection Ratio(dB) Dropout Voltage vs Output Current 300 VOUT=3.3V Dropout Voltage(mV) 4.5 5.5 6.5 7.5 Input Voltage(V) 250 200 150 100 50 0 80 Power Supply Rejection Ratio vs Frequency 70 60 50 40 30 20 10 0 50 100 150 200 250 300 0.1 Output Current(mA) 1 10 100 1K 10K 100K 1M 10M Frequency(Hz) 10 / 15 www.run-ic.com RS3219 TYPICAL PERFORMANCE CHARACTERISTICS VIN = VOUT (NOMINAL) + 0.5V, CIN = 1μF, COUT = 1μF, TA = +25℃, unless otherwise noted. Output Voltage Noise vs Frequency Voltage Noise(uVHz) 1.8 1.6 1.4 1.2 1 0.8 0.6 0.4 0.2 0 10 100 1K 10K 100K 1M 10M Frequency(Hz) 11 / 15 www.run-ic.com RS3219 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 12 / 15 www.run-ic.com RS3219 SOT23-5 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 c θ L A1 Dimensions In Millimeters Dimensions In Inches Symbol Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 13 / 15 www.run-ic.com RS3219 UTDFN-1x1-4 3 4 2 1 Dimensions In Millimeters Dimensions In Inches Symbol MIN TYP MAX MIN TYP MAX A 0.340 0.370 0.400 0.013 0.015 0.016 A1 0.000 0.020 0.050 0.000 0.001 0.002 A2 0.100 REF 0.004 REF D 0.950 1.000 1.050 0.037 0.039 0.041 D1 0.430 0.480 0.530 0.017 0.019 0.021 E 0.950 1.000 1.050 0.037 0.039 0.041 E1 0.430 0.480 0.530 0.017 0.019 0.021 b 0.170 0.220 0.270 0.007 0.009 0.011 e 0.600 0.650 0.700 0.024 0.026 0.028 f L 0.195 REF 0.200 0.250 0.008 REF 0.300 14 / 15 0.008 0.010 0.012 www.run-ic.com RS3219 TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSION Reel Diameter Reel Width(W1) DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL UTDFN-1x1-4 Reel Diameter 7’’ Reel Width(mm) 9.5 A0 (mm) 1.16 B0 (mm) 1.16 K0 (mm) 0.5 P0 (mm) 4.0 P1 (mm) 4.0 P2 (mm) 2.0 W (mm) 8.0 Pin1 Quadrant Q1 SOT23-5 7’’ 9.5 3.20 3.20 1.40 4.0 4.0 2.0 8.0 Q3 SOT23-3 7’’ 9.0 3.20 3.30 1.30 4.0 4.0 2.0 8.0 Q3 Package Type 15 / 15 www.run-ic.com
RS3219-1.8YF5 价格&库存
很抱歉,暂时无法提供与“RS3219-1.8YF5”相匹配的价格&库存,您可以联系我们找货
RS3219-1.8YF5
    • 1+0.15560
    库存:2151
