UMW
R
UMW HT75XX
LDO High voltage regulator
Product introdution
75xx series is a low-power high-voltage regulator manufactured by CMOS process. The maximum
input voltage is 30V and the output voltage range is 1.5V~12.0V.It has the characteristics of
high precision output voltage, very low power supply current and very low drop voltage.
Product features
Low power consumption: ≤ 3μA
High input voltage: up to 30V
High precision output voltage: tolerance of + 3%
Package form: TO-92, SOT89-3, SOT-23-3, SOT23-5
Low drop voltage: typical value 0.1V
Low temperature bleaching: typical 50 ppm / ℃
■ Product use
Battery power supply equipment
Various communication equipment
Audio / video equipment
Security monitoring equipment
Package form and pin function definition
SOT-23-3
23 3
SOT
VIN
GND
VOUT
Model selection
name
Order Code
7530
7533
75XX-1
7536
7540
7544
7550
www.umw-ic.com
voltage (V)
Maximum input
Output tolerance
voltage (V)
30
3.0
+3%
30
3.3
+3%
30
3.6
+3%
4.0
+3%
30
30
+3%
4.4
+3%
30
5.0
1
Package
TO-92
SOT-89
SOT23-3
SOT-23-5
UTD Semiconductor Co.,Limited
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
Principle block diagram
Vin
Vout
Vref
GND
Limit parameter
project
Symbol
Voltage
VIN
parameter
Limit value
Maximum input voltage
30
TO-92
power
waste
power waste
PD
temperature
Company
V
700
SOT-23
300
SOT-89
400
SOT-23-5
300
mW
Tw
working temperature
- 40~85
Tc
Storage temperature
-50~125
Th
welding temperature
260
℃,10s
Electrical properties
( TOPT=25℃)
7530
Typical
value
VIN=5V,IOUT= 10mA
minimum
value
2.91
Output current
VIN=5V
60
100
△VOUT
Load regulation
VIN=5V,1mA≤IOUT ≤20mA
100
150
mV
VDIF
Drop voltage
IOUT=1mA
100
mV
ISS
Quiescent
current
Vin = 5V, no load
2
3
µA
ΔV /(ΔV * V )
Line Regulation
4V≤VIN ≤30V,IOUT=1mA
0.2
%/V
VIN
input voltage
30
V
ΔVOUT /ΔTa
temperature
coefficient
+0.45
mV/℃
Symbol
parameter
Test conditions
VOUT
output voltage
IOUT
OUT
IN
OUT
www.umw-ic.com
3
Maximum Company
3.09
mA
V =5V,I =10mA
IN
OUT
0℃≤Ta≤70℃
2
V
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
7533
(TOPT=25℃)
Symbol
parameter
Test conditions
minimum
value
V
OUT
I
OUT
△V
V
OUT
DIF
I
SS
ΔV /(ΔV * V )
OUT
IN
V
OUT
ΔV /ΔTa
OUT
7536
Maximum
Company
3.399
V
value
output voltage
V =5.5V,I =10mA
3.201
Output current
V =5.5V
60
100
mA
Load regulation
V =5.5V,1mA≤I ≤30mA
100
150
mV
Drop voltage
I =1mA
100
mV
Quiescent current
Vin = 5.5V, no load
2
3
µA
Line Regulation
4.5V≤V ≤30V,I =1mA
0.2
%/V
IN
OUT
IN
IN
OUT
OUT
IN
OUT
input voltage
IN
Typical
V =5.5V,I =10mA,
IN
temperature
coefficient
OUT
0℃≤Ta≤70℃
3.3
30
+0.5
minimum
Typical
Maximum
V
mV/℃
(TOPT=25℃)
Symbol
V
OUT
I
OUT
△V
V
parameter
OUT
DIF
I
SS
ΔV /(ΔV * V )
OUT
IN
V
OUT
Test conditions
ΔV /ΔTa
OUT
7540
value
3.6
Company
3.708
V
100
mA
100
150
mV
I =1mA
100
mV
Quiescent current
Vin = 5.6v, no load
2
3
µA
Line Regulation
4.6V≤V ≤30V,I =1mA
0.2
%/V
output voltage
V =5.6V,I =10mA
3.492
Output current
V =5.6V
60
Load regulation
V =5.6V,1mA≤I ≤30mA
Drop voltage
IN
OUT
IN
IN
OUT
OUT
IN
OUT
input voltage
IN
value
V =5.6V,I =10mA,
IN
temperature
coefficient
OUT
0℃≤Ta≤70℃
30
+0.6
minimum
Typical
Maximum
V
mV/℃
(TOPT=25℃)
Symbol
parameter
Test conditions
value
V
I
V
Load regulation
OUT
DIF
I
SS
