TD8002ES5
TD8002ES5
    JINGYANG(晶扬电子)
    SOT23-5
    Character:1MHz,2A Synchronous Efficiency:96% Operating Voltage:2.5V-6.5V Iq:80uA Output Voltage:...
TD8002ES5 数据手册
TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO Description Features The TD8002 is a high efficiency, high frequency synchronous DC-DC step-down converter. The 100% duty cycle feature provides low dropout operation, extending battery life in portable systems.     The internal synchronous switch increases efficiency and eliminates the need for external Schottky diode. At shutdown mode, the input supply current is less than 1µA.       The current limit protection and on-chip thermal shutdown features provide protection against any combination of overload or ambient temperature. Low RDS(ON) for Internal Switch (Top/Bottom): 180/100mΩ 2.5V~5.5V Input Voltage Range 2A Output Current 1MHz Switching Frequency Minimizes the External Components Internal Soft-Start Limits the Inrush Current Internal Compensation Function 100% Dropout Operation Power Good Indicator Output (SOT-23-6 only) RoHS Compliant and Halogen Free SOT-23-5 and SOT-23-6 Packages Applications     Set Top Box LCD TV Tablet Portable Equipment Pin Assignments S5 Package (SOT-23-5) FB VIN 5 4 (Marking) 1 2 3 EN GND LX S6 Package (SOT-23-6) FB PG VIN 6 5 4 (Marking) 1 2 3 EN GND LX Figure 1. Pin Assignment of TD8002 Revision VB3 08/05/2015 1  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Typical Application Circuit OFF ON EN L1 VIN VIN LX VOUT TD8002 C1 R1 C3 C2 (opt.) FB GND R2 Figure 2. Schematic Diagram VOUT 3.3V 2.5V 1.8V 1.5V 1.2V 1.05V C1 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC 10μF MLCC R1 453kΩ 316kΩ 200kΩ 150kΩ 100kΩ 75kΩ R2 100kΩ 100kΩ 100kΩ 100kΩ 100kΩ 100kΩ L1 μH μH 1.8μH 1.5μH 1.5μH 1.2μH C2 22μF MLCC 22μF MLCC 22μF MLCC 22μF MLCC 22μF MLCC 22μF MLCC Table 1. Recommended Component Values Ordering Information Part number Package TD8002 ES5 SOT-23-5 TD8002 ES6 SOT-23-6 Revision VB3 08/05/2015 2  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Functional Pin Description Pin Name Pin No. (SOT-23-5) Pin No. (SOT-23-6) EN 1 1 Enable Control. this pin floating. GND 2 2 Ground Pin. LX 3 3 Power Switching Output. and low side NMOS. VIN 4 4 Power Supply Input Pin. Drive VIN pin by 2.5V to 5.5V voltage to power on the chip. PG -- 5 Open Drain Power Good Output Pin. FB 5 6 Voltage Feedback Input Pin. Connect FB and VOUT with a resistive voltage divider. This IC senses feedback voltage via FB and regulates it at 0.6V. Pin Function Pull high to turn the IC on, and pull low to disable the IC. Don’t leave Connect an inductor to the drains of internal high side PMOS Block Diagram EN PG VIN 1MΩ Power Good Undervoltage Lockout Bias Supply Enable Control Slope Compensation 90% VREF FB Control Logic Current Limit Logic COMP EA Control and Driver Logic 1 X LX Compensation VREF Soft Start Oscillator COMP GND Figure 3. Block Diagram of TD8002 Revision VB3 08/05/2015 3  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Absolute Maximum Ratings (Note 1) ● VIN to GND --------------------------------------------------------------------------------------------------- -0.3V to +6.5V ● LX to GND --------------------------------------------------------------------------------------------------- -0.3V to (VIN+0.3) ● EN, FB, PG to GND ---------------------------------------------------------------------------------------- -0.3V to VIN ● Package hermal esistance, (θJA) SOT-23-5 ------------------------------------------------------------------------------------------ +250ºC/W SOT-23-6 ------------------------------------------------------------------------------------------ +250ºC/W ● Package hermal esistance, (θJC) SOT-23-5 ------------------------------------------------------------------------------------------ +130°C/W SOT-23-6 ------------------------------------------------------------------------------------------ +110°C/W ● Maximum Junction Temperature (TJ) ------------------------------------------------------------------- +150°C ● Lead Temperature (Soldering, 10 sec.) ---------------------------------------------------------------- +260°C ● Storage Temperature (TSTG) ------------------------------------------------------------------------------ -65°C to +150℃ Note 1:Stresses beyond those listed under “Absolute Maximum atings" may cause permanent damage to the device Recommended Operating Conditions (Note 2) ● Supply Voltage (VIN) ---------------------------------------------------------------------------------------- +2.5V to +5.5V ● Junction Temperature Range ---------------------------------------------------------------------------- -40°C to +125°C ● Ambient Temperature Range ----------------------------------------------------------------------------- -40°C to +85°C Note 2:The device is not guaranteed to function outside its operating conditions. Revision VB3 08/05/2015 4  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Electrical Characteristics (VIN=5V, TA=25°C, unless otherwise specified.) Parameter Input Voltage Range Symbol VIN Shutdown Current ISHDN Quiescent Current Iq Reference Voltage VREF FB Input Leakage Current P-Channel MOSFET On-Resistance (Note 3) N-Channel MOSFET On-Resistance (Note 3) Conditions IFB Min Typ 2.5 EN=GND 0.1 VFB=0.65V, IOUT=0A 80 0.588 VFB=VIN Max Unit 5.5 V 1 μA μA 0.6 0.612 V 0.01 1 µA RDS(ON) 180 mΩ RDS(ON) 100 mΩ P-Channel Current Limit (Note 3) ILIM 2.1 A EN High-Level Input Voltage VIH 1.5 V EN Low-Level Input Voltage VIL Under Voltage Lockout Voltage 0.4 V UVLO 2.4 V UVLO Hysteresis VHYS 0.2 V Oscillation Frequency FOSC IOUT=500mA 0.8 Minimum On Time 50 Maximum Duty Cycle PG Rising Threshold PG Sink Current 1 100 1.2 MHz ns % VPG (H) VFB Rising 90 % IPG VPG=0.1V 1 mA 100 Ω VOUT Discharge Resistance Thermal Shutdown Temperature (Note 3) TSD 150 °C Internal Soft Start Time TSS 1 ms Note 3:Guarantee by design. Revision VB3 08/05/2015 5  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T 95 100 90 95 Efficiency (%) Efficiency (%) Typical Performance Curves 85 80 75 90 85 80 VOUT=3.3V VOUT=1.2V 70 75 VIN=3.3V VIN=5V 65 VIN=4.2V VIN=5V 70 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 0 2 0.2 0.4 0.6 Load Current (A) Figure 4. Efficiency vs. Load Current 1 1.2 1.4 1.6 1.8 2 80 100 Figure 5. Efficiency vs. Load Current 612 1.2 609 1.15 606 1.1 Frequency (MHz) Feedback Voltage (mV) 0.8 Load Current (A) 603 600 597 594 1.05 1 0.95 0.9 VIN=5V IOUT=0.5A 591 VIN=5V IOUT=0.5A 0.85 588 0.8 -40 -20 0 20 40 60 80 100 -40 Temperature (°C) 0 20 40 60 Temperature (°C) Figure 6. Feedback Voltage vs. Temperature Revision VB3 08/05/2015 -20 6 Figure 7. Frequency vs. Temperature  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 TITAN MICRO High Efficiency 1MHz 2A Synchronous Step Down Regulator /a85T Typical Performance Curves (Continued) VIN=5V, VOUT=1.2 , C μF, C μF, L 1.8μH, TA=+25°C, unless otherwise noted. IOUT=2A IOUT=0A VIN VIN 5V/div. 5V/div. VOUT 500mV/div. VOUT 500mV/div. IOUT 1A/div. IOUT 1A/div. VLX 2V/div. VLX 2V/div. 4ms/div. 4ms/div. Figure 8. Power On through VIN Waveform Figure 9. Power On through VIN Waveform IOUT=0A IOUT=2A VIN 5V/div. VOUT 500mV/div. IOUT 1A/div. VLX 2V/div. VIN 5V/div. VOUT 500mV/div. IOUT 1A/div. VLX 2V/div. 100ms/div. Figure 10. Power Off through VIN Waveform 100ms/div. IOUT=0A Figure 11. Power Off through VIN Waveform IOUT=2A VEN 5V/div. VEN 5V/div. VOUT 500mV/div. VOUT 500mV/div. IOUT 1A/div. IOUT 1A/div. VLX 2V/div. VLX 2V/div. 400μs/div. 400μs/div. Figure 12. Power On through EN Waveform Figure 13. Power On through EN Waveform Revision VB3 08/05/2015 7  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 TITAN MICRO High Efficiency 1MHz 2A Synchronous Step Down Regulator /a85T Typical Performance Curves (Continued) VIN=5V, VOUT=1.2 , C μF, C μF, L1=1.8μH, TA=+25°C, unless