HT7536S-2
HT7536S-2
    UMW(友台)
    SOT23-5
    线性稳压(LDO)
HT7536S-2 数据手册
UMW R UMW HT75XX LDO High voltage regulator Product introdution 75xx series is a low-power high-voltage regulator manufactured by CMOS process. The maximum input voltage is 30V and the output voltage range is 1.5V~12.0V.It has the characteristics of high precision output voltage, very low power supply current and very low drop voltage. Product features ● ● ● Low power consumption: ≤ 3μA ● ● High input voltage: up to 30V High precision output voltage: tolerance of + 3% ● Package form: TO-92, SOT89-3, SOT-23-3, SOT23-5 Low drop voltage: typical value 0.1V Low temperature bleaching: typical 50 ppm / ℃ ■ Product use ● Battery power supply equipment ● Various communication equipment ● Audio / video equipment ● Security monitoring equipment Package form and pin function definition SOT-23-3 23 3 SOT VIN GND VOUT Model selection name Order Code 7530 7533 75XX-1 7536 7540 7544 7550 www.umw-ic.com voltage (V) Maximum input Output tolerance voltage (V) 30 3.0 +3% 30 3.3 +3% 30 3.6 +3% 4.0 +3% 30 30 +3% 4.4 +3% 30 5.0 1 Package TO-92 SOT-89 SOT23-3 SOT-23-5 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator Principle block diagram Vin Vout Vref GND Limit parameter project Symbol Voltage VIN parameter Limit value Maximum input voltage 30 TO-92 power waste power waste PD temperature Company V 700 SOT-23 300 SOT-89 400 SOT-23-5 300 mW Tw working temperature - 40~85 ℃ Tc Storage temperature -50~125 ℃ Th welding temperature 260 ℃,10s Electrical properties ( TOPT=25℃) 7530 Typical value VIN=5V,IOUT= 10mA minimum value 2.91 Output current VIN=5V 60 100 △VOUT Load regulation VIN=5V,1mA≤IOUT ≤20mA - 100 150 mV VDIF Drop voltage IOUT=1mA - 100 - mV ISS Quiescent current Vin = 5V, no load - 2 3 µA ΔV /(ΔV * V ) Line Regulation 4V≤VIN ≤30V,IOUT=1mA - 0.2 - %/V VIN input voltage - - - 30 V ΔVOUT /ΔTa temperature coefficient - +0.45 - mV/℃ Symbol parameter Test conditions VOUT output voltage IOUT OUT IN OUT www.umw-ic.com 3 Maximum Company 3.09 mA V =5V,I =10mA IN OUT 0℃≤Ta≤70℃ 2 V UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator 7533 (TOPT=25℃) Symbol parameter Test conditions minimum value V OUT I OUT △V V OUT DIF I SS ΔV /(ΔV * V ) OUT IN V OUT ΔV /ΔTa OUT 7536 Maximum Company 3.399 V value output voltage V =5.5V,I =10mA 3.201 Output current V =5.5V 60 100 - mA Load regulation V =5.5V,1mA≤I ≤30mA - 100 150 mV Drop voltage I =1mA - 100 - mV Quiescent current Vin = 5.5V, no load - 2 3 µA Line Regulation 4.5V≤V ≤30V,I =1mA - 0.2 - %/V - - IN OUT IN IN OUT OUT IN OUT input voltage IN Typical V =5.5V,I =10mA, IN temperature coefficient OUT 0℃≤Ta≤70℃ 3.3 - 30 - +0.5 - minimum Typical Maximum V mV/℃ (TOPT=25℃) Symbol V OUT I OUT △V V parameter OUT DIF I SS ΔV /(ΔV * V ) OUT IN V OUT Test conditions ΔV /ΔTa OUT 7540 value 3.6 Company 3.708 V 100 - mA - 100 150 mV I =1mA - 100 - mV Quiescent current Vin = 5.6v, no load - 2 3 µA Line Regulation 4.6V≤V ≤30V,I =1mA - 0.2 - %/V - - output voltage V =5.6V,I =10mA 3.492 Output current V =5.6V 60 Load regulation V =5.6V,1mA≤I ≤30mA Drop voltage IN OUT IN IN OUT OUT IN OUT input voltage IN value V =5.6V,I =10mA, IN temperature coefficient OUT 0℃≤Ta≤70℃ - 30 - +0.6 - minimum Typical Maximum V mV/℃ (TOPT=25℃) Symbol parameter Test conditions value V I V Load regulation OUT DIF I SS ΔV /(ΔV * V ) OUT IN V IN OUT IN ΔV /ΔTa OUT