ΔV /(ΔV * V )
OUT
IN
V
IN
OUT
IN
ΔV /ΔTa
OUT
www.umw-ic.com
OUT
V =6.0V
Output current
OUT
△V
V =6.0V,I =10mA
output voltage
OUT
IN
V =6.0V,1mA≤I ≤30mA
IN
OUT
Company
value
3.88
4.0
4.12
V
60
100
mA
100
150
mV
mV
3
µA
Drop voltage
I =1mA
100
Quiescent current
Vin = 6.0v, no load
2
Line Regulation
5.0V≤V ≤30V,I =1mA
0.2
%/V
30
V
+0.7
mV/℃
OUT
IN
input voltage
temperature
coefficient
OUT
V =6.0V,I =10mA,
IN
OUT
0℃≤Ta≤70℃
3
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
7544
(TOPT=25℃)
Symbol
V
OUT
I
OUT
△V
V
parameter
OUT
DIF
I
SS
ΔV /(ΔV * V )
OUT
IN
V
OUT
IN
ΔV /ΔTa
OUT
Symbol
Test conditions
minimum
value
4.4
output voltage
V =6.4V,I =10mA
4.268
Output current
V =6.4V
60
Load regulation
V =6.4V,1mA≤I ≤30mA
Drop voltage
I =1mA
Quiescent current
Vin = 6.4v, no load
Line Regulation
output
voltage
7550
(TOPT=
25℃)
Output
IOUT
current
Symbol
parameter
Load
△VOUT
regulation
VOUT
output
Drop
voltage
VDIF
voltage
Quiescent
ISS
Output
IOUT
current
current
ΔVOUT /(ΔVIN * VOUT) Line Regulation
Load
△VVOUT
input
voltage
IN
regulation
temperature
ΔVVOUT
Drop
voltage
DIF /ΔTa
coefficient
Quiescent
ISS
current
100
mA
100
150
mV
100
mV
2
3
µA
5.4V≤V ≤30V,I =1mA
0.2
%/V
IN
IN
OUT
OUT
OUT
V =6.4V,I =10mA,
IN
OUT
0℃≤Ta≤70℃
Test
conditions
VIN 7V,IOUT 10mA
4.85
VIN=7V
60
Test conditions
VIN=7V,1mA≤IOUT ≤30mA
= IOUT=1mA
VIN 7V,I
OUT
10mA
Vin = 7V, no load
VIN=7V
6V≤VIN ≤30V,IOUT=1mA
VIN=7V,1mA≤I
- OUT ≤30mA
VIN=7V,IOUT=10mA,
IOUT=1mA
0℃≤Ta≤70℃
30
V
mV/℃
+0.7
minimu
m Typical
Maximu m Company
value
value
5
100
5.15
V
mA
minimu m Typical Maximu m Company
100
mV
value
value
4.85
60
5100
2
100
0.2
100-
100
+0.75
5.15
3
30
VmV
µA
mA
%/V
mVV
mV/℃
mV
Vin = 7V, no load
2
3
µA
0.2
%/V
30
V
mV/℃
Line Regulation
VIN
input voltage
ΔVOUT /ΔTa
temperature
coefficient
www.umw-ic.com
Company
V
OUT
input voltage
VOUT
Maximum
4.532
IN
IN
temperature
parameter
coefficient
Typical
value
VIN=7V,IOUT=10mA,
0℃≤Ta≤70℃
4
+0.75
UMW
R
UMW HT75XX
Application circuit
1. Basic circuit
75XX
GND VIN Vout
1
2
3
Vin
Vout
C1
10uF
C2
10uF
2. High output current regulator
75XX
www.umw-ic.com
5
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
3. Short circuit protection circuit
75XX
4. Circuit for increasing output voltage (1)
75XX
VOUT=Vxx (1+R2/R1)+Iss*R2
5. Circuit for increasing output voltage (2)
75XX
VOUT=Vxx+VD1
www.umw-ic.com
6
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
6. Current regulating circuit
75XX
IOUT = VXX/RX + ISS
7. Dual output circuit
75XX
75XX
Note:“××”Represents the output voltage
www.umw-ic.com
7
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
Encapsulation information
www.umw-ic.com
8
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
www.umw-ic.com
9
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
SOT-23-3
www.umw-ic.com
10
Semiconductor Co.,
Ltd
UMW
R
UMW HT75XX
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW HT75xx-1
SOT-89
1000
Tape and reel
UMW HT75xxS
SOT-23
3000
Tape and reel
UMW HT75xxA-1
TO-92
1000
Tape and reel
UMW HT75xxS-2
SOT23-5
3000
Tape and reel
www.umw-ic.com
11
Semiconductor Co.,
Ltd
很抱歉,暂时无法提供与“HT7550S-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.27720
- 200+0.17930
- 1500+0.15510
- 3000+0.13750