otherwise noted. IOUT=2A IOUT=0A VEN 5V/div. VOUT 500mV/div. IOUT 1A/div. VLX 2V/div. 4ms/div. Figure 14. Power Off through EN Waveform 5V/div. VOUT 500mV/div. IOUT 1A/div. VLX 2V/div. 4ms/div. Figure 15. Power Off through EN Waveform IOUT=0A IOUT=2A VOUT 20mV/div. ILX 200mA/div. VLX VEN VOUT 10mV/div. ILX 1A/div. VLX 2V/div. 2V/div. 20ms/div 1μs/div Figure 16. Steady State Waveform Figure 17. Steady State Waveform IOUT=0.2A to 2A VOUT 100mV/div. IOUT 1A/div. 200μs/div. Figure 18. Load Transient Waveform Revision VB3 08/05/2015 8  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 TITAN MICRO High Efficiency 1MHz 2A Synchronous Step Down Regulator /a85T Function Description Short Circuit Protection The TD8002 provides short circuit protection function to prevent the device damaged from short condition. When the short condition occurs and the feedback voltage drops lower than 40% of the regulation level, this will activate the latch protection circuit. Then output will be forced shutdown to prevent the inductor current runaway and to reduce the power dissipation within the IC under true short circuit conditions. Once the short condition is removed, reset EN or VIN to restart IC. The TD8002 is a high efficiency, internal compensation and constant frequency current mode step-down synchronous DC/DC converter. It has integrated high-side (180mΩ, typ) and low-side (100mΩ, typ) power switches, and provides 2A continuous load current. It regulates input voltage from 2.5V to 5.5V, and down to an output voltage as low as 0.6V. Control Loop Slope compensated current mode PWM control provides stable switching and cycle-by-cycle current limit for superior load, line response, protection of the internal main switch and synchronous rectifier. The TD8002 switches at a constant frequency (1MHz) and regulates the output voltage. During each cycle, the PWM comparator modulates the power transferred to the load by changing the inductor peak current based on the feedback error voltage. During normal operation, the main switch is turned on for a certain time to ramp the inductor current at each rising edge of the internal oscillator, and switched off when the peak inductor current is above the error voltage. When the main switch is off, the synchronous rectifier will be turned on immediately and stay on until next cycle starts. Over Current Protection The TD8002 over current protection function is implemented by using cycle-by-cycle current limit architecture. The inductor current is monitored by measuring the high-side MOSFET series sense resistor voltage. When the load current increases, the inductor current will also increase. When the peak inductor current reaches the current limit threshold, the output voltage will start to drop. When the over current condition is removed, the output voltage will return to the regulated value. Enable The TD8002 EN pin provides digital control to turn on/off the regulator. When the voltage of EN exceeds the threshold voltage, the regulator will start the soft start function. If the EN pin voltage is below the shutdown threshold voltage, the regulator will turn into the shutdown mode and the shutdown current will be smaller than μA. For auto start-up operation, connect EN to VIN. Over Temperature Protection The TD8002 incorporates an over temperature protection circuit to protect itself from overheating. When the junction temperature exceeds the thermal shutdown threshold temperature, the regulator will be shutdown. And the hysteretic of the over temperature protection is 30°C (typ). PG Signal Output (SOT-23-6 Package Only) Soft Start The TD8002 employs internal soft start function to reduce input inrush current during start up. The internal soft start time will be 1ms. PG pin is an open-drain output and requires a pull up resistor. PG is actively held low in soft-start, standby and shutdown. It is released when the output