www.umw-ic.com OUT V =6.0V Output current OUT △V V =6.0V,I =10mA output voltage OUT IN V =6.0V,1mA≤I ≤30mA IN OUT Company value 3.88 4.0 4.12 V 60 100 - mA - 100 150 mV - mV 3 µA Drop voltage I =1mA - 100 Quiescent current Vin = 6.0v, no load - 2 Line Regulation 5.0V≤V ≤30V,I =1mA - 0.2 - %/V - - - 30 V - +0.7 - mV/℃ OUT IN input voltage temperature coefficient OUT   V =6.0V,I =10mA, IN OUT 0℃≤Ta≤70℃ 3 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator 7544 (TOPT=25℃) Symbol V OUT I OUT △V V parameter OUT DIF I SS ΔV /(ΔV * V ) OUT IN V OUT IN ΔV /ΔTa OUT Symbol Test conditions minimum value 4.4 output voltage V =6.4V,I =10mA 4.268 Output current V =6.4V 60 Load regulation V =6.4V,1mA≤I ≤30mA - Drop voltage I =1mA - Quiescent current Vin = 6.4v, no load Line Regulation output voltage 7550 (TOPT= 25℃) Output IOUT current Symbol parameter Load △VOUT regulation VOUT output Drop voltage VDIF voltage Quiescent ISS Output IOUT current current ΔVOUT /(ΔVIN * VOUT) Line Regulation Load △VVOUT input voltage IN regulation temperature ΔVVOUT Drop voltage DIF /ΔTa coefficient Quiescent ISS current 100 - mA 100 150 mV 100 - mV - 2 3 µA 5.4V≤V ≤30V,I =1mA - 0.2 - %/V - - IN IN OUT OUT OUT V =6.4V,I =10mA, IN OUT 0℃≤Ta≤70℃ Test conditions = = VIN 7V,IOUT 10mA 4.85 VIN=7V 60 Test conditions VIN=7V,1mA≤IOUT ≤30mA = IOUT=1mA = VIN 7V,I OUT 10mA Vin = 7V, no load VIN=7V 6V≤VIN ≤30V,IOUT=1mA VIN=7V,1mA≤I - OUT ≤30mA VIN=7V,IOUT=10mA, IOUT=1mA 0℃≤Ta≤70℃ - 30 V mV/℃ +0.7 - - minimu m Typical Maximu m Company value value 5 100 5.15 V - mA minimu m Typical Maximu m Company 100 mV - value value - 4.85 - 60 - 5100 2 100 0.2 -- 100- -- 100 +0.75 - 5.15 3 - - 30 VmV µA mA %/V mVV -- mV/℃ mV Vin = 7V, no load - 2 3 µA 0.2 - %/V 30 V - mV/℃ ΔVOUT /(ΔVIN * VOUT) Line Regulation 6V≤VIN ≤30V,IOUT=1mA - VIN input voltage - - ΔVOUT /ΔTa temperature coefficient www.umw-ic.com Company V OUT input voltage VOUT Maximum 4.532 IN IN temperature parameter coefficient Typical value VIN=7V,IOUT=10mA, 0℃≤Ta≤70℃ 4 - - +0.75 UTD Semiconductor Co.,Limited UMW R UMW HT75XX LDO High voltage regulator Application circuit 1. Basic circuit 75XX GND VIN Vout 1 2 3 Vin Vout C1 10uF C2 10uF 2. High output current regulator 75XX www.umw-ic.com 5 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator 3. Short circuit protection circuit 75XX 4. Circuit for increasing output voltage (1) 75XX VOUT=Vxx (1+R2/R1)+Iss*R2 5. Circuit for increasing output voltage (2) 75XX VOUT=Vxx+VD1 www.umw-ic.com 6 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator 6. Current regulating circuit 75XX IOUT = VXX/RX + ISS 7. Dual output circuit 75XX 75XX Note:“××”Represents the output voltage www.umw-ic.com 7 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator Encapsulation information www.umw-ic.com 8 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator www.umw-ic.com 9 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator SOT-23-3 www.umw-ic.com 10 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd UMW R UMW HT75XX LDO High voltage regulator Ordering information Order code Package Baseqty Deliverymode UMW HT75xx-1 SOT-89 1000 Tape and reel UMW HT75xxS SOT-23 3000 Tape and reel UMW HT75xxA-1 TO-92 1000 Tape and reel UMW HT75xxS-2 SOT23-5 3000 Tape and reel www.umw-ic.com 11 UTD Semiconductor Co.,Limited Semiconductor Co., Ltd
HT7536S-2 价格&库存
很抱歉,暂时无法提供与“HT7536S-2”相匹配的价格&库存,您可以联系我们找货