voltage rises above 90% of nominal regulation point. Under Voltage Lockout When the TD8002 is power on, the internal circuits will be held inactive until VIN voltage exceeds the UVLO threshold voltage. And the regulator will be disabled when VIN is below the UVLO threshold voltage. The hysteretic of the UVLO comparator is 200mV (typ). Revision VB3 08/05/2015 9  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Application Information Output Voltage Setting The output voltage VOUT is set by using a resistive divider from the output to FB. The FB pin regulated voltage is 0.6V. Thus the output voltage is: A low ESR capacitor is required to keep the noise minimum. Ceramic capacitors are better, but tantalum or low ESR electrolytic capacitors may also suffice. Output Capacitor Selection The output capacitor is used to keep the DC output voltage and supply the load transient current. When operating in constant current mode, the output ripple is determined by four components: Table 2 lists recommended values of R1 and R2 for most used output voltage. Table 2 Recommended Resistance Values VOUT R1 R2 3.3V 453kΩ 100kΩ 2.5V 316kΩ 100kΩ 1.8V 200kΩ 100kΩ 1.5V 150kΩ 100kΩ 1.2V 100kΩ 100kΩ PPL t PPL C t PPL PPL ( SL) t S S t t The following figures show the form of the ripple contributions. VRIPPLE(ESR)(t) Place resistors R1 and R2 close to FB pin to prevent stray pickup. + VRIPPLE(ESL) (t) Input Capacitor Selection The use of the input capacitor is filtering the input voltage ripple and the MOSFETS switching spike voltage. Because the input current to the step-down converter is discontinuous, the input capacitor is required to supply the current to the converter to keep the DC input voltage. The capacitor voltage rating should be 1.25 to 1.5 times greater than the maximum input voltage. The input capacitor ripple current RMS value is calculated as: ( MS) (t) + VRIPPLE(C) (t) (t) + VNOISE (t) (t) Where D is the duty cycle of the power MOSFET. This function reaches the maximum value at D=0.5 and the equivalent RMS current is equal to IOUT/2. The following diagram is the graphical representation of above equation. = VRIPPLE(t) IIN(RMS) (A) 1.2 2A 1 (t) 0.8 0.6 1A 0.4 0.5A 0.2 0 10 20 30 40 50 60 70 80 90 D (%) Revision VB3 08/05/2015 10  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Application Information (Continued) PPL ( S ) PPL ( SL) PPL (C) F SC That will lower ripple current and result in lower output ripple voltage. The Δ L is inductor peak-to-peak ripple current: S L SL L SL F SC L F SC L The following diagram is an example to graphically represent Δ L equation. L C ΔIL (A) Where FOSC is the switching frequency, L is the inductance value, VIN is the input voltage, ESR is the equivalent series resistance value of the output capacitor, ESL is the equivalent series inductance value of the output capacitor and the COUT is the output capacitor. Low ESR capacitors are preferred to use. Ceramic, tantalum or low ESR electrolytic capacitors can be used depending on the output ripple requirements. When using the ceramic capacitors, the ESL component is usually negligible. It is important to use the proper method to eliminate high frequency noise when measuring the output ripple. The figure shows how to locate the probe across the capacitor when measuring output ripple. Remove the scope probe plastic jacket in order to expose the ground at the tip of the probe. It gives a very short connection from the probe ground to the capacitor and eliminates noise. 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 L=1.2μH L=1.5μH L=2.2μH 2.5 3 3.5 5 5.5 VOUT=1.2V, FOSC=1MHz A good compromise value between size and efficiency is to set the peak-to-peak inductor ripple current Δ L equal to 30% of the maximum load current. But setting the peak-to-peak inductor ripple current Δ L between 20%~50% of the maximum load current is also acceptable. Then the inductance can be calculated with the following equation: Probe Ground L L VOUT 4 4.5 VIN (V) (MA ) F SC L To guarantee sufficient output current, peak inductor current must be lower than the high-side MOSFET current limit. The peak inductor current is shown as below: GND Ceramic Capacitor P A (MA ) L Inductor Selection The output inductor is used for storing energy and filtering output ripple current. But the trade-off condition often happens between maximum energy storage and the physical size of the inductor. The first consideration for selecting the output inductor is to make sure that the inductance is large enough to keep the converter in the continuous current mode. Revision VB3 08/05/2015 11  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Application Information (Continued) Feedforward Capacitor Selection Internal compensation function allows users saving time in design and saving cost by reducing the number of external components. The use of a feedforward capacitor C3 in the feedback network is recommended to improve transient response or higher phase margin. PCB Layout Recommendation he device’s performance and stability are dramatically affected by PCB layout. It is recommended to follow these general guidelines shown as below: 1. Place the input capacitors and output capacitors as close to the device as possible. The traces which connect to these capacitors should be as short and wide as possible to minimize parasitic inductance and resistance. VOUT C3 2. Place feedback resistors close to the FB pin. 3. Keep the sensitive signal (FB) away from the switching signal (LX). 4. Multi-layer PCB design is recommended. FB R2 GND For optimizing the feedforward capacitor, knowing the cross frequency is the first thing. The cross frequency (or the converter bandwidth) can be determined by using a network analyzer. When getting the cross frequency with no feedforward capacitor identified, the value of feedforward capacitor C3 can be calculated with the following equation: FC L1 VIN 4 3 LX PG 5 2 GND FB 6 1 EN R1 C3 C VOUT C2 C1 VIN R3 R1 TD8002 R2 SS Figure 19. Recommended Layout Diagram Where FCROSS is the cross frequency. To reduce transient ripple, the feedforward capacitor value can be increased to push the cross frequency to higher region. Although this can improve transient response, it also decreases phase margin and causes more ringing. In the other hand, if more phase margin is desired, the feedforward capacitor value can be decreased to push the cross frequency to lower region. In general, the feedforward capacitor range is between 10pF to 330pF. Revision VB3 08/05/2015 12  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO Marking Information /a85T 4 5 TD8002 DYWWZ 3 2 1 D: Internal Code(A-Z) Y:Year(7-2017,6-2016...) WW:Week(01-53) Z:Internal Code(00-09) (1) 4 5 TD8002 DYYWW 3 2 1 D: Internal Code(A-Z) YY:Year(17-2017,16-2016...) WW:Week(01-53) (2) 4 5 TD8002 XXXY 1 3 2 XXX: Wafer's Lot No Y: Internal Code (3) Revision VB3 08/05/2015 13  service@jy-electronics.com.cn  www.jy-electronics.com.cn TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator TITAN MICRO /a85T Outline Information SOT-23-5 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 3.00 E 2.60 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note:Followed From JEDEC MO-178-C. Carrier Dimensions Revision VB3 08/05/2015 14  service@jy-electronics.com.cn  www.jy-electronics.com.cn TITAN MICRO TD8002 High Efficiency 1MHz 2A Synchronous Step Down Regulator /a85T Outline Information (Continued) SOT-23-6 Package (Unit: mm) SYMBOLS UNIT A DIMENSION IN MILLIMETER MIN MAX 0.90 1.45 A1 0.00 0.15 A2 0.90 1.30 B 0.30 0.50 D 2.80 3.00 E 2.60 3.00 E1 1.50 1.70 e 0.90 1.00 e1 1.80 2.00 L 0.30 0.60 Note:Followed From JEDEC MO-178-C. Carrier Dimensions Revision VB3 08/05/2015 15  service@jy-electronics.com.cn  www.jy-electronics.com.cn
TD8002ES5 价格&库存
很抱歉,暂时无法提供与“TD8002ES5”相匹配的价格&库存,您可以联系我们找货
